D.I.Y. : Tweeter install in factory Location (w/ pics)
I did not see any threads for this so i thought i would post my idea w/ pics (sorry about some of the pic quality, i had some glare probs) anyways i wanted to install some upgraded tweets but wanted to keep the stock tweeter look w/ stock tweeter grill. (dont know if it matters but, fyi i am doing this to my 07 si)
to begin you need to take out your stock tweeters which are attached to the stock grills. webby's post on front speakers ( http://www.8thcivic.com/DIY/speaker-...l.html#tweeter )will describe this in detail along with some tips for wiring your tweets. front view of stock tweeters attached to stock grills: ![]() back view of stock tweeters attached to stock grills: ![]() close up of stock tweeter attached to stock grill: ![]() I am using JL .075" tweeters, shown here: ![]() My idea was to use the stock mounting procedures to attach my JL tweeters to the factory grills. So i first removed the stock tweeters from the stock grills, they are held in by three tabs around the white tweeter mounting ring (see in pic below). next i dissassembled the stock tweeter so i could use the white mounting ring to attach my new tweeters to the factory grill. NOTE! i couldn't get the white mounting ring off of the factory tweeter with out sacrificing the stock tweeters. here is a pic of the white mounting ring off of the stock tweeter beside one of my JL tweeters: ![]() ![]() Next i fit the JL tweeters into the white mounting rings (took some persuasion w/ my dremel): ![]() ![]() ![]() ![]() I then snapped the JL tweeters w/ the white mounting rings on them into the stock grills: ![]() after that you simply pop the whole "assembly" (new tweeters attached to the stock grills) back into place. (no pics cause it looks stock, just as i planned :) ) good fit and great sound! any questions or comments welcomed |
#7 (permalink) | |
#8 (permalink) | |
#11 (permalink) |
Just in case someone does this and searches for a DIY...
Here is what I did and no pics.... 1. Get flat tip screwdriver and pry the grille off. 2. Disconnect Tweeter from factory clip 3. Remove tweeter from housing/grille. 4. Using hot glue gun, glue new tweeter to grille/housing. 5. Solder new wires that will reach X-over and simply drop down...they come out by kickpanel area on both sides. No clothes hanger...etc. Very simple No pics needed |
| DIY: Injen CAI install on R18 (lots of pics) | peliROJO | Engine | 72 | 07-24-2008 02:07 PM |
| Civic Front Speaker install PICS (56K Get an upgrade) | Mobieus | I.C.E., Electrical, Security, & Navigation | 12 | 07-21-2008 06:27 PM |
| install factory spoiler leaving deck lid spoiler also | jameshot | Civic Coupe And Sedan | 4 | 11-04-2006 10:25 PM |
| Factory Alarm Upgrade Pics | 2006civic808 | I.C.E., Electrical, Security, & Navigation | 16 | 07-31-2006 01:30 PM |
| system install pics | aliefnate | I.C.E., Electrical, Security, & Navigation | 10 | 05-18-2006 09:03 AM |
