s2 alpha header and s2 megapower header differences?? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Header Discussion
Old 01-07-2012, 04:19 PM   #1 (permalink)
Guillermo
so the titles says it all whats the difference between both of them other than the price???
woodberry17 is offline
Old 01-07-2012, 04:43 PM   #2 (permalink)
ATL Si's Avatar
Alex
Megapower is better quality, and IIRC one of the runners on the Alpha is a little different
ATL Si is offline   Reply With Quote Quick reply to this message
Old 01-07-2012, 04:47 PM   #3 (permalink)
Guillermo
i figured megapower be better quality i mean its 400 bucks more than the alpha so it better be lol but idk im debating if i should just get the alpha now even thoui heard about some leaking problems with it or wait a few more months to get the megapower
woodberry17 is offline   Reply With Quote Quick reply to this message
Old 01-07-2012, 04:54 PM   #4 (permalink)
White08Si's Avatar
I just got the s2 alpha header, and had no problems at all with it.
White08Si is offline   Reply With Quote Quick reply to this message
Old 01-07-2012, 04:57 PM   #5 (permalink)
Guillermo
did you have to extend your o2 sensor
Old 01-07-2012, 05:01 PM   #6 (permalink)
White08Si's Avatar
yeah but that is very easy to do
Old 01-08-2012, 12:09 AM   #7 (permalink)
Redbone's Avatar
I thought you basically had to do that on every header that deletes the cat?
Redbone is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 12:51 AM   #8 (permalink)
ATL Si's Avatar
Alex
I think that the Skunk2, Go-Power custom (if spec'd appropriately) and the Hytech are the only ones that require that. Correct me if I'm wrong.
Well......the question lies in the longevity of the alpha header, which nobody really knows for sure yet. Because the Megapower is a quality piece, with the exception of one person on here. His cracked.
Old 01-08-2012, 03:30 AM   #9 (permalink)
Guillermo
I think I'm just gonna wait and go with the s2 megapower not 100% sure yet but I'm almost there lol I know if I do my neighbors are going to hate me I mean they already do as it is with my 76mm exhaust
Old 01-08-2012, 09:40 AM   #10 (permalink)
White08Si's Avatar
it will be quieter at lower rpm with the header so they may actually like you, you will probably want to get a rear motor mount to make sure the header doesn't knock anything when the motor moves as well, s2 recommends doing that or injecting the front mount
Old 01-08-2012, 05:34 PM   #11 (permalink)
Guillermo
ohh yeah before i install the header im getting me some boomba motor mounts
Old 01-08-2012, 05:57 PM   #12 (permalink)
tiZZle2.0's Avatar
Just got my megapower, cant wait to install it. Overall quality looks very nice.
tiZZle2.0 is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 06:39 PM   #13 (permalink)
Guillermo
let me know how that goes and what gains u get with it
Old 01-08-2012, 07:17 PM   #14 (permalink)
tiZZle2.0's Avatar
The only gains I will be able to give are those from my butt dyno, I will be pairing it with the Full Race so I am hoping that it really wakes up the motor.
Old 01-08-2012, 07:36 PM   #15 (permalink)
Chuck D's Avatar
Charlie
I was really disappointed with the install of the alpha header. One of the bolt holes wasnt larger enough, or just alittle off center so I had to bore/open the hole alittle. Which isn't really a big deal, but I guess that's what u get for paying a cheap price for a good header(good design).
Sent from my iPhone using Tapatalk
Chuck D is offline   Reply With Quote Quick reply to this message
Old 01-13-2012, 09:04 AM   #16 (permalink)
07_FG_4Dr_S.i.'s Avatar
Jason/NX Junkie
Did the install today with alpha headereverything went ehh , ended up with exhaust leak where the adapter flange from header meets exhaust system , loosened it up put on some exhaust leak silicone tightened it all up and siliconed the outside of the connection everything is gtg now , my o2 sensor didn't reach the first bung hole so I used the defouler as an extension I drilled out the little hole with max bit I had started with half inch hole and made it almost as big as the defouler itself as max as I could go , worked out perfect with a little slack even on the wiring for the o2 sensor , second o2 is disabled with hondata
No need for o2 extension harness
07_FG_4Dr_S.i. is offline   Reply With Quote Quick reply to this message
Old 01-13-2012, 10:51 AM   #17 (permalink)
Chuck D's Avatar
Charlie
I also had issues with the install of the alpha header. The farthest most bolt hole that attaches to the head 9
on the drivers side wasn't big enough so I had to drill it out alittle.
Old 01-15-2012, 09:23 PM   #18 (permalink)
maxxnitro88's Avatar
Greg
Prob a bad idea to have anything interfearing with the primary o2 sensor...
maxxnitro88 is offline   Reply With Quote Quick reply to this message
Old 02-20-2012, 01:20 AM   #19 (permalink)
tookwick4ya's Avatar
Your headers don't determine the sound/loudness, your exhaust does! If you want your neighbors to like you then you just need to get rid of your 76mm exhaust.
tookwick4ya is offline   Reply With Quote Quick reply to this message
Old 02-20-2012, 09:16 AM   #20 (permalink)
Stephen
What you did with the primary O2, where you thought you were being clever? Yeah, take it out of that defouler. Do not interfere with the primary O2's reading at all, it needs to be directly in the exhaust stream.
w00t692 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Skunk2 Alpha Header Now Available! AutoCity-Brad Auto City Imports 33 02-24-2016 06:36 AM
