Old 06-26-2008, 11:39 PM   #141 (permalink)
nelsonr31's Avatar
Mike, this is what I was talking to you before about ^. My tuner thru in a 3Bar Map sensor with harness when he tuned my car.
nelsonr31 is offline   Reply With Quote
Old 06-26-2008, 11:45 PM   #142 (permalink)
Civicn33b's Avatar
Josh
http://www.8thcivic.com/forums/parti...much-more.html
selling my complete kit with extra turbo goodies too.... wayyyy below the marked up greddy prices
Civicn33b is offline   Reply With Quote
Old 06-27-2008, 01:35 AM   #143 (permalink)
[quote=escocrx;3122928]the pressure sensor can either be hardwired, or you can purchase the wiring harness which is plug n play with connectors on both ends no cutting. etc.
heres the sensor.
heres the harness.
heres. the unit.
i'll try to find better pictures. but the white wire is far left if looking at the unit like the picture. hehe not much help huh.
QUOTE]
Sweet, so this pressure sensor works along with the stock one as well? Is it a must when boosting more than 8 psi?
encrypted03 is offline   Reply With Quote
Old 06-27-2008, 01:47 AM   #144 (permalink)
soxfan143's Avatar
It's for boosting more than 12 psi. You can boost up to 12 psi on the stock sensor from what I've bee told. But it's good because the emanage can be tuned through the pressure sensor instead of throttle position. So you get a more presice fuel delivery. I would assume.
soxfan143 is offline   Reply With Quote
Old 06-28-2008, 11:16 AM   #145 (permalink)
PhantomSi's Avatar
WHOdata
I'm in the middle of my install and I don't know where to route the emanage harness. Can someone enlighten me? Thanks.
Never mind, I finally found the hole and got it done.
PhantomSi is offline   Reply With Quote
Old 07-01-2008, 08:14 PM   #146 (permalink)
escocrx's Avatar
anyone got the pin out diagram for the emanage ultimate for our car?
trying to wire in my hks evc to the throttle and rpm sig but i rather grab it at the EMU instead of getting it from the stock ECM.
the PEM thread that had the pinouts is pretty much dead since blueroadster left....
escocrx is offline   Reply With Quote
Old 07-03-2008, 03:26 PM   #147 (permalink)
www.yospeed.com
Celcius's Avatar
David Yonehara
Originally Posted by nelsonr31 View Post
I just got a set of NGK iridium plugs (1 step colder I believe, please let me know if they're not) BKR8EIX, now my question is should I be gapping these? unsure because I have always heard you're not suppose to gap iridium plugs. If I have to gap them what should I be gapping them to?
Looked through the thread and no one answered this. Can anyone chime in here please?
Celcius is offline   Reply With Quote
Old 07-03-2008, 06:23 PM   #148 (permalink)
nelsonr31's Avatar
I emailed NGK about this question and they told me that yes the plugs I have are 1 step colder then OEM, they said these plugs are already gapped(0.32)so there would be no need to regap them but they did say that iridium plugs can be gapped. There's a specific tool used to gap iridium plugs so that you do not damage the electrode of the plug. So to answer this question yes you can gap iridium plugs and you won't have to gap these plugs because they are already pregapped, I'm running them right now with my greddy turbo and don't have any problems.
Here's the reply from NGK
Hello, The BKR8EIX is the correct one heat range colder plug for thisapplication. The plug will be factory set to .032". If the gap needs tobe adjusted you can do so on the iridium plugs you just have to be surenot to apply any pressure or force to the fine wire center electrode asit can be damaged. The gap should be adjusted by pulling or pushing onlyby the ground electrode. Hope this helps, thank you. Best regards, Brandon Peeler Technical Support Representative Aftermarket Division NGK Spark Plugs (U.S.A.), INC. 46929 Magellan Dr. Wixom, MI 48393 Bpeeler@ngksparkplugs.com
Here's a picture of how to gap iridium plugs.
Hope this helps you out.
Old 07-03-2008, 11:01 PM   #149 (permalink)
St Jude
06si's Avatar
Kenny G
Will I be able to use my Greddy EVO2 exhaust or will that really effect the hp output of the kit?
06si is offline   Reply With Quote
Old 07-03-2008, 11:22 PM   #150 (permalink)
nelsonr31's Avatar
You'll deffinitly be able to use your greddy exhaust but a 3" exhaust with a cat delete test pipe will yeild more power.
