Help on tuning Emanage Ultimate for Gready
i am having some big trouble with the E-manage Ultimate and need help with some tuning. my civic is throughing a check engine for knocking sensor and mass air flow. also the Vsa light comes on and shuts of my car when running high boost and i have to coast for 45 seconds before it starts again. so please helpi need someone that tuned the E mange and contact me about some info. or tell me is there any other ECU that will help me out as well because E-manage is not very tunable to tell you the truth. thanks
It is tuneable only if you have bigger injectors.. Our Stock Injectors are 325cc and the one that comes with the GReddy Kit is 370cc.. Basically there is no difference! Get some 550cc Injectors and get a tuned. But if your having all those check engine lights problem, hit me up on pm with your email and I'll email you some maps to correct the issue.
well if you aren't aware... greddy has a new base map for the turbos so all u have to do is take it to a tuner or any shop and upload the base map into your ecu, i was having those problems with my sedan and this new base map got rid of it all, u just cant build boost too well in the higher gears or else it'll through a cel but im still planning on tuning it, but this definetly got me boosting until i get it tuned
Maybe we can compile some maps. Figure out how to tune the emanage.
List Location,mods. Im willing to share my map. I know we would need to be careful due to different locations (alt,ect). I was comparing the base map to my tuned map but If you have more maps to compare against maybe we can get a better understanding. |
#9 (permalink) | |
#13 (permalink) |
Now if you have a catalyst, would recommend 100% to take off, you'll see number increase.
With boost, you dont want all that power to be held back. And yes, make sure to check their software version or else it might not work with your emanage till they update it. Last edited by SpeedDemon; 05-07-2008 at 08:54 PM. |
#15 (permalink) |
On your pm you said you have 550cc injectors correct?
You need to change the injector size on the Emanage Ultimate.. If you already have the software... Import Data from main unit. Than click on that little Blue looking car... Than look for a TAB that say "I/J"... On the bottom of that tab it shows "BEFORE/AFTER Injector Size". Leave the BEFORE at "325" and change the AFTER from "370" to "550"... Click apply and Ok. Now Click on Communication and Export DATA to Main UNIT. Now all your problems are worry FREE If you dont have the software than go to www.modhparts.com than hit me up on PM and I'll give you my phone number to guide you through. Take care! |
#17 (permalink) |
Heres my map. 9.5 psi
Im in Ohio. I have the greddy sp2. and hfc and hks ssqv bov vent to atmos.This is on the 370cc. I don't recommend updating emanage I just want people to be able to compare against this map. Last edited by frydrce; 05-08-2008 at 12:37 PM. |
| Emanage Ultimate Question... | RWLib3 | Forced Induction And Nitrous | 3 | 03-27-2008 08:46 AM |
| Greddy EManage Ultimate for tuning AJP kit? | 06Fg2 | Forced Induction And Nitrous | 50 | 04-22-2007 06:46 PM |
| Greddy emanage ultimate: tune for N/A? | legendman | Forced Induction And Nitrous | 7 | 04-19-2007 08:09 PM |
