Navigation and Multiplex integrated control unit. k wire and Security wire? - 8th Generation Honda Civic Forum
Old 08-23-2006, 12:59 AM   #1 (permalink)
I got a hold of a civic nav.
I'm trying to install it in a 2001 Accord. Same dash fits no prob.
The issue is that I've gotten the wire codes and attempted to wire it up. But I have no signs of life.
The only wires I haven't hooked up are the pins labeled k-wire and security which go to the multiplex integrated control unit and the vsp wire which goes to the ecu.
I'm wondering if it is because of these wires that I have no juice. If so what do I give them for a connection. Since obviously the accord doesn't have this to work with.
xternallight is offline
Old 08-23-2006, 01:21 AM   #2 (permalink)
vsp would probably go to a speedo output or something related to the vehicle speed sensor for the speed sensitive volume control, im just guessing on that though.
security i want to say just needs a low level power input and there should be a wire from the accord that was for a security as well.
i have no clue what the k is for, but i think not having the security hooked up would be the killer. i dont really know for sure this is just intuition.
ethlar is online now   Reply With Quote
Old 08-23-2006, 02:58 AM   #3 (permalink)
took a cruise throught the manual and there wasn't anything obvious as to what the k and security wires actually do.
VSP is for the Vehicle Speed Pulse.
Check your connections as you should be able to power up the unit at least without any problems. I saw on another thread where someone had their navi hooked up and running off the 12v power from a PC.
Mobieus is offline   Reply With Quote
