#1 (permalink)
Question about installing speakers
I just bought a pair of front door speakers for my civic coupe. Crutchfield said I need to drill 1/8" holes in my car to mount the speakers! Is it just me or is this insane? Sorry I dont know much about car audio, but is this the norm for speaker installs to drill into the car? I figured the best bet would be to drill the holes in the speaker itself to match it up to the car but figured I would consult with the experts on here. Any help would be appreciated :)
well they will probably have you drill holes behind the door panel, where no one will see, so I do not think this sounds odd at all. Auto manufactures have been trying to make their audio systems more and more incompatible and less standard to make it hard to not pay $1,500 for a crappy oem system and then just go to a shop and get something better for $500. Just another example
Sounds fine to me though. No if these were visible holes, that would sound nuts. And drilling holes through speakers? Usually speakers have the cone (obviously woulnd't drill through that) and then a steel rim that goes around, I don't imagine drilling through the rim would be very easy. And that probably won't work anyways. |
#5 (permalink) | |
Though, my speakers do have a trim ring around the speaker itself with the screw holes (as most do). It's not hard to drill through that at all. |
#6 (permalink) | |
If you're going to do an MDF spacer ring, just screw that into the door with about 6 screws. First pre-drill the holes in the MDF. Then put the ring up against the door. Mark where you will drill your holes in the door with a white-out pen, or something visible. Then drill the holes in your door. Make sure to contersink your screw holes in the MDF ring so your speaker will sit flush. After this, screw the MDF ring down. If you do not use an MDF ring, the same logic appllies. Set your speaker to do the door, mark the holes, and drill. Fairly straight-forward job. Just use some common sense and you'll finish in about 30 minutes.
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/33430-question-about-installing-speakers.html
| I.C.E., Electrical, Security, & Navigation - Page 56 - 8th Generation Honda Civic Forum | This thread | Refback | 12-28-2007 03:07 PM | |
| Questions about installing front speakers. | SEBBA | I.C.E., Electrical, Security, & Navigation | 5 | 05-20-2007 10:37 AM |
| Speakers and Cap Question | i49ersfan1i | I.C.E., Electrical, Security, & Navigation | 10 | 12-07-2006 11:34 PM |
| question about speakers | i49ersfan1i | I.C.E., Electrical, Security, & Navigation | 1 | 11-29-2006 12:34 AM |
| Question on rear speakers | xinsungx | I.C.E., Electrical, Security, & Navigation | 2 | 11-26-2006 01:43 PM |
| Installing CAI Question... Not aligning right. | maiku | Civic SI | 2 | 10-30-2006 08:16 PM |
