Old 07-14-2006, 11:29 AM   #1 (permalink)
xtv-sidecar's Avatar
Kevin
Help GPS speed pulse lead
I need to know How or where to find a speed pulse lead wire for a navi HU, I have a test light but not a Volt metor. And where would I find this in cruse control or at the trany? Will a test light pick this up?
Like i said HELP!!!!!
xtv-sidecar is offline
Old 07-14-2006, 01:41 PM   #2 (permalink)
#1, TEST LIGHT BAD!!! Can really screw things up with the computer. Go out and get yourself a voltmeter, you can get them for under $20 and it could save you hundreds.
#2, A test lamp won't show you variations in voltage of a wire, so you'd be hard pressed to find the wire using one. Pulses are often so rapid that you won't see anything but a lit lamp.
basmoq is offline
Old 07-14-2006, 04:08 PM   #3 (permalink)
Hyperite's Avatar
Blue wire on the main radio harness. Don't **** with a test light or volt meter, neither will pick it up.
Hyperite is offline
Boosted Scion TC video webby Garage 20 09-22-2007 06:06 AM
Honda Civic Si Launch Night on Speed Channel jasonandre Civic SI 14 03-11-2006 06:16 PM
speed stats for Si GeorgiaBoy Civic SI 7 01-18-2006 02:51 PM
GPS Navi or Laptop yoshizuki Garage 3 09-09-2005 06:56 PM
