Battery options for cars with sound systems? - 8th Generation Honda Civic Forum
Old 05-12-2012, 11:57 AM   #1 (permalink)
runeknight95's Avatar
Derek
Hey looking for my options in getting a new battery for my car which has 2 amps in it for my system. The oem one lasted very long 3+ years, just want to get a better one that is a direct replacement.
runeknight95 is offline
Old 05-12-2012, 08:01 PM   #2 (permalink)
Justin
I got the Duralast Gold battery and love it... I'm not pushing to many amps with my system anyway...
Beckerson1 is offline   Reply With Quote
Old 05-16-2012, 05:31 PM   #3 (permalink)
jefferson111984's Avatar
Kinetic
jefferson111984 is offline   Reply With Quote
Old 05-16-2012, 11:14 PM   #4 (permalink)
Justin
Really you need to figure out how many Amps your amps will draw total...
Here is mine for example:
My mid/highs amp is capable of putting out 280W Max, thats where I have it set...
And my sub amp is set to 300W max...
So I'm looking at 580-600W Max combined
You know the amount of Watts and the Voltage which you can use 13.8 average voltage our cars run at idle...
So using the Formula Amps= Watts/Volts I get
580/13.8= 42A
With this you have a general idea, but most the time you won't require the full amperage as you won't be pulling the max wattage anyway as it fluctuates as your play music and different volumes... Also the cars components draw power as well so you need to keep this in mind... I can't remember the estimated amount of amps but I figure 30A roughly...
Now with a low draw system that I have you should be fine with most common batteries out there... but if you are running more then 1-1.5K or so then I would consider a pricier battery as the one suggested above...
Me personally with A/c on and system at full tilt run right around 14V at idle but with the Si you get a better alternator at 120A over the 70A the other civics have... so my story may be different then others
Old 05-17-2012, 09:50 AM   #5 (permalink)
omega48er's Avatar
John DOE
kinetik HC1800!!!! i was running 2 of these and they are great batteries.
omega48er is offline   Reply With Quote
Old 05-17-2012, 05:01 PM   #6 (permalink)
580/13.8= 42A
Well i gues with your formula im at 90.58. But i not only had to install an additional battery(kinetic) i also had to install as 240amp hi output alternator and run 0 gauge wires. The amperage was dropping so low it was frying my amp. My main amp runs off two 40 amp fuses and smaller just a single 40 amp fuse. I now will replace the battery under the hood with a kinetic battery as well. For the 2nd/trunk battery i simply bought a battery box and fit the biggest kinetic battery i could get($300) to fit in there
Ait Intake Systems / Exhaust Options elenamylove Civic SI 5 11-07-2008 09:52 PM
Feels and Spoon Coilovers systems for the Fd2 but will this fit on our cars???? Dizzle0420 Suspension and Brakes 12 09-12-2008 02:18 AM
Sound Systems and where are you buying them? kbeeveer46 Civic SI 15 05-25-2008 03:08 AM
Newbie On Sound Systems DC2006CivicEx I.C.E., Electrical, Security, & Navigation 7 10-04-2006 04:22 PM
