is b0osted!
Throwing PO107 Map Sensor voltage too low
I just loaded a pre-tuned map on and im throwing a CEL. Scangauge says its PO107 which I looked up and says "map sensor voltage too low" is this dangerous? im kind of confused?
![]() "oh no he dit'en" |
Still having the messed up issues with your interior electronics? Could be related. Floating ground = less voltage differential = no go electronics. I'm not saying that is the likely cause.
The ECM info sticky says 1-3V is the operating range of the MAP signal. Idling is 1V. Not hard to lose 1V due to a bad ground. That'd be the first thing I'd check though I can't confidently say since I can't see your car if my a$$ is sitting in this chair lol |
| Electronic Load Detector (ELD) questions regarding low voltage from battery | bikinpunk | Mechanical Problems & Technical Chat | 6 | 06-25-2008 02:49 PM |
| MAP, psi/bar and voltage | hannson | Civic Coupe And Sedan | 0 | 11-24-2007 09:55 AM |
| Low Voltage on MAF/MAP dtc - car won't start | enter801 | Mechanical Problems & Technical Chat | 1 | 11-06-2007 09:04 PM |
| Coolant Sensor High Voltage | ohiocivicracer | Mechanical Problems & Technical Chat | 6 | 10-25-2007 04:21 PM |
| MAP sensor tuning | hannson | Mechanical Problems & Technical Chat | 0 | 10-15-2007 02:34 AM |
