Old 05-12-2008, 09:43 PM   #1 (permalink)
CivicBeater's Avatar
Eric
Question Wideband and Ultimate
So is it possibly to go out from the ultimate into a a/f guage? OR do I need to purchase a standalone wideband kit?
Eric
CivicBeater is offline
Old 05-13-2008, 09:55 AM   #2 (permalink)
07CivicMD's Avatar
Roger
Eric
Standalone! The E-Manage is not designed to intercept the stock ECU AFR signal.
Monster Dyno Run on HGH
07CivicMD is offline
Old 05-13-2008, 05:37 PM   #3 (permalink)
Eric
well it has too because how are you going to tune? Our stock O2 is a wideband. So it's reading it, however is it possible to output to a guage is what I'm curious of!
Old 05-13-2008, 08:20 PM   #4 (permalink)
enter801's Avatar
You don't have to read the a/f through the software, you can use an external gauge. Tuners will also read exhaust gas temps from external devices as well. Whether you're reading the a/f on a laptop screen or a gauge taped to the laptop screen, what's the difference? You just have to get the readings and adjust according to what you have.
Also, I have to say that I have researched this thoroughly and the stock O2 sensor is not wideband. When I read the voltage on my ODBII it never goes over 1, also indicating narrowband. Widebands have 5 or 6 wires and the stock O2 sensors don't, they have 4. If I'm wrong somebody show me the evidence please because everything I've found points to narrowband.
enter801 is offline
Old 05-13-2008, 08:24 PM   #5 (permalink)
One Goal, One Vision, Win
jrotax101's Avatar
Robert
My MSD Dashhawk reads the AFR's from the stock o2 sensor ( which is a wideband btw) and i get as accurate readings from it, as a dyno.
Currently 10.1:1 at WOT with the comptech SC.
I was 12.7 at 8k WOT N/A with my current mods less the SC
If you would like the proof of the readings, let me know.
jrotax101 is online now
Old 05-13-2008, 09:38 PM   #6 (permalink)
07CivicMD's Avatar
Roger
Thats why you add another bung on your exhaust pipe and go with an external wideband gauge for tuning. If you cut the primary or secondary O2 sensor your stock ECU will code since it's not getting a reading.
Old 05-13-2008, 10:07 PM   #7 (permalink)
Eric
no i'm not talking about patching into stock 02 sensor. I'm saying straight of the ultimate running a guage for a/f. It seems though that i'm going to have to ge a standalone kit to work.
I know you can look at the reading on a laptop however I want to be able to monitor a/f at all times.
Old 05-13-2008, 10:49 PM   #8 (permalink)
soxfan143's Avatar
If you get a standalone wideband, like the AEM that has a 0-5v analog output, the emanage has an input for the wideband so you can set target AFR's and it makes tuning all that more easy and safe. The more I learn about the Emanage Ultimate the more I think it will be just fine for my Daily Driver.
soxfan143 is online now
Wideband A/F Meter enter801 Forced Induction And Nitrous 12 05-30-2008 08:09 PM
wideband k20beast I.C.E., Electrical, Security, & Navigation 2 02-03-2008 11:28 PM
Wideband guage soxfan143 Bolt-Ons And All-Motor 0 01-19-2008 06:41 PM
r18 wideband? el_ben2 Bolt-Ons And All-Motor 1 08-31-2007 11:14 PM
AEM Wideband mc1200s Do It Yourself Articles 1 02-06-2007 10:19 PM
