Old 04-21-2008, 09:29 PM   #161 (permalink)
Ryan
good stuff!!!
d-hardt20 is offline
Old 04-21-2008, 09:45 PM   #162 (permalink)
8thcivic Sponsor
CorSport's Avatar
Very nice.
www.CorSportUSA.com
Performance Aftermarket Parts
Honda Performance, Defined.
CorSport is offline
Old 04-21-2008, 10:10 PM   #163 (permalink)
bwagner31's Avatar
brendan wagner
update the old youtube vids pleeeeaase
i wanna see this bad boy running.
good luck with moving into the new house and everything, but hurry up. i wanna see the 3" pulley
wooooo Complex and boost FTW
bwagner31 is offline
Old 04-21-2008, 10:22 PM   #164 (permalink)
Originally Posted by CorSport View Post
Very nice.
Im down for a Stage X kit after hearing of Complex's success :)
kt411gcn is offline
Old 04-21-2008, 10:46 PM   #165 (permalink)
boca1's Avatar
is it still running a little rough......great numbers...but a littly surprised the trq was that low...i was guessin 200....but oh well, congrats!
boca1 is offline
Old 04-21-2008, 11:10 PM   #166 (permalink)
Toys For TotsMember
John
Complex Ftmfw!!!
xxmstajxx is offline
Old 04-21-2008, 11:14 PM   #167 (permalink)
HONDACARE's Avatar
254whp 167wtq
nice, very nice. what was your a/f up top????
HONDACARE is offline
Old 04-21-2008, 11:15 PM   #168 (permalink)
8thcivic Sponsor
11:1 or so from what I remember
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:16 PM   #169 (permalink)
HONDACARE's Avatar
254whp 167wtq
almost could drop that 3" pulley in with the same map huh? another 1-2 lbs of boost might bring you back to the 12:1 range
Old 04-21-2008, 11:18 PM   #170 (permalink)
silverspoon1996's Avatar
JJ
I know why your boost figures are lower then expected... Im assuming your estimating boost based on the Pully size based on there site.. our cars have the smallest crank pulley for underdriving the accessories.. Bigger crank pulley will get you more boost... I think..
silverspoon1996 is offline
Old 04-21-2008, 11:21 PM   #171 (permalink)
8thcivic Sponsor
OF course he could run a K24 CP with and would probably be at 12psi with his present Blower pulley...
Yes a 3.0 would be 9psi... We run a Z1CP
bp=blower pulley
a2 cp=crank pulley from 02-04 type s
z1 cp=crank pulley from 05-06 type s
bp l l z1 cp
4.0" l 4 PSI
3.8" l 5 PSI
3.4" l 6 PSI
3.2" l 7 PSI
3.0" l 9 PSI
2.8" l 11 PSI
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:22 PM   #172 (permalink)
JJ
I have a K24 cp if hed like....
Old 04-21-2008, 11:29 PM   #173 (permalink)
8thcivic Sponsor
CP change is more difficult than a Blower pulley changer But how much I may want it
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:33 PM   #174 (permalink)
8thcivic Sponsor
Crank Pulley sizing...
5.115" K20A/Z, 5.465" K20A2, 5.98" K24
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:37 PM   #175 (permalink)
HONDACARE's Avatar
254whp 167wtq
i happen to work where k24 crank pulleys are like water
Old 04-21-2008, 11:38 PM   #176 (permalink)
JJ
we can work something out..
Old 04-21-2008, 11:39 PM   #177 (permalink)
8thcivic Sponsor
GImme ALL of them!!!
Ok I ran off topic sorry complex...GREAT NUMBERS!!!
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:39 PM   #178 (permalink)
HONDACARE's Avatar
254whp 167wtq
ima gonna order one tommorow, so i can stare at it untill hondata releases
Old 04-21-2008, 11:44 PM   #179 (permalink)
8thcivic Sponsor
Yeah yeah...HOndata's new tuning solution...Were all waiting...
In the future, the 06+ DBW cars should be able to be tuned by using the OBD2 port. So we should be seeing a USB to OBD2 type of cable available.
Positives:
1) Less hardware to carry around or mount
2) work off factory ecu - good for future smog checks
3) retain traction control..and more.
Negatives: It may not have all the features like Kpro. (Keep in mind that these features are at its current state during our conversation. Things/features may be improved by the time it's released)
1) No extended boost map: usually on an all motor map we have 10 colums to tune with. If we select boosted we get about 3 more. For boosted setups...currently using the first 7 for negative pressure and the last 3 for positive pressure.
2) probably will not have boost control or gear selection features but these are things we could add on separately."
BUY MY CIVIC
Highrev1 is offline
Old 04-21-2008, 11:45 PM   #180 (permalink)
08_tw_si's Avatar
dammmmmnnnn... video please :)!!!!!!!!!!nice numbers.......that us a killer set up
08_tw_si is offline
Tags
complex, comptech, stage 2, stage x, supercharger
Front stage question javig999 I.C.E., Electrical, Security, & Navigation 6 10-18-2007 10:15 AM
Size tubing for Turbo stage 1??? stage 2?? alxwin Forced Induction And Nitrous 4 07-06-2007 01:05 AM
Stage 2 CAMS!!! carter21 Bolt-Ons
