Complete Stereo Wire Diagrams - All Stereos/Navigation - Page 4 - 8th Generation Honda Civic Forum
Old 10-14-2015, 02:01 PM   #61 (permalink)
DeDonDeRosa's Avatar
DeDonDeRosa likes to double clutchDeDonDeRosa likes to double clutchDeDonDeRosa likes to double clutchDeDonDeRosa likes to double clutch
can i use a 09 prem nav unit in an 08 non nav si ?
DeDonDeRosa is offline   Reply With Quote Quick reply to this message
Old 10-14-2015, 02:19 PM   #62 (permalink)
BlurpleFG1's Avatar
Zimmer
BlurpleFG1 just put it into 1st gear on 8thcivic
Yes, as long as you have the 09-11 navigation style connectors.
BlurpleFG1 is online now   Reply With Quote Quick reply to this message
Old 11-07-2015, 05:39 PM   #63 (permalink)
08coupe just put it into 1st gear on 8thcivic
I don't see any preamp subwoofer signal of the 2 door premium or anything else for that matter. I'm thinking the amp is splitting the signal internally to output to the rear speakers and sub. This makes little sense .. especially with the stock sub being 2ohms.
I do know in my 08 Ex the amp has internal crossover for the front tweeters and door speakers.
However its great to have this info for the rest of it.. Thanks for the post.
08coupe is offline   Reply With Quote Quick reply to this message
Old 11-17-2015, 04:49 AM   #64 (permalink)
will82's Avatar
will82 just put it into 1st gear on 8thcivic
Garage
front speakers go out when I use the power windows... obviously a short but not even sure where to start anyone had this problem before?
will82 is offline   Reply With Quote Quick reply to this message
Old 11-17-2015, 08:46 AM   #65 (permalink)
BlurpleFG1's Avatar
Zimmer
I remember reading a TSB for this in regards to the early EX sedans but I didn't find it with a quick search.
Anyway, it involved the driver's door harness either being too short or inatalled in a way that pulled the wires from the connectors when the window was used. The early EX sedan drivers door harness was revised to fix this.
Old 11-18-2015, 05:32 AM   #66 (permalink)
will82's Avatar
Garage
thanks ill check that out
Old 03-17-2016, 05:04 PM   #67 (permalink)
John_Hammond just put it into 1st gear on 8thcivic
Super helpful info! Thanks! Sub'd
John_Hammond is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 06:55 PM   #68 (permalink)
MNTonyB just put it into 1st gear on 8thcivic
I acquired a Honda Navi unit from a Civic Hybrid - part number 39541-SNA-A320-M1. Based on the information contained in this thread, was able to get the unit up and running on the bench, including Aux port and the factory XM radio unit. So thank you very much for all the great wiring diagrams.
I do have one question. The output of the radio is REALLY anemic. Since the face plate on the radio did not say "Premium Audio" I assumed the radio I picked up didn't require the external amplifier, but given the way the radio sounds (and the fact the speaker wiring is the same whether you are going directly to the speakers or to the Amp), I'm suspecting I'll need an external amp. I have been unable to find any site or information to help me determine whether my specific radio needs the external amp or not. Does anybody know how or where I can go to determine that? Google searches haven't yielded any good results.
Thanks in advance for your replies.
MNTonyB is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 09:22 PM   #69 (permalink)
BlurpleFG1's Avatar
Zimmer
All 06-11 Hybrid navigation systems have the amp built into the unit. None of them were Premium units with a separate amp.
Looking up Honda navigation systems by using 39541 is practically useless because Honda lists them as 39540 in thier system.
Under the Zoom In/Out button there's a 4 digit alphanumeric code, what is it?
Old 04-20-2017, 10:43 PM   #70 (permalink)
Thanks for the quick reply BlurpleFG1. The four digit code under the Zoom In/Out on my radio is 2AD4.
Old 04-21-2017, 05:49 AM   #71 (permalink)
BlurpleFG1's Avatar
Zimmer
Originally Posted by mntonyb View Post
Originally Posted by blurplefg1 View Post
all 06-11 hybrid navigation systems have the amp built into the unit. None of them were premium units with a separate amp.
Looking up honda navigation systems by using 39541 is practically useless because honda lists them as 39540 in thier system.
Under the zoom in/out button there's a 4 digit alphanumeric code, what is it?
thanks for the quick reply blurplefg1. The four digit code under the zoom in/out on my radio is 2ad4.
2ad4 = 39540-sna-a31.
Old 04-21-2017, 09:18 AM   #72 (permalink)
Thank you. So, this confirms that the radio does not need an external amp. Assuming I have wired it up on the bench correctly, the fact that the sound coming out of it is anemic, (very little bass even with the bass turned all the way up and a large discrepancy between the volume coming out of the front speakers vs the rear speakers) suggest a problem with the radio itself, correct?
Old 04-21-2017, 09:53 AM   #73 (permalink)
BlurpleFG1's Avatar
Zimmer
What speakers are you using to test with?
A Hybrid would have come with 2 front door speakers, 2 rear deck speakers and 2 tweeters in the dash. All were made by Pioneer and are 4ohm.
Old 04-21-2017, 10:58 AM   #74 (permalink)
Great question. I tested the system with two different sets of speakers. The first set were the original Honda speakers from the car, which have 4 ohms, 15 watts stamped on the back of each one. The second set of speakers I tested with are the speakers I want to install in the car - Pioneer TS-D1602R. They are rated at 4 ohms and 250 watts.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/165790-complete-stereo-wire-diagrams-all-stereos-navigation.html
Club Quebec Auto Son :: Accessoires et Fit Kit This thread Refback 09-13-2011 08:13 AM
2010 LX single DIN radio wiring pinout - Honda CR-V Owners Club Forums This thread Refback 09-10-2011 03:51 AM
Honda Civic/PAC SWI-PS - AVIC411.com This thread Refback 08-22-2011 01:04 PM
DIYMA.com - Scientific Car Audio - Truth in Sound Quality - View Single Post - 2006 Honda Civic EX - Here we go again!!! This thread Refback 07-16-2011 10:26 AM
Info.com - stereo diagram - www.Info.com This thread Refback 07-14-2011 09:02 AM
Complete Stereo Install [Sedan Si] jonofmac I.C.E., Electrical, Security, & Navigation 40 08-10-2013 12:53 AM
Complete Book of Wiring Diagrams for 07-UP Civics (All Trims) Shroot420 I.C.E., Electrical, Security, & Navigation 5 09-23-2010 03:25 PM
Complete 07 SI Stock Stereo Swap DgreeCali07 I.C.E., Electrical, Security, & Navigation 30 08-04-2007 07:58 PM
Navigation and Multiplex integrated control unit. k wire and Security wire? xternallight I.C.E., Electrical, Security, & Navigation 2 08-23-2006 01:58 AM
