Fuel Rail
CorSport Online Store: Honda 'K-Swap' Parts - 92-95 Civic w/ K Swap - GFR105
-Precision CNC machined from 6061T6 billet aluminum 11/16” ( .6875 ) fuel bore for maximum fuel delivery on street or full race alcohol burning engines - -8AN O-ring ( Boss ) ports provide huge flow capability -Utilizes two ( 2 ) 1/8 NPT ( pipe ) ports for fuel pressure gauge or fuel pressure sending unit. Also comes with two ( 2 ) 1/8” NPT plugs -Allows use of stock fuel pressure regulator Comes with stock Banjo fitting adapter and plug for “bolt-on” applications -Optional fittings: - -6 AN fitting Part# GAN100-6 - -8 AN fitting Part# GAN100-8 - -10 AN fitting Part# GAN100-10 Hey guys i need to upgrade my fuel rail as I am installing Nitrous and a digital Fuel Pressure gauge would i be able to use this fuel rail ? Golden Eagle K20 Swap Fuel Rail I bolded out k20 swap because can thise only be used for a swapped motor dont erally understand but this is for my k20z3 let me know what you think guys thanks in advance! eBay Motors: GOLDEN EAGLE FUEL RAIL K-SERIES HONDA ACURA MADE IN USA (item 330224525911 end time May-30-08 13:35:52 PDT) -Precision CNC machined from 6061T6 billet aluminum 11/16” ( .6875 ) fuel bore for maximum fuel delivery on street or full race alcohol burning engines - -8AN O-ring ( Boss ) ports provide huge flow capability -Utilizes two ( 2 ) 1/8 NPT ( pipe ) ports for fuel pressure gauge or fuel pressure sending unit. Also comes with two ( 2 ) 1/8” NPT plugs -Allows use of stock fuel pressure regulator Comes with stock Banjo fitting adapter and plug for “bolt-on” applications ^^think this one il be able to install on my car and be able to use a Fuel pressure gauge , and hook it up to my nitrous ? Do you guys think it would be ok taking fuel out from my fuel rail or should i tap fuel line from thick fuel hose from under the vheicle for nitrous wet kit Last edited by 07_FG_4Dr_S.i.; 04-30-2008 at 06:38 PM. |
once the fuel system is pressurzed it stays pressurized. its a dead end system so taking it from the rail versus taking it from the line before the rail isnt any different. also the golden eafle rail doesnt have a 1/8" port only the b series. i have a bunch of them here most people use the description from the b seres rails whch have a 1/8" port. you can alwaysdrill and tap it for your nitrous fuel supply.
#7 (permalink) | |
Monster Dyno Run on HGH |
| what Fuel rail do | miles10238 | Bolt-Ons And All-Motor | 11 | 01-11-2008 09:22 AM |
| fuel rail upgarde | linda! | Bolt-Ons And All-Motor | 15 | 12-01-2007 09:35 PM |
| What Fuel Rail fits? | WhiteSicivic06 | Bolt-Ons And All-Motor | 33 | 11-05-2007 09:18 PM |
| How to put injectors in fuel rail? | adamhoud | Mechanical Problems & Technical Chat | 8 | 03-18-2007 09:08 PM |
| AEM fuel rail?? | Conrad | Forced Induction And Nitrous | 4 | 08-02-2006 10:18 AM |
