Fuse & Wire Guide - Page 5 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 08-17-2009, 10:47 PM   #81 (permalink)
CarDriver's Avatar
Originally Posted by ROMA View Post
The fuse #27 (Option HAC) what is HAC? Coz my Si donīt have it! And the manual say it need it! Thanks for you help!!!
Hill-Start Assist Control? Haha, I don't know.
"HAC is the accessories division of Honda. Honda Accessories Corporation, I think. The fuse is probably for the trailer hitch wiring harness, as I think it is the only electrical accessory." -From a member in the Hond Ridgeline forums.
Googling didn't help me figure out what HAC is, and I'm sure you don't need it, and are fine without it.
CarDriver is offline   Reply With Quote
Old 08-20-2009, 11:28 PM   #82 (permalink)
nice write up broooo....
*****I AM UNABLE TO USE MY WINDSHIELD WASHER FLUID. ITS FILLED UP BUT JUST DOESNT COME OUT. DOES ANYONE KNOW WHATS WRONG WITH IT????*** MESSAGE ME...
JuszDipCivic is offline   Reply With Quote
Old 09-23-2009, 05:03 AM   #83 (permalink)
does anyone know what fuse controls the side mirror automation?
tonydatiga210 is offline   Reply With Quote
Old 10-12-2009, 01:00 PM   #84 (permalink)
MaXaZoR's Avatar
Another know if the Civic have a Neutral Positin Safety switch?
MaXaZoR is offline   Reply With Quote
Old 10-25-2009, 11:46 PM   #85 (permalink)
jmsamaco's Avatar
Originally Posted by CarDriver View Post
This is a great guide . I''ve exhausted myself with all this research, but still cannot figure this one out on my own. I figure a lot of knowledgeable people are here and can help me with this...
I have a basic LED "scanner" strip. Has a red, black, and yellow wire.
Here are the its directions:
"If you have a car alarm:
A1. Connect the red wire of the LED scanner to 12 volts constant positive.
A2. Connect the black wire from the LED scanner to the negative when armed wire of the car alarm
A3. Connect the yellow wire to 12 volts constant positive.
OR
If you do not have a car alarm:
B1. . Connect the red wire of the LED scanner to 12 volts constant positive.
B2. Connect the black wire from the LED scanner to constant negative
B3. Connect the yellow wire to the ignition wire that shows 12 volts when the key is turned to the ON position.
You're done. If you installed it with car alarm using step 1 above, then whenever you arm the alarm, the LED scanner will activate.
If you installed it without a car alarm using step 2 above, then the LED scanner will activate when your car is parked and the key is in the off position."
Whether I use Method 1 or Method 2, I don't care. I don't even know which method I'd use because I don't know if my keyless entry on my 2009 EX qualifies as an "alarm".
With this information in mind, plus what you know from Civic-specific fuse knowledge, can you guys tell me exactly what to do, and which fuse/wiring locations to use?
I've gone nuts going through countless DIYs and Googling, but cannot figure this one out.
Thanks
anyone has an answer for this?! i also have the same problem so please, anyone answer this, thanks!!!!
jmsamaco is offline   Reply With Quote
Old 10-26-2009, 12:16 AM   #86 (permalink)
CarDriver's Avatar
I'll get back to you on this. I ended up pulling a couple fuses out, wrapping the LED scanner wires around the fuse prongs, then reinserting the fuses.
With the LED's 3rd wire, I just wrapped it around the bolt on the right-hand side of the interior fusebox, and secured the bolt like normal. I guess that was my "ground" connection.
Old 10-26-2009, 09:53 AM   #87 (permalink)
jmsamaco's Avatar
Originally Posted by unplugged View Post
Here's a list of fuses and location #'s.. hope this helps!
Updated: Also included wires & locations!
