Old 01-04-2007, 09:16 PM   #1 (permalink)
mike11202's Avatar
Hmm Ported or Sealed Box?
Which type do you guys think I should get? I am looking for SQ and i was thinking about getting a double baffle ported box.
Its going up to an eD NINe.1 amp 450x1 @4ohm 900x1 @2ohm
Its a JBL W12GTi MkII Sub.
http://carsound.com/articles/publish/article_892.shtml
http://www.jbl.com/car/products/prod...at=SUB&ser=GTI
mike11202 is offline   Reply With Quote
Old 01-04-2007, 10:21 PM   #2 (permalink)
Eltrentz's Avatar
Lou
Personally i think sealed boxes make the bass sound better
Eltrentz is offline   Reply With Quote
Old 01-04-2007, 10:24 PM   #3 (permalink)
moxom's Avatar
A well designed/integrated sub will sound great regardless of the bass alignment.
moxom is offline   Reply With Quote
Old 01-04-2007, 10:24 PM   #4 (permalink)
I have had both and much perfer ported much deeper tone
c0lby68 is offline   Reply With Quote
Old 01-04-2007, 10:32 PM   #5 (permalink)
Ported only gives more bass at lower frequencies if you tune the box low; if you tune too high, you will LOSE low-end extension. But if you tune too high, you will lose high-end extension. It's a give-and-take situation. Sealed yields the best flat response, but won't be as loud. I'd say go sealed, if you don't like it or want louder, go ported.
Rommy is offline   Reply With Quote
Old 01-04-2007, 11:25 PM   #6 (permalink)
Go sealed... it is the only way to get tight SQ bass. You might try an Image Dynamics IDQ sub in it too... or if you have more bucks to spend - try an ID Max. Used ones can get in the $200 range.
As far as I know, there are very few systems in SQ competitions using ported bass... and that is for a reason.
Good luck!
Jim
less is offline   Reply With Quote
Old 01-05-2007, 12:57 AM   #7 (permalink)
Toxis's Avatar
Even Women Aren't Safe
Sealed > Ported in quality sound. Rommy pretty much summed it up.
Unless you want to talk about 4th order quasi-bandpass boxes for SQ. MMMMM Sorry!
Toxis is offline   Reply With Quote
Old 01-05-2007, 02:27 AM   #8 (permalink)
bikinpunk's Avatar
Erin
Ported, tuned low. That is all.
bikinpunk is offline   Reply With Quote
Old 01-06-2007, 02:54 PM   #9 (permalink)
I prefer ported for SQL.
lostdaytomorrow is offline   Reply With Quote
Old 01-06-2007, 02:55 PM   #10 (permalink)
Streethonda06's Avatar
Greg
I have a sealed box and the bass sounds so clean!!!! but it all depenst on how you like your sound good luck
Streethonda06 is offline   Reply With Quote
Old 01-06-2007, 11:49 PM   #11 (permalink)
Toxis's Avatar
^and what subs you have.
Old 01-07-2007, 07:49 AM   #12 (permalink)
moxom's Avatar
The best thing to do is call JBL and ask them for the T/S (Fs, Qts, and Vas)parameters and report back to us.
Auto sub manufacturers are notorious for advertising that a particular sub is suitable for all types of enclosures; which is usually a lie.
Woofers have a Q (Qts) factor which is a measure of how dampened the woofer is. It's that number that will determine if you need the dampening of a ported box or a sealed box to keep the distortion down and the output linear.
This is why I said that a properly designed ported or sealed box will sound good.
Most folks prefer one over the other because they either a) heard an improperly tuned sub or b) have read misleading information.
Old 01-07-2007, 12:30 PM   #13 (permalink)
Devin's Avatar
Devin Flannery
I've never been able to find information that explains all the T/S parameters. I've seen short definitions for some of the parameters, but never a full explanation. Last summer I took a Syn-Aud-Con seminar titled "Sound Reinforcement For Designers" in which the instructor, Pat Brown, defined "Q" as being a directivity factor relating to the Directivity Index of a driver. Maybe someone could break it all down, or as Pat would say, lets peel some onions.
Devin is offline   Reply With Quote
Old 01-07-2007, 03:31 PM   #14 (permalink)
Toxis's Avatar
Loudspeaker Cook Book by Lance Dickenson... or was it Vance? GREAT book!!!
Old 01-07-2007, 03:38 PM   #15 (permalink)
moxom's Avatar
Well let me do some peeling for ya':
In driver (the actual speaker) and system design (driver and enclosure) you have to take into account key enclosure and driver parameters to help predict and determine the box size, tuning frequency and F3.
The big three driver parameters are Qts., Vas and Fs.
Qts. is the driver's total dampening and is comprised of the electrical dampening (Qes) and mechanical dampening (Qms). The primary restoring force(spider), voice coil, magnetic flux, etc. will determine what the Qes and Qms will be.
The Vas is the amount of air it would take to equal the stiffness of the driver's suspension.
Fs is the resonant frequency of the driver when not enclosed.
Hope that helps.
Old 01-07-2007, 03:43 PM   #16 (permalink)
moxom's Avatar
That's why in this particular situation a properly designed box is more important than the box type.
It doesn't take much work to build the wrong type of enclosure...
PS: The only woofer line that I know of that can actually be used in any type of enclosure is the Infinity VQ line. You can actually change the driver's Qts. by replacing the metallic slugs near the pole piece.
Old 01-07-2007, 03:52 PM   #17 (permalink)
Smiley Whore
SiViC81's Avatar
Shu
If you are after SQ only, then a sealed box is the way to go...Right now I have a ported box and will switch over to a sealed box b/c I'm not happy with the SQ of the ported box...I've had both sealed and ported boxes and sealed boxex always have sounded better...Although a ported box will give you more bass, you compromise SQ and IMO it's not worth it for the extra bass...
SiViC81 is offline   Reply With Quote
Old 01-07-2007, 04:00 PM   #18 (permalink)
moxom's Avatar
That's your opinion...but it's flat out wrong.
What makes a closed box better than a ported box?
I have been building speakers that use both types of bass loading for about 20 years. I have built some that sound good and bad but I've never blamed it on the bass loading technique because I know better.
Old 01-07-2007, 04:14 PM   #19 (permalink)
Smiley Whore
SiViC81's Avatar
Shu
Well it's just my opinion...like I said, I have had both types of boxes and I prefer sealed b/c the bass is tighter and overall SQ is better, which is why I want to switch back to a sealed box...
Old 01-07-2007, 04:23 PM   #20 (permalink)
yankeesbat17's Avatar
Evan
ok heres the thing...
ported = more bass and much louder
sealed= better quality
i would go with ported because if you have a good quality sub it will even it out loudness and good quality
and if ur looking at jbl i would rather go with polk audio...http://www.polkaudio.com/caraudio/products/sr124svc/i find it alot better trust me ive heard everything
yankeesbat17 is offline   Reply With Quote
REMOTE START Tikolx333 I.C.E., Electrical, Security, & Navigation 36 06-08-2008 08:20 PM
just in case you need every cereal type from the 80's webby Water Cooler 16 12-09-2007 03:28 PM
New Box, couple pics bikinpunk I.C.E., Electrical, Security, & Navigation 2 10-21-2006 12:41 AM
Box design for 12w7. bikinpunk I.C.E., Electrical, Security, & Navigation 1 10-13-2006 03:39 AM
