#1 (permalink)
Ian
Another navigation retrofit
well this weekend i did my own navi retro to an 06 SI. all went well but it was very time consuming. the wiring harness is a PITA to remove and the new one i rerouted a different way because there was no way to put it in the stock location. i started on saturday at 1pm and finished on sunday at 1pm. i used teh OEM nav unit from the CR-V whish works perfect. there is no need to bypass the stock amplifer, and you do not need to plug in a XM antenna to ge the unit to boot up (was mentioned in the other thread). there is not much of a DIY since most of the car clips together and all you have to do is snap it into/out of place, except for the few screws here and there. and as or the wiring...just route the new wireing harness the same way the old one came out. all of the harness clips only fit one matching plug...so you cant really plug anything in the wrong area...and the harness is cut exactly to lenght.
i dont have the exact parts list but i will list off the things needed to do this without the voice activation and xm radio part. i will do thos ein teh near future though and give a write up. 1. navi surround w/ mounting brackets and hardware 2. nav unit 3. wire harness....(wire harness #2) |
Ian
i never 100% finished this DIY, there are no pictures but its all the parts you should need. all plug and play and the harnesses ony fit to a certain plug.
DIY OEM navi retrofit |
i got a 07 si sedan, i bouth the unit, the trim panel, all the pieces except for the wire harness and the floor harness b/c it wuz like 500 both parts through the dealer n they said you can prob get it cheaper but now i dont want to buy somethin wrong and i want to see if i can pik it up somehwere local or in the city somewhere, worse comes to worse i'll order it online but i wanted to start the job this wknd.
Ian
i listed the parts needed in another thread of mine. the part number in it are correct. just order the dash harness, and the XM antennae from online. (i dont think you need the floor harness). this will get you the basic install with everything workgin except voice activation.
#10 (permalink) |
yea i have the antenna already, im assuming its the thread u posted b4 to my request, it says instrument panel harness for 205.26 so if thats the one then do u no if i can get it anywhere local as a aftermarket bc i rather not pay 205.
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/34595-another-navigation-retrofit.html
| Audio - 8th Generation Honda Civic Forum | This thread | Refback | 12-23-2007 04:58 PM | |
| OEM Navigation retrofit questions | rvarg | I.C.E., Electrical, Security, & Navigation | 8 | 12-05-2008 12:52 AM |
| OEM navigation worth it?? | Hybrid93Hatch | I.C.E., Electrical, Security, & Navigation | 29 | 10-26-2006 03:34 PM |
| retrofit projectors | slik1017 | Lighting, H.I.D.'s, & Neon | 18 | 08-11-2006 11:41 PM |
| My First Day! (Civic EX Sedan with Navigation) | jwoertz | Civic Coupe And Sedan | 6 | 06-04-2006 02:59 AM |
| Hmm...retrofit Navi?? | SiGTi | Do It Yourself Articles | 2 | 04-16-2006 10:16 PM |
