DIY: Wiring Si spoiler Third brake light into DX/LX/EX brake light plug - 8th Generation Honda Civic Forum
Old 08-14-2009, 08:05 PM   #1 (permalink)
jbsali's Avatar
Joel
Lightbulb DIY: Wiring Si spoiler Third brake light into DX/LX/EX brake light plug
1- Unclip your Third Brake Light cover
2-Disconnect the Third brake light (un-plug)
3-Find the Si spoiler third brake light plug (located in middle of trunk)
4-Disconnect Si spoiler third brake light (plug)
5- Find a decent length of wire that looks thicker then the Stock Third brake light wiring
6- Strip the wire on both ends
7- Feed the wires into the stock DX/LX/EX male plug (ground-ground, power-power)
7- Cut or splice the other end of the wires into the si spoiler third brake light.
9- tape or zap-strap the wires along the license plate bulb wiring that leads to the left/driver side trunk arm.
10- your done.
This was a quick way of connecting the bulk wire from the si spoiler to the LX stock third brake light plug. I shoved the wires into the hole and taped it up so the 2 wires dont touch eachother. Use electrical tape to keep the connections away from eachother
http://i434.photobucket.com/albums/q...ivic077777.jpg
Hope this helps.
Total time of wiring install: 20min
jbsali is offline
Old 03-07-2011, 11:51 PM   #2 (permalink)
Scotty1981's Avatar
Scott
What guage wire did you use?
Scotty1981 is offline   Reply With Quote
Old 03-08-2011, 03:56 AM   #3 (permalink)
jbsali's Avatar
Joel
i believe it was 16 gauge.
jbsali is offline   Reply With Quote
DIY: sedan spoiler removal & third brake light swap sm2s DIY Honda Civic Exterior Style Mods 52 05-18-2013 11:27 AM
Wiring Si spoiler brake light to EX Third Brake Light! Need Help! jbsali I.C.E., Electrical, Security, & Navigation 8 08-14-2009 05:09 AM
DX/LX/EX third brake light in Si? Arethusa Inside and Out 23 04-29-2009 03:24 PM
Ex Third Brake Light On A Lx! CivicCoupe06 Lighting, H.I.D.'s, & Neon 9 01-10-2008 04:42 PM
Ex w/ Si Spoiler, 3rd brake light? ksmithers88 Inside and Out 7 03-15-2007 06:11 PM
