Old 05-06-2008, 05:06 PM   #241 (permalink)
Whocares05050's Avatar
nice #'s
BUILD MY CITY!:http://whocares05050.myminicity.com/sec http://whocares05050.myminicity.com/ind
Originally Posted by 07mugencivic View Post
i need to go poop ...ill be back
Whocares05050 is offline
Old 05-11-2008, 03:48 PM   #242 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
complex. would you recommend that other people try this? what size pulley would you need for 8-9psi of boost?
//Eibach//Ingall's//BuddyClub
//CorSport//K&N//Hawk//Coming Soon... C-T Engineering
Nathen is offline
Old 05-11-2008, 03:52 PM   #243 (permalink)
boca1's Avatar
boca1 is offline
Old 05-11-2008, 04:01 PM   #244 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
after doing some more skimming i have found that at sea level the 3.2 pulley may achieve about 9psi +\- 1psi
Nathen is offline
Old 05-11-2008, 04:15 PM   #245 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
what would the effects be if you dropped the compression with different pistons? do you think the F/IC would be capable of tuning it out? would a 3.0 pulley be good enough to make decent power with the lowered compression? what would a good compression be? 10:1? 8:1?
Nathen is offline
Old 05-11-2008, 04:19 PM   #246 (permalink)
boca1's Avatar
i would not get into that motor yet....just put the 3inch pulley now and tune...should be fine...you live in pretty good weather so you dont have to worry about heat...
boca1 is offline
Old 05-11-2008, 04:21 PM   #247 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
im just worried about the rough idle. plus, im kind of holding off to see what kraftwerks ends up with.
Nathen is offline
Old 05-11-2008, 04:52 PM   #248 (permalink)
LiL Sang's Avatar
LiL Sang
If I were in your shoes, I would just get the smaller pulley and a tune...call it a day! If you're going to go with different set of pistons, get a k24a1 block and build it from there (if you like).
LiL Sang is offline
Old 05-11-2008, 04:53 PM   #249 (permalink)
boca1's Avatar
yup^
as far as the idle goes, there will be a stand alone soon..so just be patient...
boca1 is offline
Old 05-11-2008, 05:22 PM   #250 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
thoughts on k24 with stock compression?
Nathen is offline
Old 05-11-2008, 05:37 PM   #251 (permalink)
boca1's Avatar
thats fine too...but you dont need to buy anything else, unless you need it...your motor is runing strong...so keep that until otherwise
boca1 is offline
Old 05-11-2008, 06:27 PM   #252 (permalink)
jameslewis178's Avatar
there is no need to lower the c/r
jameslewis178 is offline
Old 05-12-2008, 02:33 PM   #253 (permalink)
M.U.R.D.E.R
COMplex's Avatar
Sure why not? If you/anyone is up to it, I don't see why you wouldn't do it. My car is running ok here in Denver @ those power levels. You may have different results based on your area, and your tuner's capabilities.
As for 8-9psi, I'm not sure yet. For me, I'm probably going to need the 3" pulley. For someone at sea level, they may be able to achieve that with the 3.2".
Altitude has noticeable effects on my car, including lower boost than most people.
Your experience at sea level will likely vary. Not necessarily bad, but you shouldn't use my exact setup @ sea level and expect the exact results.
» Supercharged 2006 Honda Civic Si Coupe
» Information/Teaser Video | ROTM | Carbon8mag Feature!
COMplex is offline
Old 05-12-2008, 05:21 PM   #254 (permalink)
boca1's Avatar
where did you get the boomslang harness?
boca1 is offline
Old 05-12-2008, 05:57 PM   #255 (permalink)
perlmeistere8's Avatar
Ben
AEM F/IC Plug and Play Harnesses
perlmeistere8 is offline
Old 05-12-2008, 07:51 PM   #256 (permalink)
LiL Sang's Avatar
LiL Sang
call LHT... I'm pretty sure they will likely to make you a harness. :)
LiL Sang is offline
Old 05-13-2008, 03:20 PM   #257 (permalink)
Neal
It's slightly cheaper at Procivic. It just sucks that the Harness is as much as the F/IC.
nbilyue is offline
Old 05-13-2008, 05:19 PM   #258 (permalink)
boca1's Avatar
yup....
boca1 is offline
Old 05-15-2008, 09:29 PM   #259 (permalink)
why would you drop the c/r? with a supercharger it takes power to make power so there is no need to drop the c/r. now if you were running 15+psi and nitrous then you might drop it to 10.1 but otherwise stock is good.
Old 05-19-2008, 02:57 AM   #260 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
any chance of some video?
Nathen is offline
Tags
complex, comptech, stage 2, stage x, supercharger
