Old 06-10-2008, 12:56 PM   #181 (permalink)
results were fairly good for n/a civics w/ a gain of 15whp
turktech is offline   Reply With Quote
Old 06-10-2008, 02:19 PM   #182 (permalink)
NSPYR's Avatar
Adrian Yeo
That kinda seem a little bit extreme unless they added a aftermarket computer or piggy back EMS and tuned the car. The other problem is when i add the intake manifold i would need to get my car retuned again, and that mean's i have to ask my tuner from Hong Kong to fly over again to tune my car.
NSPYR is offline   Reply With Quote
Old 06-10-2008, 06:20 PM   #183 (permalink)
yea i dont think it wold be worth it...
what do you use to switch from high boost to low boost.. what kinda boost contoller?
Old 06-11-2008, 01:39 PM   #184 (permalink)
NSPYR's Avatar
Adrian Yeo
Profec B boost controller...
Old 06-11-2008, 01:40 PM   #185 (permalink)
NSPYR's Avatar
Adrian Yeo
Some preview pics of my Type R goodies that i will be installing...
My Type R suspension and Brembo Calipers and slotted rotors... :)
Old 06-11-2008, 10:57 PM   #186 (permalink)
NSPYR's Avatar
Adrian Yeo
Actually i was wondering if there are CAMS, Pistons and valves available for our R18 engine ? i was considering doing a engine rebuild to suit the F/I setup i am running. This would be around 1 yr down the track thou... but i was thinking of doing a rebuild of the engine and changing the manifold so i could run more boost, say 1.2 bar would be good i think....
Old 06-12-2008, 03:33 AM   #187 (permalink)
[quote=NSPYR;3027697]Actually i was wondering if there are CAMS, Pistons and valves available for our R18 engine ? QUOTE]
Custom rods (eagle, for example: Eagle Specialty Products, Inc.),
custom pistons: CP Pistons - Products - Custom Pistons
custom BlockGuard - ?
Cams and valves don't needs for turbo engine rebuild...
Vladd is offline   Reply With Quote
Old 06-12-2008, 06:04 AM   #188 (permalink)
where did ya get the brembo rotors :)
Steviephamo is offline   Reply With Quote
Old 06-12-2008, 12:33 PM   #189 (permalink)
NSPYR's Avatar
Adrian Yeo
From a FD2 Type R :) same as the suspension...
Old 06-12-2008, 12:34 PM   #190 (permalink)
NSPYR's Avatar
Adrian Yeo
[quote=Vladd;3029162]
If i was in australia, singapore, japan or america it would be easy to get things custom made, but as im in china it's alot more difficult !!!
Old 06-12-2008, 01:41 PM   #191 (permalink)
dm8m's Avatar
How much did the fd2 front brake kit cost you?I'm planning to upgrade to fd2 oem brake kit but so far they only cost slightly less than the aftermarket one's with 4-pot calipers here in the Philippines. Just wondering how much they cost there.
Any figures of your 1/4 mile ET? Also planning on a TSI turbo kit install. So far browsing the forums, it has good reviews and good performance including yours.
Thanks!
My Civic FD1 '07
Build My City: Derick City - MyMiniCity
dm8m is offline   Reply With Quote
Old 06-12-2008, 10:44 PM   #192 (permalink)
NSPYR's Avatar
Adrian Yeo
Thanks!
My Civic FD1 '07
The FD2 CTR OEM brake kit costed me around 6000 RMB, and they type R suspension costed me also around 6000 RMB. As for my quatermile times i should be in the high 13s now i guess... as someone previously was able to run a very low 14s at stock boost 0.5bar but i am running 0.7bar :)
The TSI kit is pretty good over all, just need a good tuner to tune the car for you that's all !!!
Old 06-14-2008, 01:37 AM   #193 (permalink)
NSPYR's Avatar
Adrian Yeo
Today i will be installing the Type R suspension, I was also wondering if it's possible to move the front brakes to the back and use the type R brembo's up front...
Old 06-14-2008, 01:38 AM   #194 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Toe Knee
that some nice stuff you got there
Originally Posted by SiViC81 View Post
this freaking site damn it...it's like crack!
Old 06-16-2008, 01:24 AM   #195 (permalink)
NSPYR's Avatar
Adrian Yeo
Thanks bro...
car is getting closer and closer to completion...
Old 06-18-2008, 07:31 PM   #196 (permalink)
txgriff's Avatar
Griffin
Anyone who has the tsi kit and it is working for them please help me out!!!
I have a very important question, first off I live in texas which is about 600ft above sea level and I am having an issue with my car stalling once I pop the clutch. Everything else seems to be working just fine but once I drop the clutch the car will stall and die. If I rev the car when not in gear it is a different situation, it will struggle around 400 rpms then climb back up and be fine. i have learned that once I drop the clutch and tap the throttle it will fix this problem but I really don't want to have this issue for the rest of the time that I have this car. Can anyone help, also I have noticed that once I dropped the clutch when I was close to home after driving for a while it dropped the rpms more slowly and had absolutely no issue with stalling, so is it possible that the ecu is figuring this out and fixing it? So anyone who knows how to fix this please let me know asap.
txgriff is offline   Reply With Quote
Old 06-18-2008, 09:14 PM   #197 (permalink)
projectprelude's Avatar
Aaron
^^ have your tuner play with the map/maf voltage this is a problem i had also
projectprelude is offline   Reply With Quote
Old 06-18-2008, 11:31 PM   #198 (permalink)
txgriff's Avatar
Griffin
ya he was messing around with it he was able to make the idle more stable but it still has a stalling issue, but now it seems like it is trying to keep it from getting too low of rpms. But also my car is not fully tuned yet so I can't really get on it yet, so its still a work in progress but I was curious why it is having this problem
Old 06-19-2008, 03:40 AM   #199 (permalink)
NSPYR's Avatar
Adrian Yeo
All you have to do it get a good tuner to fix your problem. If you get your car tuned right you'll have no problems at all... Im running 0.7bar and have no issues :)
Old 06-19-2008, 03:45 AM   #200 (permalink)
NSPYR's Avatar
Adrian Yeo
I am getting my car resprayed and installing a carbon fiber truck and carbon fiber Type R Wing at the back. The CTR suspension is already installed and also the Brembo type R brakes are installed too. Also ordered a new set of 17" rims that will make the car look alot better. I will be losing all the stickers for the time being and see if i like the car as it is, else i'll be putting the stickers back.
The suspension is very good and now there is just a 3 finger gap... I will update with pictures when my car is complete...
TSI R18 Turbo Installed First Update Blackened Sky Forced Induction And Nitrous 968 10-05-2008 11:56 PM
GT35R Turbo Update blueroadster Forced Induction And Nitrous 71 11-28-2007 11:50 AM
Turbo Update: GT-35R blueroadster Forced Induction And Nitrous 170 05-17-2007 08:22 PM
R18 ECU Update XianTi Mechanical Problems & Technical Chat 75 04-02-2007 03:26 PM
turbo update/ forced induction sickyute Forced Induction And Nitrous 26 11-23-2006 10:15 PM