Under-Hood Fuse Box
1. 100A - Main Fuse
70A - EPS
2. 80A - Option
50A - Ignition Switch Main
3. 30A - ABS motor
30A - ABS F/S
4. 50A - Headlight Main
40A - Power Window Main
5. -- Not Used
6. 20A - Fan Motor
7. 30A - Main Fan Motor - A/T
20A - Main Fan Motor - M/T
8. 40A - Rear Defroster
9. 40A - Blower
10. 10A - Hazard
11. 15A - FI
12. 15A - Stop, Horn
13. -- Not Used
14. -- Not Used
15. 7.5A - Oil Level Sensor
16. -- Not Used
17. -- Not Used
18. 15A - Ignition Coil
19. 15A - FI Main
20. 7.5A - MG Clutch
21. 15A - DBW
22. 7.5A - Interior Light
23. 10A - Back Up
Interior Fuse Box
1. 7.5A - Power Window
2. 15A - Fuel Pump
3. 10A - IGI ACG
4. 7.5A - ABS
5. 15A - Audio Amp
6. 20A - Front Fog Lights
7. -- Not Used
8. -- Not Used
9. 7.5A - ODS
10. 7.5A - Meter
11. 10A - SRS
12. 10A - Right Headlights High Beam
13. 10A - Left Headlight High Beam
14. 7.5A - Small Lights (Int)
15. 7.5A - Small Lights (Ext)
16. 10A - Right Headlight Low Beam
17. 10A - Left Headlight Low Beam
18. 20A - Headlight High Beam Main
19. 15A - Small Lights Main
20. -- Not Used
21. 20A - Headlight Low Beam Main
22. -- Not Used
23. -- Not Used
24. 20A - Moonroof
25. 20A - Door Lock
26. 20A - Dr Power Window
27. 20A - HAC Option
28. 15A - Rear Accessory
29. 15A - Accessory
30. 20A - Fr Pass Power Window
31. -- Not Used
32. -- Not Used
33. -- Not Used
34. -- Not Used
35. 7.5A - Accessory, Radio
36. 10A - IG2 HAC
37. 7.5A - Daytime Running Lights
38. 30A - Front Wiper
Ignition Wires
White - Constant 12V
Blue - Ignition
Yellow - Starter
Accessory - Orange
Second Accessory - Red
Other Wires
Vehicle Speed Sensor (VSS) - Blue wire (next to purple) on Radio Harness
Power Lock - green (-) dr kick or MICU, 34 pin plug, pin 28
Power Unlock - gray (-) dr kick or MICU, 34 pin plug, pin 27
Parking Lights - red (+) dr kick or fuse box, top 42 pin plug
Parking Lights - gray or red (-) switch or MICU, 20 pin plug, pin 13
Door Trigger - see notes (-) ea kick or fuse box, top 42 pin plug
Notes: The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
Hood Pin - lt. blue (-) pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Pin - blue (-) dr kick or fuse box, top 42 pin plug
Trunk/Hatch Release - green (+) dr kick or fuse box, top 42 pin plug
Factory Alarm Arm - orange (-) dr kick or MICU, 34 pin plug, pin 32
Factory Alarm Disarm - brown (-) dr kick or MICU, 34 pin plug, pin 31
Brake Wire - lt. green (+) switch or fuse box, top 42 pin plug
Parking Brake - orange (4dr) or lt. blue (2dr) (-) parking brake switch
Horn Trigger - orange (-) switch or fuse box, rear 16 pin plug
DEI 689M
Main Harness
Green: (-) door trigger, tap this into the door trigger input on the brain of the alarm. (DIODE ISOLATE!)
Purple: not used.
Black/White: Connect to black/white on the brain of the alarm.
Dark Blue: (-) status input, hook up to a blue or blue/white status output on the brain of the alarm
Light Blue: (-) status output, probably not needed
Yellow: 12v+ Ignition
Red: 12v+ Constant
Black: Ground
2-pin harness
purple: to black ground wire @ clutch pedal (yellow switch)
black: to orange trigger wire @ clutch (yellow switch)
Very nice write up, just want to know where i could find the ignition fuse wires? thanks!!
Old 10-26-2009, 02:50 PM   #88 (permalink)
jmsamaco's Avatar
I did everything on the book. I connected the led red wire to #8 fuse (open fuse), blue wire to #35 (radio) and tried other fuses, and the black wire to the ground. I also connected the led red wire to the white wire (12v positive), blue led wire to the blue wire (ignition) and orange wire (car alarm armed). I did everything but none of them works. I am going nuts about this..anyone who can assist me with this one please? i also need the exact location of the wires because i am not sure if i am doing the right thing..PLEASE PLEASE PLEASE!!!THANK YOU!!!
