Rear speaker wires, which wires are positive and negative.
My 2006 Civic Sedan VTi (Australia model) has blue and orange for right rear speaker wires and grey and brown for rear left speaker wires. Which ones are positive and negative?
I just completed my Amplifier and Subwoofer setup, and the Kenwood 8104D amplifier turns on (blue and red light) but the subwoofer has no sound. The amplifier uses speaker level inputs (tapped from the rear left and right speakers) and has auto sensing turn on. Did I wire them correctly? Wouldn't the amp not turn on if it wasn't wired correctly? By the way, I'm using Alpine Type-R 10" speakers 4ohm dual voice coil (SWR-1042D model), wired to 2 ohm and my amplifer accepts 2ohm load stable at 500 RMS. Thanks. |
Then I have wired the speaker level input wires correctly. The subwoofer still doesn't have sound.
The Kenwood 8104D amplifier has power lights on (Blue and red) but the subwoofer makes no sound or vibration whatsoever. The wiring setup should be correct, so I don't know what's wrong. I don't think the subwoofer is defected because I just bought it and it hasn't been used before. Can anyone help me? |
Not sure about the Aussie models, I have a US version 07 civic sedan, and the wires are as follows:
Left rear + = Yellow (Port 11) Left rear - = Brown (Port 2) Right rear + = Blue (Port 16) Right rear - = Orange (Port 8) I give the ports because I believe they link to the same terminals regardless of wire color. If you look at the back plug and face the part you unplug from the radio directly, it should have 9 ports on top (Ports 1-9 left to right) and then 8 ports on the bottom (Ports 10-17 left to right). If they're not much different, hope that helps. |
How does the multimeter tell you what's pos and neg? I tried this once before by turning on the radio, running the multimeter at DC voltage and putting the leads on the speaker wires in the harness after it was disconnected, and I got the pos and neg on the display of the meter and thought that that was the correct pos and neg of the speaker wires. This made all the sense in the workd to me and I thought it was the correct way to find out, but then after doing some research, I found out that in fact, the way i did it was wrong. The small DC voltage that you get when touching the speaker wires was not accurate. I found the wiring diagram for the car, and the meter was wrong.
How did you do it to find the pos and neg. This is really important as if you do it wrong, you will reverse polarity and the bass will be inconsistent as one woofer will move the opposite way as the other, canceling out the bass sound waves. Now, of course this is going into a line out converter and then the single subwoofer I am hooking up may have one rca opposite polarity of the other in the converter which will translate to sloppy bass sound. I need a wiring diagram for those rear speakers, and I am hoping that lml Frank lml has it correct. I will also run the meter and see if what lml Frank lml has said also is consistent with a multimeter test. Pea soup. Does this make sense to you guys? |
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/193099-rear-speaker-wires-wires-positive-negative.html
| Thread rear speaker wires | CamaroZ28.Com Message Board - The Ultimate Source for 2010 Camaro News, Info, and Community | BoardReader | This thread | Refback | 07-21-2011 09:56 PM | |
| Speaker level input wires | richardcwc | I.C.E., Electrical, Security, & Navigation | 3 | 05-15-2011 11:49 AM |
| Speaker builds, positive and negative material qualitys. | mightygoose | I.C.E., Electrical, Security, & Navigation | 21 | 10-20-2009 05:39 PM |
| How to find out positve and negative speaker wires. | pks17 | I.C.E., Electrical, Security, & Navigation | 6 | 04-24-2009 06:33 PM |
| front door speaker wires | goob | I.C.E., Electrical, Security, & Navigation | 22 | 07-07-2008 09:43 PM |
| RCA Or Speaker Wires?? | Johannes | I.C.E., Electrical, Security, & Navigation | 23 | 02-17-2007 02:52 PM |
