Amp Recommendations - 8th Generation Honda Civic Forum
Old 10-18-2012, 03:15 PM   #1 (permalink)
JP
Amp Recommendations
So I already have Sony Xplod speakers in my car but I wanna add a sub. I was leaning towards going with a Kicker CVR 12. I want to run the speakers off of one amp and the sub off another. The front speakers have a 4 ohm impedence and a 270 W cap and the rear have a 4 ohm impedence and a 160 W cap. The sub is a Dual 2 ohm voice coil with a max of 800 W. Any help with what amp to buy is helpful.
JPonelove is offline
Old 10-18-2012, 05:39 PM   #2 (permalink)
Justin
Just so you know, watts as far as audio is useless... The important number is the RMS rating...
What kind of budget are you looking at?
Beckerson1 is offline   Reply With Quote
Old 10-18-2012, 07:25 PM   #3 (permalink)
JP
I'm willing to go up to 200 for an amp. And the RMS for the speakers is 50W on both and on the sub its 400W
JPonelove is offline   Reply With Quote
Old 10-18-2012, 07:48 PM   #4 (permalink)
papasin's Avatar
Richard
Do you have size/footprint in mind to address your space requirements? Precision Power makes some good budget-friendly amps IME.
Precision Power PPI BK 340.4 340W RMS 4-Ch Class A/B Black Ice Car Amp
EDIT: sub-amp would need to drive 400W RMS at 4ohm or 1ohm load (since your sub is 2ohm DVC - wire in series or parallel). Matching sub-amp is not critical, but if you want a consistent look/theme, the matching PPI amp could be this one:
http://www.sonicelectronix.com/item_...-BK650.1D.html
papasin is offline   Reply With Quote
Old 10-18-2012, 07:56 PM   #5 (permalink)
Justin
$200 for both a mono and 4 channel is low (if thats per amp then you can work with it)... So used would be your best option if you go that route... You can also look at getting a 5 channel but once again to get ones that are decent you will need to go used
Old 10-18-2012, 08:05 PM   #6 (permalink)
papasin's Avatar
Richard
My assumption was 200 per amp, but otherwise, yeah, hard to get.
Old 10-18-2012, 09:28 PM   #7 (permalink)
You should find the amp I picked up, Alpine MRX-V60, 5 Channel
Amazon.com: MRX-V60 - Alpine 5-Channel Subwoofer Amplifier: Car Electronics Amazon.com: MRX-V60 - Alpine 5-Channel Subwoofer Amplifier: Car Electronics
it's a class D and will run everything you want. It'll be a little weak on the sub channel but if $200 is your budget for both amps that would probably be your perfect solution to run all your speakers.
I originally had the same plan as you but I've decided to go up a step and put a set of components up front and fade out my rears and run them through the HU for when I need them.
rdubbs is offline   Reply With Quote
Old 10-18-2012, 11:57 PM   #8 (permalink)
JP
I meant 200 for each amp. And if I did get the 5 channel then how much would that push to each?
Old 10-19-2012, 01:50 AM   #9 (permalink)
It would usually be less RMS then getting a 4 Channel and a Mono separately but you can find some nice 5 channels that will push 50-100 RMS x 4 + 200-300RMS Sub that would fall right into your price range. Just shop around and find what will work best for your goals i.e. RMS ratings, Physical Space usage, built in crossover etc...
Old 10-19-2012, 03:45 PM   #10 (permalink)
Justin
Perfect... Go with Papasin's suggestion as those are wonderful amps
Since your 200 per amp then I would say defiantly go 4 channel and mono.
Old 10-19-2012, 08:23 PM   #11 (permalink)
DaNuKidd's Avatar
Dave
Listen to Rdubbs I had a alpine pdx5 and regret selling it
DaNuKidd is offline   Reply With Quote
Old 10-19-2012, 08:43 PM   #12 (permalink)
papasin's Avatar
Richard
I have nothing against 5-channel amps...actually will be using the successor to the pdx-5 (the pdx-v9) in another build (more power, shorter by 20% compared to the pdx-5). For hiding under a seat, definitely a better solution.
However, if you have the room, using a separate 4-channel and monoblock gives you more choices. And if one goes out, you only have to replace that part that went out. Just food for thought...
Old 10-19-2012, 09:13 PM   #13 (permalink)
Considering your budget I would stick with Papasin's suggestion! I just thought it was $200 total, and 5 channels are great and a lot of people are using them but like papasin said, you have more options for all the fun things that you can do in your vehicle! Plus you'll be feeding really clean and efficient power with those amps
Old 11-12-2012, 03:34 PM   #14 (permalink)
JP
Thanks for the feed back, I'll post an update if anything happens seeing as Im away at school right now.
Any recommendations CivicSi1Day ECU Tuning Information 4 01-28-2010 05:16 PM
Recommendations for NAV please! Evillager I.C.E., Electrical, Security, & Navigation 5 11-18-2009 04:35 AM
HID recommendations iNightlight California South 25 10-10-2009 05:56 AM
HID recommendations iNightlight Civic SI 25 10-05-2009 11:57 AM
i need recommendations kshakeylude20 Wheel And Tire Upgrades 1 01-27-2008 04:28 PM
