2008 SI Security/Remote Start/Keyless Entry Wire Diagram
WIRING INFORMATION - HONDA / CIVIC / 2008 / Remote Start
12volts white (50A) + ignition switch, brown 7 pin plug, pin 3 Starter yellow + ignition switch, brown 7 pin plug, pin 1 Ignition blue + ignition switch, brown 7 pin plug, pin 6 Accessory orange + ignition switch, brown 7 pin plug, pin 4 Second Accessory red + ignition switch, brown 7 pin plug, pin 5 Keysense pink - ignition key cylinder, green 6 pin plug, pin 1 Power Lock green or blue - driver kick or MICU, lt. green 34 pin plug, pin 28 Power Unlock gray - driver kick or MICU, lt. green 34 pin plug, pin 27 Lock Motor blue 5 wire driver kick or fuse box, rear, 14 pin plug, pin 7 Unlock Motor yellow 5 wire driver kick or fuse box, rear, 14 pin plug, pin 13 Parking Lights+ red + dr kick or fuse box, lt. green 42 pin plug, pin 19 Parking Lights- gray - headlight switch, 12 pin plug, pin 11 Hazards green + hazard switch, blue 5 pin plug, pin 2 Turn Signal(L) blue + dr kick or fuse box, lt. green 42 pin plug, pin 40 Turn Signal(R) brown + dr kick or fuse box, lt. green 42 pin plug, pin 39 Reverse Light brown (4-door), purple (2-door) + dr kick or fuse box, lt. green 42 pin plug, pin 15 Door Trigger green - dr kick or fuse box, lt. green 42 pin plug, pin 37 Dome Supervision pink - below fuse box, blue plug Trunk/Hatch Pin blue - dr kick or fuse box, lt. green 42 pin plug, pin 36 Hood Pin yellow/red to lt. blue - hood pin switch or fuse box, blue 21 pin plug, pin 13 Factory Alarm Arm orange or pink - driver kick or MICU, lt. green 34 pin plug, pin 32 Factory Alarm Disarm brown - driver kick or MICU, lt. green 34 pin plug, pin 31 Tachometer NOT yellow/black or yellow/green ac any fuel injector Brake Wire lt. green + switch or fuse box, lt. green 42 pin plug, pin 34 Parking Brake orange or lt. green - parking brake switch or driver kick, 23 pin plug, pin 13 or 18 Horn Trigger orange - horn switch, white 20 pin plug, pin 10 WIRING INFORMATION - HONDA / CIVIC / 2008 / Keyless Entry 12volts White + Ignition Switch Or Top Row Of Driver's Fuse Box Starter Yellow + Ignition Switch Or Top Row Of Driver's Fuse Box Ignition Blue + Ignition Switch Or Top Row Of Driver's Fuse Box Power Lock Green - Driver's Door Harness, Behind Fuse Box White Con. Power Unlock Gray - Driver's Door Harness, Behind Fuse Box White Con. Lock Motor Unlock Motor Yellow Reverse Driver's Door Harness, Behind Fuse Box White Con. Parking Lights- Gray - At Lights Switch Door Trigger Green - Driver's Fuse Box Second Row In A 42 Pins Conn. Trunk/Hatch Release Green + Driver Running Board Harness Factory Alarm Arm Brown - Driver's Door Harness, Behind Fuse Box White Con. Factory Alarm Disarm Orange - Driver's Door Harness, Behind Fuse Box White Con. Horn Trigger Orange - Top Of Sterring Collumn White Connector WIRING INFORMATION - HONDA / CIVIC / 2008 / Security 12volts White + Ignition Switch Or Top Row Of Driver's Fuse Box Starter Yellow + Ignition Switch Or Top Row Of Driver's Fuse Box Ignition Blue + Ignition Switch Or Top Row Of Driver's Fuse Box Power Lock Green - Driver's Door Harness, Behind Fuse Box White Con. Power Unlock Gray - Driver's Door Harness, Behind Fuse Box White Con. Unlock Motor Yellow Reverse Driver's Door Harness, Behind Fuse Box White Con. Parking Lights- Gray - At Lights Switch Door Trigger Green - Driver's Fuse Box Second Row In A 42 Pins Conn. Trunk/Hatch Pin Dk.Blue - Driver's Fuse Box Second Row In A 42 Pins Conn. Hood Pin Lt.Blue - Harness With Gray Tape Bellow Fuse Box Trunk/Hatch Release Green + Driver Running Board Harness Factory Alarm Arm Brown - Driver's Door Harness, Behind Fuse Box White Con. Factory Alarm Disarm Orange - Driver's Door Harness, Behind Fuse Box White Con. Tachometer At Any Coil 1 Cyl Top Of Engine Horn Trigger Orange - Top Of Sterring Collumn White Connector Last edited by Keith Ngo; 11-26-2008 at 07:09 PM. |
| DIY: push start button ( wiring diagram) | BATANG CITY JAIL | Electrical | 509 | 06-10-2009 12:37 PM |
| CTR Push start button DIY install w/pics and wiring diagram | acb384 | Electrical | 201 | 06-02-2009 07:46 PM |
| Security/Remote Start/GPS Wire Diagram | Pumpdog | I.C.E., Electrical, Security, & Navigation | 8 | 12-10-2008 01:53 PM |
| Audio Wire Diagram for 2008? | Gas Is Expensive | I.C.E., Electrical, Security, & Navigation | 16 | 04-15-2008 07:45 PM |
| Remote Start/Alarm w/auto rear defrost? | yearight | I.C.E., Electrical, Security, & Navigation | 17 | 12-14-2007 11:09 PM |
