Couldn't pull the trigger on a race header, so I went with the next best thing... - Page 6 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Header Discussion
Old 02-20-2012, 10:47 PM   #101 (permalink)
tookwick4ya's Avatar
Originally Posted by w00t692 View Post
What i've garnered from this thread:
OP wants to show off something that looks pretty and does nothing
People that agree with the OP, have the same setup as him
People that disagree know this isn't a good setup
Meh.
I agree with him because he accomplished his goal.
I have a shorty header+HFC setup and I hate it because although there were gains, there could be so much more. I'm getting a Race Header no cat very soon. Most likely Skunk2!
Just respecting what someone did, that's all.
tookwick4ya is offline   Reply With Quote
Old 02-24-2012, 01:52 AM   #102 (permalink)
I just saw this thread. I had the same setup as OP plus cat. I actually contacted BERK to start making HFC for our cars. I was gonna buy RT cat but it had 2" outlet I believe. It looks much smaller than BERK. It has 3" hfc and about 2.9" piping all the way through. Outlet does merge to 2.5" at the end. Nice piece. I had it paired with CT shorty on my car for 1.5 years maybe. Car is SCed and I had zero issues with hfc melting, clogging, etc.
Anyway, I finally decided to get Kiddracing header and paired it with 2.5" hfc. Also, I swapped TSX TB to 3.7 TL TB and changed 2.5" CT exhaust to 2.75" Q300. Anyway, I was hoping for some gains and went to local dyno shop. Car was tuned before and after as well. Long story short, I was a little disappointed. Car lost some midrange hp and tq compare to my shorty+Berk hfc setup.
Now I am confused, lol. Its not 1-2 hp, you can see a little more significant drop. Car run about 0.5 psi more then before as well. For the past 2 days I read quite a bit about header designs and all. Its a pretty crazy science. I just thought I will post it here... just some food for thoughts. Its SC... NA motor is the whole different animal and I dont think this grapg can be used.
I am planing to put my CT+Berk back. I also want to open up hfc to 2.75" to match my exhaust. Its not much but might as well. I may take it back to the dyno again since I am not sure if it was a mistake or something. Thought I'll share it here as well since I already posted it in one of sc threads.
mike_si_29 is offline   Reply With Quote
Old 02-24-2012, 10:19 PM   #103 (permalink)
That's pretty crazy stuff right there. Whether you're SC'd or not, that's pretty interesting info. Can I ask if these numbers are STD or SAE corrected?
What kind of cat are you running on the Kidd Racing setup?
Are you sure your BERK HFC is 2.5 at the outlet? Mine is 2.75 at the outlet.
FOURDOORSI is offline   Reply With Quote
Old 02-25-2012, 12:52 PM   #104 (permalink)
I believe these numbers are STD corrected. Its local dyno for mostly mustang guys. It reads a tad lower. I am not too much after numbers but i like to see how diffrent parts affect your power curve. Damm, I need to re-measure my outlet. If its 2.75, its gonna be awesome. I measured quick at Berk shop so it might be wrong. I run 2.5" with krrh... same sell count.
Old 02-25-2012, 09:48 PM   #105 (permalink)
^ Most likely standard numbers, which would mean the air temp would make a difference in the numbers. How close were the air temps on each day? Either way, hot day and cold day wouldn't make that big of a difference, just saying.
I just double check my BERK pipe, it's 2.75" on the outlet. (Sorry for the camera phone pic)
Old 02-26-2012, 01:02 PM   #106 (permalink)
JSA
Great pictures, and nice header!
JSA is offline   Reply With Quote
Old 02-27-2012, 12:15 PM   #107 (permalink)
I checked other graphs last night. It was STP (STD) correction. I wrote temp on my previous graps as well. I believe, previous run was made at 10F higher temperature. I can find exact number. Anyway, I think if its corrcted, temp shouldnt matter. I also checked outlet diameter and its 2.5". Thats wierd, maybe they increased it. Mine was just a test version...
Old 03-16-2012, 01:14 AM   #108 (permalink)
RAWsushiii's Avatar
Yip's 08 FBP FG2
that thing looks sick..
RAWsushiii is offline   Reply With Quote
Old 03-16-2012, 03:54 PM   #109 (permalink)
Kevin
Any updates?
K20Mak is offline   Reply With Quote
Old 03-17-2012, 02:44 AM   #110 (permalink)
pinoystylez's Avatar
that header looks sick!
pinoystylez is offline   Reply With Quote
Old 03-17-2012, 02:37 PM   #111 (permalink)
Ace21's Avatar
i finally read the whole thread. subscribed and hopin to see the dyno results soon...
that header / hfc combo looks like a beast, btw!
Ace21 is offline   Reply With Quote
Old 03-18-2012, 02:53 AM   #112 (permalink)
Eric.'s Avatar
Eric
Originally Posted by blacksnow View Post
Ok I'm a a bit confused. How is this going to be any different then a race header?
Short answer is that the flow will suck in comparison. Running a shorty header and a test pipe instead of a proper longtube header is, frankly, stupid and pointless.
Eric. is offline   Reply With Quote
FP: About to pull the trigger, some noob ?'s... OGMD Hondata 7 06-19-2011 04:24 AM
Pull the trigger or do not pull the trigger? itsmillz Header Discussion 14 04-26-2011 07:03 PM
Ready to pull the trigger on HFP rims but . pfbmgd Ontario 22 03-18-2009 02:55 PM
Help me pull the trigger (WS2 or Vibrant)--> Crusin_w00kie Bolt-Ons And All-Motor 24 07-16-2008 04:48 PM
Should I pull the trigger?? 2 Honda's 4Me Civic SI 44 10-21-2007 12:22 AM
