Old 02-21-2007, 10:31 AM   #1 (permalink)
Has any1 installed EX tweeters on LX/DX?
If it can be done, a quick procedure list with part numbers would be appreciated.
VR
VelociRacer is offline
Old 03-20-2007, 10:46 AM   #2 (permalink)
kelrog's Avatar
Sure if could be done, but I don't know why you would want to.
Walmart tweeters would be just as good sound wise, and cheaper @ $20.
And to run them just do a T-tap into the existing front speakers near the head unit. Takes like 20 mins to do. And you will get the same effect with a much cheaper price. Did it for my wife on her LX sedan, its not overwhelming, but its noticable, and cripser.
kelrog is offline
Old 03-21-2007, 12:56 PM   #3 (permalink)
Almost gave up on a response to my question. Thanks kelrog! That is exactly what I was looking for. Now, can you give me a bit more detail on the Walmart tweeter that fits? And are the front speaker wires labelled near head unit or do you need a wiring diagram? Thanks.
Old 03-23-2007, 10:29 AM   #4 (permalink)
kelrog's Avatar
I just got 1" tweeters. They are pretty cheap, like $20 bucks. They come with speaker wire as well. and a plastic surround/pod. They came in a red and clear plastic package, sorry can't remember the brand, pretty much no name.
EDIT: here is the pic of them in the store.
Anyways, I took the tweeters out of the pods, be very carefull not to break the speaker. then I mounted them to the factory locations, and ran the speaker wire thru the dash and glovebox. Then I tapped into the front right and left speaker wires about 6" from the stereo, with T tap (vampire taps) I connected the positive and negs. As for the wiring I just used the wire out diagrams from the ex sedan aftermarket headunit install. Here. And if you think you have connected it to the wrong wires, just use the stereo, and adjust the balance and fading, to find the correct wires.
Took me about 30 to an hour, due to the speaker pods I had to take apart.
I think it was worth it, because I hated sitting in the front, and blocking the highs from the speakers with my legs. =]
kelrog is offline
Old 03-25-2007, 10:51 AM   #5 (permalink)
Excellent info. Just one final question: The way you connected the tweeters is in Parallel with Front speakers. How is the EX wired from factory? Because impedance will decrease if wired in parallel and I don't want to overload the amp. If wired in series, impedance will increase but one blown voice coil will disable both the tweeter and the front speaker. So which way is it wired by design?
Old 03-25-2007, 11:33 AM   #6 (permalink)
IIRC the stock setup is wired in series.
RBP LX is offline
Old 04-02-2007, 05:12 PM   #7 (permalink)
ct20's Avatar
Cool
I had JBL Pro series components (1" tweeters and 6.5" coax) installed in my LX sedan...just made y connection with front 6.5 coaxials...sounds alright..but I really need an amp to make the components sound better. you can definitely tell a difference with the tweeters in the dash...much clearer sound than just coming from the door speakers.
ct20 is offline
Old 04-02-2007, 09:48 PM   #8 (permalink)
Eric
anybody pics of their setup??
ericivic is offline
Old 04-04-2007, 11:38 AM   #9 (permalink)
A pic of the tweeter housing in the dash (grill removed) would be great. Having a hard time imagining how an aftermarket tweeter is going to be dropped/attached/fixed in there.
Old 04-04-2007, 01:05 PM   #10 (permalink)
T-Tap
Can you just tap into the existing wires for the speakers up front?
Sznaps is offline
Old 04-07-2007, 11:57 PM   #11 (permalink)
BlackCivic's Avatar
I have MB Quarts all around + tweeter. I'll take picture about my tweeter setup tomorrow. stay tune
BlackCivic is offline
Old 05-27-2007, 10:48 AM   #12 (permalink)
kelrog's Avatar
yes this is what we are talking about. you can use tclips to tap in to the existing front speakers. to add a set of tweeters in your LX.
kelrog is offline
avic-z1 installed on 07ex no sound from tweeters narked I.C.E., Electrical, Security, & Navigation 10 03-31-2007 09:54 PM
Just installed my AEM CAI on my EX Coupe NightKidsGTR Bolt-Ons And All-Motor 25 08-31-2006 04:04 PM
AEM CAI Installed on EX Coupe! (1.8L) (pix & Video!) Lo0T Bolt-Ons And All-Motor 150 07-12-2006 02:22 PM
Ground Control's installed today on my EX otsacto Suspension and Brakes 25 06-19-2006 11:32 PM
