#827 (permalink) | |
#828 (permalink) | |
#829 (permalink) | |
#830 (permalink) | |
If both these are checked reset your ECU and reconnect ...you should be good to go |
#831 (permalink) | |
now the radiator fan doesn't seem to come on at 93 degrees when it is supposed to... no check engine lights or anything when i turn the aircon on however i don't have this problem !!! Any idea about this issue ??? |
#832 (permalink) |
water temp sensor died? That's what kick on the fans. But running your a/c will decrease your numbers by a good 10 whp. Or perhaps something got unplugged when installing the turbo and FIC. Did you say it works without the boomslang harness connected?
#835 (permalink) | |
Regarding the radiator fan just check whether you have some connectors unplugged or not connected properly. If everything is ok then you could take a look at pin no 23 on the grey connector which is the ECT sensor and also take a look at pin nos 4 and 5 on the white connector which again goes thru the boomslang to the main harness. The pins on the boomslang need to be handled with a lot of care and possibly you might have something that has come off. |
#836 (permalink) |
another R18 running:)
got mine back from the shop today got it tuned for 7 PSI runs very very well ill get vids and pics up early saturday, taking it to the 1/4 mile friday at 7pm est. wish me luck:) it wasn't easy said my tuner but he got the job done, he completed it on the 3rd F IC unit and the 2nd wiring harness some numbers if your having troubles. TS- 562 403 7039( FIC) Boomsland- 573 635 6656 ( Wiring harness) aim for me is : huthuthut07 if u have problems Last edited by civicinpa; 05-21-2008 at 08:20 PM. |
