help i installed a kennwood double din navi, and I am not getting sound to the speakers...I toook the blue and white wire from radio harness and attached it to soild light blue on factory harness for factory amp trun on, but still no sound.....
reviving from the thread, i'm a really experienced installer and i did an install for a kenwood radio today and i'm having the same issue he's having. everything's wired accordingly!
Did you do a amp bypass/rewired the speakers or did you forget to hookup the factory amp? You need to take the PowerCon and wire it to turn on the factory amp.
i found the fix you have to give signal to plug number 2 the light blue wire bur I am getting a bit of static possibly because i am getting signal from a cable in plug number 1
I just used the wire harness I got with the dash kit I ordered that plugs into the stock radio's plug and matched cable colors going to the aftermarket radio. Then from plug number 2 which is a bit smaller that also gets plugged into the stock radio there is a light blue cable I believe is number 15 and got signal from there which is what gave the sound but gives static specially during playing a dvd or cd. If you can please explain the Whiterice's way and is it necessary to bypass the stock amp
If you don't bypass the stock amp you will be sending an amplified signal from the HU to the stock amp which also amplifies it. I had this problem which caused the volume to be very touchy. Vol 1-5 would sound like 20-30 and became distorted.
ive installed an 07 civic ex navi into my 00 civic ek i got it all to work but i got the sound turned all the way up but you can bearly hear is ..y is that?
i assume when you tape the HU blue/white wire to the Car side Lt. Blue wire you mean the Lt. Blue on the small plug? I am having the same problem and noticed that both plugs have a light blue wire. so i'm nervous to tap one or the other.
I hate to try to revive a thread but If i start a new one I'm sure I'll hear that I need to search first.
I've tried tapping into the light blue with silver dots cable with the blue remote wire and blue antenna wire but still no sound. you can see the red arrow pointing to this
just to make sure I'm not supposed to be connecting to the plug circled in blue correct? That's what I thought at first but then saw the other plug.
Any help would be appreciated.
Related Threads
12M posts
157.5K members
Since 2005
