Old 03-31-2008, 03:12 PM   #1 (permalink)
txgriff's Avatar
Griffin
r18 tsi kit installed...somewhat
well as some of you know I was installing my turbo this past weekend on my civic. Everything for the most part worked out fine I took some pictures of several things that might help out some with the install but I will post them later (maybe tomorrow or wednesday). So everything is installed and no leaks are evident BUT there is one little problem. This kit is supposed to have a FIC that is pretuned for the car WELL turns out the FIC that was sent to me is not pretuned whatsoever so basically I'm sitting around waiting for pro civic to get back to me and either send me one that is tuned or send me all the data I need to just tune the one I have. The car will at least run the idle is pretty high and doesnt stay constant, it will also not respond to throttle increase. Although my brother was messing around with the fuel curve a litlle and was able to reach 2000 rpms and we got the bov to discharge and it sounds pretty awesome! I'll let you guys know whats going on when anything new happens
txgriff is offline   Reply With Quote
Old 03-31-2008, 03:13 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
wow that sucks. GL>
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Old 03-31-2008, 03:18 PM   #3 (permalink)
projectprelude's Avatar
Aaron
im working on mine and have to still install the injectors...how did that do for you? can you help me out with a few details or tips of some sort
projectprelude is offline   Reply With Quote
Old 03-31-2008, 03:20 PM   #4 (permalink)
txgriff's Avatar
Griffin
what do you need help with do you have most of the kit on already or are you doing the fuel injectors first?
Old 03-31-2008, 03:23 PM   #5 (permalink)
Aaron
yeah i have most of it on and only other real thing to do is the injectors..havent started them yet...just seein how hard it was and what you did
Old 03-31-2008, 03:36 PM   #6 (permalink)
txgriff's Avatar
Griffin
well first you need to remove the engine cover there are numerous bolts in the front that should be easy enough to see then there are i think 3 or 4 on the backside of it where the fuel injectors are. Then you need to unplug the spark plugs and then you should be able to pull of the cover, but be careful there is a gasket seal that you need to make sure stays intact. So once that is off then there is a fuel injector cover which you should be able to just pull off then the fuel rod is held in by 2 screws just remove those and you should be able to pull them out. So now comes the fun part I hope you have a soldering iron because the new injectors dont just simply clip in place of the old ones. So you should of gotten some wires that I believe are yellow and you should have gotten 10 of them but of course you only need 8 of them since you use 2 for each injector. So you just have to wire them up yourself since they don't just clip in place, also you dont need to use the gray adapter pieces that they give you for the injectors these actually clip in place but you still have to solder and also you have to push the wire all the way through to make them work. I might be able to get some pictures up but Im stuck at my brothers house and I might have to wait until he gets home before I can do that. Sorry if this confuses you Im trying to explain as best as I can remember
Old 03-31-2008, 03:36 PM   #7 (permalink)
caveman74's Avatar
Kevin
Thats good you R18 guys actually get something good. Hope everything works out. Seems like its always the Si gets the parts.
caveman74 is offline   Reply With Quote
Old 03-31-2008, 03:49 PM   #8 (permalink)
Aaron
yeah i knew that i was ganna have to solder the wires...but yeah thatd be sweet if you could get some pictures
Old 03-31-2008, 03:59 PM   #9 (permalink)
txgriff's Avatar
Griffin
well we took some I think we took some of the overall look of the injectors not of any individual ones. But I can post some later tonight
Old 03-31-2008, 04:18 PM   #10 (permalink)
8thcivic Sponsor
PRO Civic's Avatar
I just found out it is possible to email the MAP file. We will do this in just a bit. Just remember that you do first need to upgrade the AEM unit to v2.01. You can download the AEM software at:
F/IC SOFTWARE v2.01, NEW FEATURES ADDED, UEGO GAUGE DISPLAY
We apologize for this happening. I just spoke with TSI and they don't know why this happened either, but our best guess is someone had a stack of F/IC they were reflashing and just skipped over one. Luckily, it is easy to correct.
Honda Civic Parts Specialists
PRO Civic.com
PRO Civic is offline   Reply With Quote
Old 03-31-2008, 04:26 PM   #11 (permalink)
KEVtec's Avatar
subscribed.
KEVtec is offline   Reply With Quote
Old 03-31-2008, 04:31 PM   #12 (permalink)
txgriff's Avatar
Griffin
sweet thats good to hear thats kind of what I figured that someone just forgot mine and I actually have a higher version its 3.06 I think we found it on the AEM forums last night which Im assuming will work fine.
Old 03-31-2008, 04:40 PM   #13 (permalink)
I Vtec, do you?'s Avatar
Vids! I'm pumped to see this in action lol
I Vtec, do you? is offline   Reply With Quote
Old 03-31-2008, 05:48 PM   #14 (permalink)
8thcivic Sponsor
PRO Civic's Avatar
The higher version SHOULD work fine, but if it does not then do the 2.01 version.
PRO Civic.com
Old 03-31-2008, 08:22 PM   #15 (permalink)
Civic Pride's Avatar
I can't wait to see someone elses car in action besides the procivic video, i will make sure to hit the dyno with my aftermarket exhaust if no one has done it by the time i get my turbo install. i will be taking it to the shop on april the 23rd and should be ready in 2 to 3 days.
BTW am thinking of just boosting 8psi instead of the 6/7 the kit comes pretune for, has anyone else thought about doing that?
Civic Pride is online now   Reply With Quote
Old 03-31-2008, 10:29 PM   #16 (permalink)
Kurt's Avatar
I have
Kurt is offline   Reply With Quote
Old 03-31-2008, 11:07 PM   #17 (permalink)
bs101's Avatar
o you guis...
Don't blow 'em right away, I don't want to be seeing either of you posting in a thread w/ a title like "civic _x k20/4 swap"
bs101 is offline   Reply With Quote
Old 03-31-2008, 11:11 PM   #18 (permalink)
Originally Posted by bs101 View Post
o you guis...
8psi should still be realiable, is not like we are boosting 12psi lol, am sure the d17 engine handle that much boost reiably on stock engine.
Am going to see what bumbers is pushing on the 6psi of boost it comes pretune for, and if i don't like the numbers i see i will up the boost to 8psi.
the ajp kit comes pretune for 8psi on a stock engine, so am sure it can handle it in a reliable way.
Old 03-31-2008, 11:15 PM   #19 (permalink)
Kurt's Avatar
8 pounds will be fine. My buddy with a D16 in a 91 hatch is boosting his next week and will be running 8 pounds on a T3/T4
Old 03-31-2008, 11:24 PM   #20 (permalink)
Derek
friend blew his older d16 at 12 with stock internals.
KameraBoy is offline   Reply With Quote
TSI R18 Turbo Installed First Update Blackened Sky Forced Induction And Nitrous 968 10-05-2008 11:56 PM
Help Tuning 07 SI W/ TSI kit TotalPower Forced Induction And Nitrous 30 11-16-2007 09:35 AM
tsi turbo kit micyj30 Forced Induction And Nitrous 25 11-14-2007 12:41 PM
tsi extreme turbo kit question... se7engen_ride Forced Induction And Nitrous 2 10-14-2007 05:35 AM
