Hi,
This is my first lengthy post on this forum, but wanted to share regarding my audio install. I’ve worked on car audio of a few different cars over the years as a hobby since I was a teen (not for a shop, but mainly just DIY on family members cars). This is my first SQ install on my own car. I wasn’t able to take as many pictures as I probably should have but wanted to share my experience since I have learned a lot from others on this forum. I realize after looking at the other builds that what I’ve done definitely is not up to par with some of the top-notch work by others, but I had to start somewhere
Anyway, onto some of the install goals:
1. Achieve a decent level of sound quality. This is my daily driver and I don’t intend to enter any competitions.
2. Stealth is priority, show not at all.
3. Utilize the stock navigation head unit that came with the car. Had I to do it over again, would have probably chosen a car that didn't come with stock NAV, and gone aftermarket as I did with our other cars. Got the car though for less than I would have paid for one without, so can't complain too much.
4. Minimize loss of trunk space and retain the spare tire and have the ability to access it.
5. Re-use speakers from a previous car.
I’ll get started with some pics of the car:
As stated, the signal source comes from the stock navigation unit on a 2009 Honda Civic SI sedan that many of you of course have seen:
As many of you know, this HU connects to a 350W amplifier (per Honda’s specs) that resides under the driver’s seat in an SI sedan (the amp is under the center console for SI coupes). The forum has some information on this amp (believe it is a Pioneer amp), but the short and sweet on the factory amp is that there are two harnesses that are connected to it. I left the amp where it is, but unplugged the two harnesses. One harness comes from the HU, and the other harness breaks out to the 7 speakers in the stock locations:
2 tweeters in the dash
2 mids in the front doors
2 rear fills in the rear deck
1 “sub” (really a mid-bass) in the rear deck
I decided to remove all the stock speakers. I lined the outer door skin of each door and the trunklid with Dynamat Extreme (left over from another install). I realize I need to go back and take care of the inner door skin and seal the doors completely, but that’s for another day, when I get more time and materials.
I replaced the stock speakers with a set that I pulled from a previous car. Here’s what I had on hand that went into the stock locations:
Front stage: 2-way Infinity Kappa 60.7cs
Specs from its manual: 6-1⁄2" 2-Way Component set
Kappa Woofers that went into the doors:
Speaker Impedance: 2 ohms
Power Handling: 90W RMS, 270W Peak
Sensitivity: 95dB @ 2.83V, 1m
Frequency Response: 45Hz – 25kHz
Mounting Depth: 2-3⁄ 16" (56mm)
Cutout Diameter: 5" (127mm)
Kappa Tweeters that went into the dash:
Power Handling: 50W RMS, 150W Peak
Sensitivity: 94dB @ 2.83V, 1m
Frequency Response: 3.5kHz – 25kHz
Mounting Depth: 3/4" (19mm)
Cutout Diameter: 1-7/8" (48mm)
Rear fill: 3-way Infinity Kappa 63.7i (went into the rear deck)
Specs from its manual: 6-1⁄2" 3-Way
Power Handling: 75W RMS, 225W Peak
Sensitivity (2.83V, 1m): 95dB
Mounting Depth: 2-3⁄16" (56mm)
Cut-Out Diameter: 5" (127mm)
The stock sub was removed and the opening was left “open” to allow sound to come into the cabin from the sub.
To expedite wiring the speakers, I purchased a “Honda integration adapter” from Crutchfield and this connected to one of the harnesses coming out of the amp (Item #120701728). Again, “for another day”, I’ll probably replace the speaker wires to 14 or 12 gauge since the adapter utilizes what look to be 16 gauge at best, perhaps even 18 gauge.
Processing for this install is done by a JBL MS-8.
I think most are familiar with this unit. There's a massive 200+ page thread on the MS-8 in the DIYMA forum:
JBL's MS-8 processor! - DIYMA.com - Scientific Car Audio - Truth in Sound Quality
but the threads I found quite useful are these ones:
JBL's MS-8 - DIYMA.com - Scientific Car Audio - Truth in Sound Quality
JBL MS-8 FAQ - DIYMA.com - Scientific Car Audio - Truth in Sound Quality
To get the signal from the HU to the MS-8, a custom harness was utilized. The signal from the HU (before going into the amp) is, as I understand, differential-balanced output. Because of this, I decided not to tap from the speakers for hi-level input into the MS-8 as the stock amp probably does some filtering, and utilizing the differential-balanced output direct from the HU is going to be superior. I bought the harness from “Mercman” and this plugged into the harness coming from the HU. Mercman’s harness outputs 4 RCAs (2 RCAs for front and 2 RCAs for rears) and a remote turn on. Only the 2 RCAS for the front + remote turn on is connected to the MS-8. Pictures of the adapters/harnesses are below connected under the driver’s seat (hard to get a good shot since I didn’t remove the front seat for the install).
So basically two wiring bundles went from under the driver’s seat into the trunk. Wire ties were used every 6-8 inches.
For power, wiring from the battery was quite easy, many thanks to a nice write-up from another 8thcivic member (giving credit where credit is due):
http://www.8thcivic.com/forums/audio/87041-running-power-wire-trunk.html
This makes for a super clean power run and I don’t think my pictures do it justice.
I ran the power wire along the driver side all the way to the trunk.
Ground for the amps and the MS-8 was under the back seat, on an existing bolt, sanded down to the metal:
The amps and the MS-8 are mounted behind the back seats, and the amps used for this install are:
Alpine PDX-F4 (powers the front stage, birth sheet indicates 129Wx4 RMS at 4ohm)
Alpine PDX-M6 (powers the sub, birth sheet indicates 650Wx1 RMS at 4ohm)
The MS-8 powers the rear fill
For the sub, I used a JL Audio 10W3V3-4 and a sub enclosure from Audio Integrations (their Perfect Fit Enclosure) is utilized.
06 Honda Civic Sedan 10 Inch Perfect Fit Enclosure
Here’s a pic before installing the trim ring:
and a couple after:
The enclosure blends very well with the carpet in the trunk, and the trim ring provided by Audio Integrations along with a JL Audio speaker grill purchased separately matches nicely. This entire setup is ideal for us since we have to carry a stroller in the trunk a lot. I would be very worried about hitting the sub without a grill
. I had to trim the Honda Civic trunk mat so that it is not “stuck” under the enclosure since it bolts straight down (is subtle and only noticeable if you look very closely). This makes it easy to remove and the spare is still quite accessible with this setup.
What’s next?
1. Install and wire up a backup camera.
2. As stated above, I want to seal the doors completely.
3. Will probably re-wire the speakers to thicker ones (14 or 12 gauge) rather than utilize the Crutchfield adapter. I wired the sub with 12 gauge already straight to the M6 since they are both in the trunk vs. using the sub wire that came with the Crutchfield adapter.
4. Sound deaden the car a bit more (perhaps line the floors and trunk with 25% CLD + CCF + MLV)
5. Upgrade the speakers for my front stage.
6. Install tweeters in the A-pillars.
7. Move the amps under a front seat (since they are stackable) and move the MS-8 under the other seat.
8. Center speaker?
I know and realize, as I stated from the beginning, that my install is not up to par with many other folks in the forum, but for my first SQ install, I’m quite happy how everything turned out and came together. I’m happy to get any feedback, suggestions, and thoughts on the install.
and a couple after:
What’s next?
8. Center speaker?