Old 10-26-2009, 08:25 PM   #89 (permalink)
CarDriver's Avatar
Originally Posted by jmsamaco View Post
I did everything on the book. I connected the led red wire to #8 fuse (open fuse), blue wire to #35 (radio) and tried other fuses, and the black wire to the ground. I also connected the led red wire to the white wire (12v positive), blue led wire to the blue wire (ignition) and orange wire (car alarm armed). I did everything but none of them works. I am going nuts about this..anyone who can assist me with this one please? i also need the exact location of the wires because i am not sure if i am doing the right thing.[/SIZE]
How about this:
Red wire to #35.
Blue wire to #8 Open Fuse.
Black wire to ground?
Old 10-26-2009, 09:04 PM   #90 (permalink)
jmsamaco's Avatar
How about this:
Red wire to #35.
thanks again bro, everythings done..i did what youve told me, really appreciate it..its just that, i prefer the led lights to activate when i lock the doors...anyways, thanks again!!
Old 10-26-2009, 09:19 PM   #91 (permalink)
CarDriver's Avatar
Cool...everything's done, as in...you got it to work? Or you gave up on it?
Old 10-27-2009, 09:48 AM   #92 (permalink)
jmsamaco's Avatar
^^^ i made it work and looks cool...i am also planning to get a remote start from honda in the future..
Old 11-18-2009, 10:27 AM   #93 (permalink)
PhilaCivic's Avatar
Philly Crew #35
awesome guide, thanks to this i avoided a trip to the stealership, i just had to replace a fuse and now my headlight works!! I thought they were supposed to crack when they blew?
PhilaCivic is online now   Reply With Quote
Old 11-27-2009, 09:43 AM   #94 (permalink)
Matt Pavliv
thank you!
matpav is offline   Reply With Quote
Old 12-09-2009, 01:52 AM   #95 (permalink)
where is top 42 pin plug at?
Kfkn20si is offline   Reply With Quote
Old 12-09-2009, 03:16 PM   #96 (permalink)
Adam D. Edwards
Thumbs up rear driving lights were off
Thanks for posting this. I was able to locate the fuse and fix it. I wondered why everyone was honking at me last night... no rear lights.
foldthings is offline   Reply With Quote
Old 02-14-2010, 08:05 AM   #97 (permalink)
My horn stopped working. After diagnosing, service center replaced the inside fuse box. And it started working.
Now I realized that my reverse light stopped working with the new fuse box. What can be wrong ?
BTW, mine is 2006 Civic-AT RHD, India.
I can post pic of the fuse box which I clicked in the workshop.
mgdelhi is offline   Reply With Quote
Old 04-26-2010, 01:25 AM   #98 (permalink)
Question reset trip not working
would really appreciate it if anyone can help me on knowing this, my reset trip odometer stopped working? and the button also next to it that controls the lights in the dash that brightens or dims it! if it is a fuse which one (number), thanks anyone?
jacob650 is offline   Reply With Quote
Old 04-26-2010, 08:32 AM   #99 (permalink)
CraigW's Avatar
Sounds more like a connector is loose from the switches.
Do those 2 buttons light up at night when the lights are on ??(same connector has illumination)
CraigW is offline   Reply With Quote
Old 04-26-2010, 09:27 AM   #100 (permalink)
BTomp6754's Avatar
Some good info here... Subscribed...
BTomp6754 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/2286-fuse-wire-guide.html
I.C.E., Electrical, Security, & Navigation - Page 59 - 8th Generation Honda Civic Forum This thread Refback 02-09-2008 04:18 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-31-2008 11:56 AM
HELP. Fuse Diagram for 06 Civic. - Automotive Forums .com Car Chat This thread Refback 01-29-2008 04:56 PM
Fuse Taps - Always Hot / ACC Hot - 8th Generation Honda Civic Forum This thread Refback 01-26-2008 05:24 AM
HELP. Fuse Diagram for 06 Civic. - Automotive Forums .com Car Chat This thread Refback 01-09-2008 01:59 AM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-30-2007 02:09 AM
I.C.E., Electrical, Security, & Navigation - Page 99 - 8th Generation Honda Civic Forum This thread Refback 12-13-2007 07:36 PM
Sidemarker DIY ErichPryde Exterior Style Mods 427 01-19-2012 11:15 PM
DIY: Solar Panel Install on Civic Hybrid giantquesadilla Electrical 25 09-18-2011 10:38 PM
step by step K2motor "ebay" fogs install on LX Coupe (Canada) yippieguy Lighting, H.I.D.'s, & Neon 38 03-16-2009 10:45 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
