#21 (permalink) |
Maybe. I am cool with it for now. When/If Hondata comes out I'll worry about it then. I gained 45whp so I am happy for the time being. When/If Hondata releases something I'll be getting larger injectors and moving to 9psi. I am cool with what I have for now though.
#22 (permalink) |
Remember the AJP car at around 8psi had a 106 trap speed, so your not doing to bad.
What is your A/F ? I wonder what would happen with a slightly smaller pully and 2 more psi? would the computer adapt since the tune is already very conservation? what kind of exhaut you running? |
#23 (permalink) |
Dave Matthews Band
![]() Join Date: Jul 2007
Location: “The future is no place to place your better days.”
Owens
Get It Tuned!
07||FB|| FG2 ![]() I failed mah pants, burrito bowl duece meet thread info! Would you like to Turbo your car!? |
#25 (permalink) | |
#26 (permalink) | |
#27 (permalink) |
I just talked to Greg from Redshift and his opinion is the cams couldn't be hurting my numbers. I really do think my dyno reads slightly low. I gained 45whp which is the standard gain. I was shifting slow on purpose ( was having a problem with 4th gear for some reason, seems fine now) and still managed a 14.1 on the stock tires. His opinion was better tires and faster shifting. I am still confused about my trap speeds though. How are NA guys with ~205whp running 100-101 traps when I have a dyno proven 241whp and am only running that. Could drag radials really help that much with trap speed?
Since it is spreads through out this thread let me put everything here: 241whp, 161ft/lbs SC and 197whp, 144ft/lbs NA 14.1 @ 100 with 2.15 60' (shifting slow on purpose) Previous best at same track: 14.7 @ 94 (fastest SI I have seen there and I go every street night) Last edited by nbilyue; 05-13-2008 at 04:53 PM. |
#31 (permalink) |
I can almost promise the only reason my whp is low is the dyno. They probably don't notice a 10hp difference on the 600+ whp racecars this place usually works on. My real question is the one I stated above.
"How are NA guys with ~205whp running 100-101 traps when I have a dyno proven 241whp and am only running that. Could drag radials really help that much with trap speed?" |
| Speed Trap! | xtant21 | Water Cooler | 17 | 10-11-2007 01:17 PM |
| Project Acura RSX Supercharged - from stock to supercharged | &REY | Garage | 0 | 09-26-2007 09:34 AM |
| 1/4 mile trap | jmillz | Autocross & Sanctioned Drag Racing | 20 | 02-07-2007 06:05 PM |
| Trap Shooting | 7AndrewPD | Water Cooler | 12 | 01-19-2007 11:34 AM |
| Find the speed trap.... | blck06si | Water Cooler | 9 | 01-07-2007 12:14 PM |
