Old 04-17-2008, 07:27 AM   #1 (permalink)
FatSacSi's Avatar
JSRC Roots Style
Purchased JRSC roots style will be installing next weekend. Will post pics/vids
FatSacSi is offline
Old 04-17-2008, 08:30 AM   #2 (permalink)
ReDHatchyGuy's Avatar
David
whos installing it? you know u need to notch the block oe something to install that
ReDHatchyGuy is offline
Old 04-17-2008, 08:31 AM   #3 (permalink)
Next weekend too far!!! You should resist the urge to post so early as to keep it from getting messy!
habitat is offline
Old 04-17-2008, 11:58 AM   #4 (permalink)
LiL Sang's Avatar
LiL Sang
goodluck!! can't wait until its done..
LiL Sang is offline
Old 04-21-2008, 09:40 PM   #5 (permalink)
FatSacSi's Avatar
Now just to install it
FatSacSi is offline
Old 04-21-2008, 09:43 PM   #6 (permalink)
chugiboi's Avatar
chue hang
if you're installing it yourself then good luck with the mess you'll have to go through, but will be worth it after it's finish though.
here's the installation info, just in case you want some heads up.
http://www.mossmotors.com/graphics/p...ns/989-320.pdf
chugiboi is offline
Old 04-21-2008, 09:45 PM   #7 (permalink)
ChinoiSI's Avatar
D block(Daily Donut)
interesting. cant wait to see what it puts down.
ChinoiSI is offline
Old 04-21-2008, 09:55 PM   #8 (permalink)
8thcivic Sponsor
Dump the manual tensioner and use the stock autotensioner, just figure out the belt size WELL worth it!!!
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 10:13 PM   #9 (permalink)
FatSacSi's Avatar
Yeah I think I will go with the stock tensioner
FatSacSi is offline
Old 04-21-2008, 10:16 PM   #10 (permalink)
LiL Sang's Avatar
LiL Sang
Finally, someone purchased a JSRC!!! Let me know how it goes!
LiL Sang is offline
Old 04-21-2008, 10:18 PM   #11 (permalink)
FatSacSi's Avatar
Rev belt provided with the kit wont work with the stock tensioner?
FatSacSi is offline
Old 04-21-2008, 10:24 PM   #12 (permalink)
MutantCheese's Avatar
'06 Si Coupe NBP Full HFP
in like flynn
MutantCheese is offline
Old 04-21-2008, 11:00 PM   #13 (permalink)
8thcivic Sponsor
I dunno...I would install then string the pulleys and measure the belt size needed..The tensioner included WILL cause belt slip at high rpm's...
BUY MY CIVIC
Highrev1 is offline
Old 04-22-2008, 01:34 AM   #14 (permalink)
TeamValorRacing's Avatar
^not only will it cause a belt slip, but in many cases i have personally witness a belt break...over 6 times on the same damn car. their tensioner is absolute garbage and should be avoided at all costs.
but the charger itself is a good charger.
the vhishu<-sp? on the other hand.............dont even get me started. lol
TeamValorRacing is offline
Old 04-22-2008, 08:24 AM   #15 (permalink)
NIGHTHAWKSI's Avatar
in for results
NIGHTHAWKSI is offline
Old 04-22-2008, 12:21 PM   #16 (permalink)
benmunger's Avatar
I agree the stock tensioner is better but it cant be used with this set up theres just no space for it. (i know there is an RSX that did it though but there was heavy modification necesary.)
benmunger is offline
Old 04-22-2008, 12:23 PM   #17 (permalink)
8thcivic Sponsor
Sure it can...in its stock form.
BUY MY CIVIC
Highrev1 is offline
Old 04-22-2008, 12:31 PM   #18 (permalink)
Toys For TotsMember
John
ewww...that SC is so ugly and worthless.....COMPTECH looks better and has a better ECU Upgrade, no hanging wires.
xxmstajxx is offline
Old 04-22-2008, 12:35 PM   #19 (permalink)
benmunger's Avatar
ohhh... never heard of that... you got a link.
BTW, are you guys still making a SC for the FG SI?
Old 04-22-2008, 12:45 PM   #20 (permalink)
8thcivic Sponsor
63" or 62.5" belt I forget.. Lemme find the info. Its a larger idler pulley that helps with belt wrap.
So this is with the A2 pulley so it would need to be tested for our CP...
Belt = Dayco # 5060620 (6 Rib, 62") $23.49
Crank Pulley = Honda K20A2 part # 13810-PRB-A01 $104.99
Idler Pulley = Dayco "No Slack" 100mm x 30mm part # 89026 $29.96
(Note: When you remove the idler pulley from your stock tensioner you'll use the bearing sleave that your stock idler has in it. Just pop it out and place it in the new one. Don't use the concave dust cap. It's not going to fit and the guy at Napa said the bearings are fine without it.)
This setup is as tight a belt as you'll get where the indicator on the tensioner is aligned perfectly and has zero belt slip
BUY MY CIVIC
Highrev1 is offline
Know Your Roots. (Pics) lxxsilencexxp Introduction & Pictures 61 07-23-2007 06:35 PM
Anyone with JR (Roots) SC? stevenshizzle Forced Induction And Nitrous 18 04-18-2007 04:07 PM
does anyone have the moss old jackson racing roots supercharger of 06 si? crex Forced Induction And Nitrous 10 03-26-2007 09:37 AM
Getting back to my ricer roots... TexasK20Z Inside and Out 112 03-22-2007 08:23 AM
Eaton M62 roots supercharger gearing video sheek360 Forced Induction And Nitrous 15 12-03-2006 12:55 PM