Old 07-04-2008, 04:28 PM   #151 (permalink)
soxfan143's Avatar
The GReddy exhaust will be leaps and bounds better than the stock pea shooter I'm running now. Whatever you do don't use the stock exhaust. It's awful for boost. Anything over 4500 rpms, you will loose about 2-3 psi from it. I'm still waiting for my Skunk2 70mm. UPS is a bunch of lying dicks!!!! Hehe.....
Old 07-06-2008, 12:34 PM   #152 (permalink)
FlatlineSi28's Avatar
Matt
how many hours is his install on average
FlatlineSi28 is offline   Reply With Quote
Old 07-06-2008, 12:37 PM   #153 (permalink)
soxfan143's Avatar
Where do you plan on doing it? Do you have a lift and professional tools? Or are you doing it on jackstands in your driveway?
Old 07-06-2008, 12:40 PM   #154 (permalink)
Matt
jackstands in a driveway with my father who was a mechanic for 20 years.. but very little experience with turbos i have all professional tools
Old 07-06-2008, 12:50 PM   #155 (permalink)
soxfan143's Avatar
Expect 2 days eat least. I'm currently a ASE master tech and I had a lift and all my tools at my shop and it still took me about a day and a half. Getting the turbo between the firewall and the valve cover was a serious PITA. And running the PnP harness was even worse. Also do not forget to wrap up your harness and brake lines and the fuel line where the turbo sits. They will melt fatsr than you can say boost.
It's pretty straight forward though. it's the little stuff that makes it take a while. Like wrapping the harnesses and wiring in the guages and stuff.
Another tip is with the bottom manifold studs that GREddy tells you to put in. I would just reuse the factory bolts wherever possible. The nuts that GReddy supplies kept loosening up on me and just falling off. I had to double nut all the bottom nuts on mt exhaust manifold. I also used some loctite after vthey fell off the second time. The top ones stay on fine because theyare the stock nuts with the teeth on the bottom of the nut. If you can get 3 of the stock style intake manifold nuts from Honda use those. it will save you the headache of an exhaust leak from the manifold. And not knowing where it's coming from because you figure it can't be the manifold because you tourqued it to specs, twice!!! Good luck and if you have any questions just PM me. And have fun bro....
Old 07-06-2008, 01:27 PM   #156 (permalink)
Matt
yeah we shall see.. i have an fa5 also... i have the kit in my garage and i just wanted to get more info on it... ne problems i should beaware or b/c i have the fa5?
Old 07-06-2008, 02:15 PM   #157 (permalink)
PhantomSi's Avatar
WHOdata
I had mine done in a driveway with jackstands and professional tools also. I had two Nissan techs with performance shop experience (Fabbing and installing Turbo kits) do mine. We were originally gonna have it done at the dealership they worked at but we got kicked out. So it ended up taking us a full day (8 AM -10 PM) at the guys house.
Having your dad with you is a big plus but expect it to take a bit longer if you guys have no turbo experience.
Old 07-06-2008, 02:26 PM   #158 (permalink)
Matt
yeah it defiantely is a plus.. thanks for ur info.. its making em want to go do it now lol
Old 07-09-2008, 02:39 AM   #159 (permalink)
GalaxyGreySi's Avatar
Phil
took me about 12 hours total, spread out over 3 days, with plenty of bud light, sandwiches, and smoke breaks
If you must whine about my Avatar, do it in this thread:
http://www.8thcivic.com/forums/showthread.php?t=35167
GalaxyGreySi is offline   Reply With Quote
Old 07-09-2008, 02:43 AM   #160 (permalink)
Phil
P.S. never was I without my car. You can install the heat wrap, harness, injectors and e-manage without the turbo being installed, mind you.
Greddy Turbo Kit CorSport CorSport 146 11-12-2008 11:41 AM
Had to Rebuild My GReddy Turbo - A Tale of Precaution for Greddy Kit Owners enter801 Forced Induction And Nitrous 77 10-31-2008 08:33 AM
Greddy Turbo Kit, Im in it.. LoverOfCivics Forced Induction And Nitrous 3 05-02-2007 10:48 PM
GReddy Turbo Kit? HoustonSi06 Civic SI 4 03-22-2007 01:10 PM
