#1 (permalink)
upgrading your electrical system
pulled this from a local car site.. im going to do it next weekend... its good for all the guys that have stereos or neons (slaps him self on the forehead) in there car
hey yea i would say get a yellow top battery and do the "BIG THREE" here is how to do it We’ll start out by explaining exactly why you’re doing this upgrade. As you should know, the bigger the power wire in your sound, video or lighting system, the better it will perform and you should experience less dimming and/or voltage drops. The Big 3 is.. 1) Alternator Positive to Battery Positive (optional fuse) 2) Battery Negative to Chassis 3) Chassis to Engine Block Replacing/adding larger wire to these three critical spots can reduce or rid your electrical system of dimming and voltage drops. Overall, giving your charging system a larger surface area to travel over, will stabilize power and relieve strain on the alternator and battery. If you have little cash to spend on a High Output (HO) alternator at the moment.. and the thought of even buying a new/better battery is daunting to you, this is a cheap and quick solution for your voltage issues. Each wire serves its own special purpose, so you need to upgrade/replace all three for maximum potential of this mod. The Alternator Positive to Battery Positive wire is pretty small on a stock electrical system, so quite obviously upgrading that particular wire will increase power flow from the alternator to the battery. In DC power systems, power flows negative to positive. So upgrading the main grounds is just as important as the main power wire is. And lastly, since the alternator is grounded to the engine block, you need a way to transfer that energy back into the system. Items You Need You’ll need a varying assortment of tools and supplies to successfully complete this job. Depending on how large your engine compartment is you’ll need between 5-10ft of wire. I recommend you use the absolute largest you can afford. 1/0awg is a very popular choice for completing this upgrade, although others have been known to use 4awg. Remember that anything over stock is still better, but while you’re under there... you might as well go big You’ll also need several crimps sized for whatever wire you use. A normal amount would be 6. If you upgrade your stock battery terminal to something with set screws, you’ll need one less crimp. If you decide to fuse the Alternator Positive to Battery Positive wire, you’ll need a fuse and fuse holder. Try to fuse for the maximum amperage of your wire. Beginning the Project 1) Start out by disconnecting your Battery Negative. This will interrupt power through the whole system allowing you to safely work on the vehicle without danger to you or the cars more fragile electronic devices. 2) Sand down the potential grounding point for the new Chassis to Battery Negative point. This should be shiny metal when you’re done. You want as clean of a connection as possible. If you use the existing ground point you may not have to drill a new hole for a screw. Sand around it to ensure a good connection still. This connection must be tight and secure when you’re done. 4) Screw the new ground wire in place but DO NOT reconnect it to the Battery Negative yet. Lay it down on a piece of cloth or paper and wait to connect it till after you finish the other elements of the project. 5) It’s time to add onto the existing Alternator Positive wire. This can be a bit tricky due to a small plastic collar around the positive lead coming off of the alt. It really only allows you to use one ring terminal terminated wire on the alt. That is perfectly fine though. Break off a little of the plastic if the extra wire refuses to fit. There should be a rubber gasket over the existing wire that will protect it. Again, make sure that the wire is hooked snug on the terminal and not exposed to the elements. 6) Take the other end of the Alternator Positive wire and if you so choose, run it through the fuse holder. If you’ve decided to not get a fuse holder, then run it straight to the battery positive. 7) Attach the wire along the way to something that won’t get too hot and that won’t vibrate too terribly. Go ahead and connect the wire to the positive battery terminal. 8) The last step is the Chassis to Engine Block wire. Remember to sand both points well, just like the when you did the Battery Negative to Chassis. All you need to do for this step is to find a non-essential bolt on the engine block to attach the wire to. Non-essentials are those that don’t hold a liquid in. For example… using the Oil Drain plug as an attachment point probably isn’t the smartest place. 9) Take the other end leading off of the engine block and sand a smooth place on the chassis. If you want to do more than one lead off of the block that would be fine as well. The more the merrier. 10) You’re just about done. Re-check all of the new and old connections you just fiddled with to ensure stability, safe connection and good contact. After you’ve made sure everything is safe, you may re-attach the Battery Negative wire to the negative terminal on the battery. Congratulations! You’ve just completed the cheapest and easiest upgrade to your electrical system that there is |
AFAIK, no, it won't void warranty. Just don't REPLACE the factory wiring. Simply ADD those wires to your system. In other words, you'll have 2 wires in each set of the big 3: the factory, and the newer, larger wire.
Current flows the path of least resistance. |
#5 (permalink) | |
Might wanna run that wiring away from the factory wires....don't wanna introduce noise into the system. Also, there are cheaper, lighterweight alternatives to the Optima batteries. Them bishes is heavy... |
#9 (permalink) | |
I have all Tsunami Competition 1/0 to do Big 3 and for my audio. Along with Tsunami Comp. 4awg from my Stinger fused distro. Whenever I get around to doing the install (still need amp and sub) then I will do a DIY on the Big 3. Seems to me I'm going to have to take my front bumper off to find the block and chassis grounds... Other batteries to look into: Kinetik and Stinger/Oddessy |
LinkBack to this Thread: http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/11424-upgrading-your-electrical-system.html
| DIY: radar detector hard wire - Page 9 - 8th Generation Honda Civic Forum | This thread | Refback | 02-07-2008 10:19 PM | |
| My new HO alternator - 8th Generation Honda Civic Forum | This thread | Refback | 01-07-2008 01:32 PM | |
| Amplifier screwing with my electrical system! | galaxycivic | I.C.E., Electrical, Security, & Navigation | 8 | 07-05-2006 12:00 PM |
| Looking for 2-way security system | marc-o-lishuz | I.C.E., Electrical, Security, & Navigation | 14 | 05-29-2006 12:01 PM |
