Brandon
Whoops! (voltage woes and worries)
So my fiance had installed a Xplod 1200w amp and 2 JL w3's at 2ohm, 4G wire, no big 3, single hi-amp schoche fuse. There was a SH1TTY crimp job inches down from the fuse off the power lead. I replaced the splice with a 100A inline fuse, and turned the gain on the amp up to a reasonable level... 2 days later, when Idling, the audio kept clipping out and the sat-nav resetting asd if I just started the car. Popped the hood, and my freshly brushed hot terminal was WHITE! Not fuzzy corrosion, just cooked white. I pulled the hi-amp fuse out to discover this:
Whoops - Imgur I am having a box built as we speak (Thanks to Beckerson1 for the hook-up! ) for a single Sundown Audio SA-10, 1.0ft^3@35Hz, with a Hifonics Brutus BRZ1200d running about 1,000w at ohm, and also doing the "Big 3" upgrade as well.(TL;DR) I need a better battery and I have been hearing the Optima's are a waste fo money for car audio compared to others out there. Which batter would you guys suggest for this setup? I don't think this build commands additional batteries, just need one solid unit to replace my crotch rocket battery on my Si. Thanks! Last edited by apor1a; 06-25-2012 at 01:04 PM. |
I would say fit the biggest possible you can under the hood. as for brand choice ive had great results with kinetic batteries although some people have had issues. XS power also makes great batteries even though i have no personal experience i have never heard a single negative review. The sizes that will fit under the hood with no modification are the kinetic hc1400 and xs d5100. if you are willing to do slight modification to the battery tray(no cutting just some bending and new batt. tie down) you can get the bigger size either kinetic 1800 or xs d3400. Also it is necessary that you upgrade the run of 4 gauge to a run of 0 gauge wire. Read this and use the voltage drop calculator that is included.
DIY - Understanding Voltage Drop (Headlight Dimming) |
#3 (permalink) | |
Justin
You will want to switch out that fuse holder... it shorted out... thats why its all melted and black, which i'm very surprised it didn't blow... It's like the fuse was completely bypassed which isn't good at all... I suggest switching to an ANL style fuse and holder such as this: and placing it right on the power wire itself... I have this holder and its very universal which can fit up to 1/0 gauge wire and a wide variety of ANL fuses... Also withstand the heat very well and have a very solid snap connection... And cheap Here is the fuse you can use: Its the 125 amp fuse but the 200 amp is shown... I also have used them and love the gold color... As for a battery... There are a few good brands out there for audio such as: Kinetik, XS power, REMY to name a few... I haven't had to look into batteries as I'm still pushing low enough power that the alternator can keep up... Lowest drop i've seen has been down to 13.7V at full tilt on idle at less then a second... nothing lower then 14V when cruising and on most songs stays at 14.4V... But if I were to pic one it would be equally between Kinetick and XS... really whichever has the lowest price when you buy it... But I agree with Vetc718 on the run of 1/0 power wire... So a complete new run of 1/0 to the rear, big 3 in 1/0 and if you can a dedicated 1/0 ground for your amp run straight to the negative on the battery... Last edited by Beckerson1; 06-25-2012 at 04:53 PM. |
#4 (permalink) | ||
Brandon
I think getting a larger battery is a must, I am shocked that these little turds power the car as it is! Running new wire to the rear? Fun ![]() Thanks for the links for the accessories, too, that's helpful in sorting all this crap out, it's all coming together at the same time, which is nice. How many feet would you guys estimate I would need for a fresh run to the rear, plus the big 3, of 0 would I need for my sedan? I know the 3 basically can be done with what like 5 feet total? I just don't want to order twice, and I haven't ever done any wiring myself (don't laugh at me) |
#5 (permalink) | |
Justin
I'm not sure how much for the sedan but you can actually use string to give you a rough estimate of the length... Just assume more then you will need as it will most likely come in handy at some point... I know in my coupe I have roughly 15' of RCA's with just under 3' of room to play with so I would say something like 18' should be more then enough to run back to the trunk and have plenty for the big three as well... Papasin may actually be better to answer this as he has a sedan... not sure but his build log may actually say how much he used... just shoot him a PM Last edited by Beckerson1; 06-25-2012 at 06:08 PM. |
I have a sedan and when I bought for the big three and a run from front to back I bought 25 feet and did have a decent amount left over. better to have a couple feet left over than to be a couple feet short
| Lug Nut Worries | 09CivicLX | Mechanical Problems & Technical Chat | 5 | 01-23-2012 04:16 PM |
| whoops | SiSoldier | Civic SI | 3 | 02-13-2010 10:21 AM |
| Rubbing worries | davisesteban | Suspension and Brakes | 2 | 11-24-2008 09:18 PM |
| Whoops! | Hondahawaii777 | Mid-Atlantic | 2 | 07-23-2007 04:20 PM |
