Old 06-23-2006, 09:08 AM   #1 (permalink)
Marin's Avatar
Damian
SRI cold air.
Okay, i was thinking about this the other day. Obviously the downfall of a short ram is it sucks in hot air. What if you got some dryer ducting and routed it from the shortram inlet down to the same area the cold air intake goes and cut out a hole were the fog light. This would draw cold air from the front of the car to the filter on the shortram? Has anyone thaught of this? Im sure it is worth some kind of a HP gain when the hood is closed. Let me know what you think.
I dont think it would be hard to do because you could make the duct go in the same place the cold air intake is supposed to go.
Marin is offline   Reply With Quote
Old 06-23-2006, 10:11 AM   #2 (permalink)
CNUco2007's Avatar
Eric
why not just buy a CAI?
CNUco2007 is offline   Reply With Quote
Old 06-23-2006, 10:12 AM   #3 (permalink)
brooklynscat69's Avatar
Hence it will be called a cold air intake.
ALso if you wanted to get cold air why not just get a cold air? Anyways if your worried about hydrolock, your still bringing down a tube which will do the same thing anyway.
brooklynscat69 is offline   Reply With Quote
Old 06-23-2006, 10:50 AM   #4 (permalink)
peliROJO's Avatar
Just install a hood scoop. Don't make a cheap version of a CAI.
peliROJO is offline   Reply With Quote
Old 06-23-2006, 10:51 AM   #5 (permalink)
FujiBlueSi's Avatar
Tim
I think what he means is more or a ram air effect. The hose would not be touching the filter directly so it would not create vacuum to draw in water.
On that note, I don't know if it would be effective enough to show a difference. Without the vacuum effect that CAI's have the air will lose velocity by the time it reaches the filter. Since the air is moving slow it will most likely warm up by the time it reaches the filter. It's an interesting idea. Try it an let us know how it works. Worst case scenario, it doesn't increase power. It wouldn't decrease power though so it couldn't hurt to try.
FujiBlueSi is offline   Reply With Quote
Old 06-23-2006, 01:10 PM   #6 (permalink)
Then just nickname your civic , Ricey.
Old 06-23-2006, 01:17 PM   #7 (permalink)
larryd's Avatar
It would give a ram air effect but the main difference between a CAI and SRI is the temperature of the intake charge. Running a scoop or a tube to feed the SRI will not give the same temperature change that a CAI will.
It would not hurt though.
larryd is offline   Reply With Quote
Old 06-24-2006, 01:18 AM   #8 (permalink)
Marin's Avatar
Damian
See, im probably going to just get a cold air intake, i think all the short ram is good for is sound. Have you ever opened your hood after driving for an hour? You cant even touch anything because it will burn your hand. I think without a cold charge you arent getting anywere with a shortram.
Old 06-24-2006, 01:48 AM   #9 (permalink)
its not like your car comes stock with a CAI your getting gains eitheir way. both systems could be used for diffrent applications and setups.
just keeps those puddles in mind if you get a CAI.
chillen420 is offline   Reply With Quote
Old 06-24-2006, 03:31 AM   #10 (permalink)
Deamon's Avatar
Sounds like you should just get a Comptech Ice box if your wanting a cold air type function, minus the hydrolock issue.
Deamon is offline   Reply With Quote
Old 06-24-2006, 09:08 AM   #11 (permalink)
Marin's Avatar
Damian
well you have to think about it this way as well, the only way you are going to suck up a lot of water is if that entire filter is submerged. The filter sits above the rocker line of the car so you would have to be in a big puddle to do a lot of damage, and if your driving through puddles that big then your doing something wrong. Even if a bit of the filter was submerged there isn't enough vacum in the intake to be sucking up water, it would just keep sucking air through the part that isnt in the water. And as far as water getting the the filter driving through small puddles i dont think is a concern because the entire area were the fiilter sits is closed off.
Old 06-24-2006, 10:07 AM   #12 (permalink)
I agree, but maybe some of us just don't want to take our bumper off to gain 7hp. Fujita claims 11hp with their SRI and I don't care if they did it with the hood open or closed. Hydrolock isn't the only concern people have when they are looking at intakes. How about looks, ease of installation, price, sound, and filter access to name a few.
Sam388 is offline   Reply With Quote
Old 06-24-2006, 12:09 PM   #13 (permalink)
Good Point.
Old 06-24-2006, 12:12 PM   #14 (permalink)
All_bets_off's Avatar
Sean
hey! Not all induction hoods are rice...
All_bets_off is offline   Reply With Quote
Old 06-24-2006, 12:15 PM   #15 (permalink)
On a civic, yes. But to each his own.
Old 06-24-2006, 08:49 PM   #16 (permalink)
Marin's Avatar
Damian
i think a lot of people are very worried about hydrolock, inorder to have a sever case of hydrolock the entire filter must be submerged in water, and that would mean your driving in 2 feet of water, who drives in 2 feet of water? The filter on teh cai is in a cavity behind the bumber totally blocked by the bumper, wheel well, and frame. Like i said before, even if half the filter is submerged it's doesnt have enough force to suck up water. Those are just my thaughts, as far as gains from a short ram, i dont think there are any except for sound. The stock air box draws cold air from the fender, if anything there is a more efficient charge in the stock air box system. They do advertise gains of 9hp with the short ram but that is more than likely with an open hood and not a extremely hot engine.
Old 06-24-2006, 08:51 PM   #17 (permalink)
Marin's Avatar
Damian
I dunno, i guess i am just torn between the same things you said, ease of instalation, access to filter, but im still worried about sucking up all that hot air.
Old 06-24-2006, 08:51 PM   #18 (permalink)
Marin's Avatar
Damian
it would be nice to have someone dyno a short ram with the hood closed to see exactly what kind of gains they are capable of.
Old 06-24-2006, 10:08 PM   #19 (permalink)
Umm maybe when it rains alot. And there are puddles you cant go around. It happens everywhere. Even if the fender was protecting it, water can go around thingss. Think about that.
AEM COLD AIR tagman Bolt-Ons And All-Motor 59 07-14-2007 10:03 AM
Cold air/ cat back exhaust 2006SI Mechanical Problems & Technical Chat 7 04-16-2006 07:06 PM
Cold Air intake? Ricanjordan21 Civic SI 4 04-04-2006 04:59 AM
cold air intake install or pic GeorgiaBoy CorSport 10 01-30-2006 08:12 PM
