Old 06-02-2006, 02:07 PM   #1 (permalink)
BLU BY U's Avatar
Cool 11:1 compression + nitrous?
How would a high compression motor like the si's respond to a 50 shot of nitrous? I was under the impression that high comp motors love nitrous.
talk to me.
Old 06-02-2006, 02:27 PM   #2 (permalink)
could probably go all day long on just a 50 shot...
Conrad is offline   Reply With Quote
Old 06-02-2006, 03:49 PM   #3 (permalink)
larryd's Avatar
I ran a 50 shot on my Celica GT-S which was 11.5:1 compression and it ran fine.
larryd is offline   Reply With Quote
Old 06-03-2006, 12:29 AM   #4 (permalink)
Compression has nothing to do with nitrous from what I've been told. Asked the question "will 11:1 compression be bad with nitrous" answer "compression has nothing to do with running nitrous"
Nafunu32 is offline   Reply With Quote
Old 06-03-2006, 07:47 AM   #5 (permalink)
BLU BY U's Avatar
Thanks for the answer, i wasn;t sure how compression affected nitrous or vice versa.
Old 06-03-2006, 08:21 AM   #6 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
well compression does have an effect on the safety of nitrous. Nitrous is a power adder just like a turbo or supercharger. In an engine that already runs higher compression it can get dangerous to run high power adders without beffing up the internals of the engine. With a 50 shot you won't have to worry, but if you start going bigger you will at least need to get some kind of fuel management system to make sure your car doesn't start going dangerously lean. Honda blocks are alot stouter than most people want to admit so up to about a 150 won't hurt you as long as you can keep enough fuel in there. Just like a turbo running 10psi won't hurt you as long as you keep enough fuel in going to the motor. Hope this helps.
jed = hermaphrodite
Old 06-03-2006, 08:50 PM   #7 (permalink)
Right... but a 9:1 compression honda motor will blow on a 75 shot as easily as a 11:1... thats what a well known performance shop told me.
Old 06-04-2006, 12:33 AM   #8 (permalink)
Tuna Fiddle™
Dave
well no stock honda motor made in the last 10years will blow on a 75 shot whether it had 11:1 or 5:1 compression. And I'm pretty sure they are mistaken, but i will back up my argument when i find an old article i have about nitrous.
jed = hermaphrodite
Old 06-04-2006, 12:58 AM   #9 (permalink)
Tikolx333's Avatar
How does this apply to the R18?
Tikolx333 is offline   Reply With Quote
Old 06-04-2006, 01:36 AM   #10 (permalink)
You totally missed my point... I was proving that compression will not affect the nitrous.
Old 06-04-2006, 02:10 AM   #11 (permalink)
Tuna Fiddle™
Dave
here is some info I found with some FAQs about nitrous. http://www.nitrousdirect.com/faq.html
I'll highlight the ones i feel pertain to this thread.
6. Can I use Nitrous Oxide on a stock engine?
A: Yes. The most important aspect is not to overindulge. Choosing the correct kit for any given application is essential; a good rule of thumb to follow is never exceed 50% power increase to your current engine output.
9. Does nitrous oxide cause detonation?
A: Not directly. Detonation can be the result of many things, such as a lean condition caused by not adding enough fuel, too low of an octane of fuel, and too much ignition advance.
15. Can you apply Nitrous Oxide to high compression engines?
A: Absolutely. High compression ratios work well with nitrous oxide provided the proper balance of nitrous and fuel enrichment is maintained. Generally, the higher the compression ratio, the more ignition retard, as well as higher octane fuel, is required.
So there is a difference running nitrous on a high compression engine vs. a lower compression engine.
jed = hermaphrodite
Old 06-04-2006, 09:29 AM   #12 (permalink)
BLU BY U's Avatar
see i knew it would be sifferent, sounds like you could get a lean condition easier.
Old 06-09-2006, 03:31 AM   #13 (permalink)
you could go lean alot easier, notice it said retard igniton and higher octane fuel. All nitrous is, in a simplistic way, is super consentrated oxygen. the more o2 in your cylinders, the higer the compression. too much and it will blow just like over boosting a turbo car. In that sense high compression may not be ideal for larger shots of nitorus where too much ignition timing has to be pulled or fuel has reached its limit. In terms of smaller,50-75 shots, I think you'd be good to go
Rocklobsta1109 is offline   Reply With Quote
Nitrous For 1.8L Tikolx333 Forced Induction And Nitrous 35 05-12-2006 08:34 AM
Nitrous For FG2 Already?! SpeedDemon Civic SI 7 04-12-2006 01:09 PM
Anyone tried nitrous yet? bradvb Forced Induction And Nitrous 12 04-06-2006 10:23 PM
