Old 05-23-2008, 08:13 PM   #101 (permalink)
soxfan143's Avatar
Haha. You're sooo right about the dyno numbers. I actually haven't even really seen any dyno talk on this side of the site. It's awesome. Everyone is happy and helpful. It's awesome. No arguing about dyno numbers and which intake is better. I actually want to come on here now and hang out. I was getting so tired of all the attacks on people and the misinformation be spread. It was geting rediculous. But now it's great. I just can't wait to be boosting. Only 25 more days and counting. YAY!! Hey, I gotta go so I'll talk to you later bro.
soxfan143 is offline   Reply With Quote
Old 05-27-2008, 02:26 PM   #102 (permalink)
ricerocket110's Avatar
Thanks for the info. I guess I will be getting mine in a month or two...Now I just gotta find a good shop to go to in Sacramento, CA since Motorsport Dynamics closed =(
ricerocket110 is offline   Reply With Quote
Old 05-31-2008, 08:29 PM   #103 (permalink)
GalaxyGreySi's Avatar
Phil
Originally Posted by PhantomSi View Post
I think that the recommended spark plugs should be updated.
It says: 6. Spark plugs that are 1 heat range colder than stock. Personally, I recommend NGK brand plugs, part number BKR7E-11, gapped to 0.030".
according to other threads, those are actually stock heat range. The ones that are one step colder are BKR8E.
I actually went out already and bought the BKR7E-11 spark plugs. i guess i gotta go exchange them.
Good catch. Fixed.
If you must whine about my Avatar, do it in this thread:
http://www.8thcivic.com/forums/showthread.php?t=35167
GalaxyGreySi is offline   Reply With Quote
Old 06-05-2008, 11:40 AM   #104 (permalink)
a1j7g's Avatar
Andy
Will the Greddy kit past Emissions?
a1j7g is offline   Reply With Quote
Old 06-05-2008, 05:39 PM   #105 (permalink)
soxfan143's Avatar
It depends on where you are. If it has a cat and there is no check engine light you should be fine. Some states don't allow open element filters though so I would check it out. I'm pretty sure it would pass in MA.
Old 06-14-2008, 05:29 PM   #106 (permalink)
nelsonr31's Avatar
I have a installation tip that saves you from lowering the subframe to get the OEM exhaust manifold out and removing the valve cover to get the Turbo in. Unfortunately I don't have any pics but I'll do my best to describe it.
1- There's no need to lower the subframe to get the OEM exhaust manifold out. Just unbolt the bracket that holds the shift cables and unbolt the bracket that holds the first O2 sensor wire. Doing this frees up enough space to wiggle the OEM exhaust manifold out, trust me this is how I got my manifold out.
2- There's no need to remove the valve cover to get the turbo in. Since you have to remove the trim where the windsheild washer jets are and the metal plate underneath it to change spark plugs, I suggest doing this right away before you start your install. Doing this frees up a considerable amount of space to get your hands to the back of the enigine bay for heat wraping and etc. The trim has 3 external clips to remove then carfully pry it up and away, don't forget to disconnect the windsheild washer hose. The metal plate has a total of 7 bolts all in sizes of 10mm & 12mm which are plainly visible. Once this is removed, installing the turbo from the right hand side carefully moving some of the hose's and wire harness' is a peice of cake. This is how I got my turbo in and it seemed to be the easyiest way.
Hope this help out with your future install.
nelsonr31 is offline   Reply With Quote
Old 06-14-2008, 09:24 PM   #107 (permalink)
soxfan143's Avatar
How bad is it to run the stock temperature ranged plugs for a day or so with this kit? My plugs won't be here till wednesday and I have to do my install on tuesday because of work schedule. I can only use my shop tuesday night. Will it hurt it by running them for a night to drive it home and back to the shop? I wish they would just come then so I wouldn't have to remove the damn cowl again!!
Old 06-16-2008, 07:42 PM   #108 (permalink)
escocrx's Avatar
i ran the stock plugs for a couple days. got on her pretty hard too. just dont boost if your worried about it, its not hard to granny drive.
escocrx is offline   Reply With Quote
Old 06-17-2008, 08:30 PM   #109 (permalink)
Phil
Stock plugs should be fine for a while, just change 'em out when you can. You're not gonna blow it up.
Old 06-17-2008, 10:23 PM   #110 (permalink)
PhantomSi's Avatar
WHOdata
What plugs are you going to be running?
Sorry for the threadjack.
PhantomSi is offline   Reply With Quote
Old 06-17-2008, 10:57 PM   #111 (permalink)
soxfan143's Avatar
The NGK BK8EIX's or something like that. I can't remember the exact number but it's the ones with the 8 in the part number. Our cars run the ones with the 7 in the part number.
Old 06-18-2008, 01:56 AM   #112 (permalink)
EK=FTW
bear.914's Avatar
BEAR
i got the best ? why did the greddy kit go up nearly 900.00 ????
check corsports site.
bear.914 is offline   Reply With Quote
Old 06-18-2008, 10:50 PM   #113 (permalink)
soxfan143's Avatar
They went up accross the board on everything they sell. I just bought a used kit from a kid that works at GReddy's New Jersey location and he told me about this a few weeks before it even happened. I think he said it's from the rising shipping costs accross the board. Pretty crappy huh? It's from oil prices. This is what happens. But I can say, the GReddy kit is awesome for the money. A bitch to install but well worth the aggravation. It took me alittle over 10 hrs to install everything. From the kit to all the guages. The Emanage harness and the turbo itself were the hardest part. But I would recommend this kit to whoever can swing it. Well worth it. I love it.
Old 06-24-2008, 12:15 PM   #114 (permalink)
Seven
So if I wanted to keep foglights on a SI coupe I can, just not on a sedan correct?
Ridezx6r is offline   Reply With Quote
Old 06-24-2008, 08:43 PM   #115 (permalink)
escocrx's Avatar
not sure for the sedan. but i have a coupe and foglights wit the kit. no problems.
Old 06-24-2008, 08:50 PM   #116 (permalink)
soxfan143's Avatar
I'm pretty sure the factory style fogs will not fit with GReddy intercooler behind bumper. I had to do alot of trimming of the bumper just to get it to fit right without fog lights.
Old 06-24-2008, 08:57 PM   #117 (permalink)
escocrx's Avatar
i have oem honda fogs. no trimming needed.
Old 06-24-2008, 09:53 PM   #118 (permalink)
soxfan143's Avatar
OOps. I meant to put for the sedan....My bad..
Old 06-24-2008, 10:02 PM   #119 (permalink)
Wuddup's Avatar
A lot of people say get the Greddy turbo and just build it up. My question is, how can we build our kits up, but still be safe on our motors. And how much of a whp increase are we looking at?
Wuddup is offline   Reply With Quote
Old 06-25-2008, 02:10 AM   #120 (permalink)
I have a quick question about the orifice, what is it supposed to do exactly?
encrypted03 is offline   Reply With Quote
Greddy Turbo Kit CorSport CorSport 146 11-12-2008 11:41 AM
Had to Rebuild My GReddy Turbo - A Tale of Precaution for Greddy Kit Owners enter801 Forced Induction And Nitrous 77 10-31-2008 08:33 AM
Greddy Turbo Kit, Im in it.. LoverOfCivics Forced Induction And Nitrous 3 05-02-2007 10:48 PM
GReddy Turbo Kit? HoustonSi06 Civic SI 4 03-22-2007 01:10 PM
