#21 (permalink) |
The sub-par return line has nothing to do with a catch can. The Go fast bits BOV is a pretty neat idea. I have also heard that the GReddy BOVs are garbage.
If you must whine about my Avatar, do it in this thread: http://www.8thcivic.com/forums/showthread.php?t=35167 |
#24 (permalink) |
You can change parameters on GReddy's E-Manage. The maps can be tinkered with. And no, the oil capacity does not change enough to worry about.
#26 (permalink) |
I have had my setup for 5,000 miles now, and about 8 months. I have had only minor problems here and there, nothing to blame on the kit. I would add it, but I don't see how one person's experience positive or negative is relevant or indicative of the kit's reliability. It's all in the tune
#27 (permalink) |
Being that the nearest shop to me with an actual wheel dyno is about 3+ hours away. Would it be advised to stay away from this kit because of the base map? I remember reading it's not the greatest/safest setup and is meant to just get you to a tuner.
#28 (permalink) |
That is up to you to decide. With a full 3" exhaust, I was running as lean as 15:1 on WOT above 4000 rpm. The base GReddy map is meant for an otherwise stock vehicle. In GReddy's opinion, however, it does not need to be tuned.
#29 (permalink) | |
#30 (permalink) |
My guess, djpreview, is that they offer different sizes to fit cars and turbo kits that already have a fitting to plumb a recirculation fitting into already. Since you would have to weld a fitting onto the intake pipe to recirculate back into, you would choose a size that is the same as the fitting you are planning to weld on. So the answer is, it depends.
#31 (permalink) | |
#32 (permalink) |
No. The fittings that I think you are talking about are for crank case vapors. You keep those in place (or put an oil catch can in the loop - blueroadster knows a little more about this than I do). You would need to add an additional fitting on to the intake pipe to connect the BOV recirculation fitting to, probably with a rubber hose. There are a few members on here running a recirc. type setup - I don't know who though. Here is a pic from google showing what I mean on a Nissan though, you can get the general idea - see how the BOV shoots right back into the intake?
#34 (permalink) | |
thank bro! |
#36 (permalink) |
what type of spark plugs are u running? I just did the install and running the stock plugs until my 1 and 2 step colder plugs come in tomorrow. but it seems like it runs great as is. I ordered some NGK BKR8EIX and BKR9EIX. any plugs recommended?
with the plugin play harness. how in the world do you get the ECM to mount properly. i have mine just laying in the general area right now. I have tried bending it in every which way. anyone have wild engine jolts? if i gun it, and shift my engine or whatever some part of it(mani/turbine/etc) will hit the body somewhere, haven't figured it out yet. the white plastic T, in the kit. part #29 I assume is the boost gauge tap? is there a recommended location for this? |
#38 (permalink) |
I run the Innovate XD16/LC1 kit.
Innovate Motor Sports On-Line Store It's nice, programmable and I believe it can do datalogging. |
#40 (permalink) | |
1. Recommended plugs are mentioned in the FAQ. 2. To get the factory computer back in place, I put the bolts in while TWO of my friends held the thing in place. It is not easy. 3. I used to get the jolts that you are speaking of. I know what you mean EXACTLY. They went away as soon as I installed the Ingalls Stiffy engine damper. Fixes a lot of things, highly recommened. 4. The T - fitting... I don't know what that was for. I didn't use it.
| Greddy Turbo Kit | CorSport | CorSport | 146 | 11-12-2008 11:41 AM |
| Had to Rebuild My GReddy Turbo - A Tale of Precaution for Greddy Kit Owners | enter801 | Forced Induction And Nitrous | 77 | 10-31-2008 08:33 AM |
| Greddy Turbo Kit, Im in it.. | LoverOfCivics | Forced Induction And Nitrous | 3 | 05-02-2007 10:48 PM |
| GReddy Turbo Kit? | HoustonSi06 | Civic SI | 4 | 03-22-2007 01:10 PM |
