#102 (permalink) |
Yea, i know but i just went there to get the engine code number.. there is nothing i can do right now, i will let my tuner know about it and maybe he can help.. i did added some fuel cleaner i figure am not harming nothing by doing so.. ther car has been running great today.. thats why i went out and took some more videos.. i will post the inside car one so you guys can check the speedo jump by 5mph everytime..
#103 (permalink) |
I never said i turbo was perfect, there will always be issues with them specialy running a piggyback system.. but i said a turbo car can be reliable if driven properly, and many are just as reliable as stock.. but right now all R18 owners are having small issues that will be fix overtime.. most of this issues come from the piggyback system.. But i do agree with you on some of this..
#105 (permalink) | |
#106 (permalink) | |
and thanks sbigshot, it has been a while since last time i seen you on here.. |
#108 (permalink) |
I would think a standalone system wouldn't be that hard to make once they make kpro because both the r18 and k20 have the same wiring for the ecu. the boomslang harness for the tsi kit is made for a si. but the question is would there be enough interest to pay $2000 or so on the r18. sure some of us have already spent between 5000-6000 but would you be willing to spend another 2k just for another 20whp?
#110 (permalink) |
This kit blocks the EGR so i find that if u tune the car rich it doesn't seem to drive very well, also you have to tune ur volt coz at high rpms they tend to be a bit high, i had that same problem with the check engine light coming on the highway while i was with my tuner but since he was there he was able to retify it...
#111 (permalink) | |
OP- Welcome to the world of aftermarket turbos and check engine lights. Buy a scanner, it'll save you more time than you'll ever know. |
#112 (permalink) | |
and bobby jayaram said if i have fix this with a gasket? will a gasket fix the engine light? or the F/IC.. |
#114 (permalink) |
Yup, this isn't a gas saver modification. Normal driving should really hurt your gas milage at all. Get on it and you'll notice the difference. You are forcing much more air into the motor than it was taking in while in it's stock configuration. You'll need to add more fuel with the increase in air.
#116 (permalink) | |
#117 (permalink) |
anything more that 200hp/tq and you're looking at a rebuild at lot sooner than you would have to and sub 200hp or at stock. I'd take a guess at 250hp when you start having to rebuild it monthly...but who knows....my friend has a b16 running at 300hp+ on stock internals....don't know how it's stayed together, but it has. but for the new r18 it would be too much wear and tear on the stock internals...6psi and 180hp/185tq would be plenty for me
#119 (permalink) | |
#120 (permalink) |
not an expert here, but i think the gasket would fix it, but that's my personal opinion...
anavrin351, I would be more willing to agree with you since technology has gotten better, but keep in mind the d15 and b16 blocks come from heavier stock, and with the "short block" issues honda has been having I doubt that the R18 could handle 220+hp for an extended period of time. If you don't know about the short block thing, I think there are a few threads of people saying their engine blocks cracked at 30,000miles and needed to be replaced..so I'm skeptical, but if it happens I'll be , amazed and ridiculously happy all at the same timeAnd to the OP props to you to get this kit up and running in record time. Sorry for the slight thread jack |
