Old 02-25-2008, 05:19 PM   #1 (permalink)
Will
Question Turbo and fuel question for guru's (highrev and blueroadster better be in here)
Time to state some obvious facts with some conclusions and problems with possible projects to undertake.
OK, so we all know that knocking and detonation are not our friends.
We have knock sensors in our SI's, but if you run a turbo kit, you increase the risk knocking, and the sensor(s) might not keep up with the knocking and cause detonation. Since we run high compression engines (11:1 compression) we are required to use 91 octane fuel (or better)
"Safely" we can run about 8-9lbs of boost on our stock motors. That's all fine and dandy, but when boosting, knock and ping happens. So when on the track, you want race fuel 99 octane, 101 octane, etc. This stuff is expensive. Like $5 or $6 bucks per gallon.
There IS however an alternative and I cant believe nobody has mentioned this before: E85 fuel. For those that dont know, E85 fuel is a fuel with much higher concentrations of ethanol and made from corn. It is also MUUCH cheaper. about 25%-40% cheaper than regular gasoline. E85 also has an octane rating of 100-105. (WOW?) There are some drawbacks, unless your car is "flexfuel" certified or "e85 certified" you have to replace some items on your car to make it compatible. Read the following article to see what I'm talking about.
Taken from wiki article
E-85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such flexible-fuel engines are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. The primary differences from non-FFVs is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system, the use of fuel pumps capable of operating with electrically conductive (ethanol) instead of non-conducting dielectric (gasoline) fuel, specially-coated wear-resistant engine parts, fuel injection control systems having a wider range of pulse widths (for injecting approximately 40% more fuel), the selection of stainless steel fuel lines (sometimes lined with plastic), the selection of stainless steel fuel tanks in place of terne fuel tanks, and, in some cases, the use of acid-neutralizing motor oil. For vehicles with fuel-tank mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used.
So my questions are: is it possible to get e85 fuel w/o spending thousands of dollars modifying. If it is, what would need to actually be replaced? maybe we just need a couple parts replaced and viola.
Anybody willing to partner up or undertake the project with me or on their own?
icewildabeast is offline   Reply With Quote
Old 02-25-2008, 05:39 PM   #2 (permalink)
There are pro's and COn's to E85 and this will be debated for a long time IMO...
You have to flow 2-2.5 times as much fuel for a start. Think 1000cc injectors.
Ethanol is corrosive to aluminum, and deteriorates elastomers (rubbers) anodized aluminum parts are a good preventative and teflon coated fuel lines... any elastomers it comes in contact with should be checked frequently of course.
Gasoline's stoich is 14.7. E85 stoich is around 9ish if I remember. Boosting AF should be like 7:1 which is alot of fuel...
Also, one thing everyone doesn't know is that e85 is an alternative fuel, but not a cleaner fuel. It is supposed to be equal to or more damaging than fossil fuels to the environment.
It can be done and a bunch of the supercharged RSX guys I know use it, but without tuning its not somthing we should be concerned with right now
I am sure BLue can help more than me...
Old 02-25-2008, 05:50 PM   #3 (permalink)
Will
gah... back to the K-PRO *cough cough* I mean ***-BLOW solutions eh? *sigh* that's irritating.
Old 02-25-2008, 06:08 PM   #4 (permalink)
It would cost too much to convert everything. If you need to up the octane rating and don't want to buy race gas all of the time, then go with a water/methanol injection system. I'll be using an Aquamist system and 07CivicMD will be using a Snow system.
blueroadster is offline   Reply With Quote
Old 02-25-2008, 06:09 PM   #5 (permalink)
No converting from what I remeber Blue...Not sure though...I know the K-pro guys just switch maps and there set to go. That is on just big injectors and stock fuel systems..
Old 02-25-2008, 06:41 PM   #6 (permalink)
sheek360's Avatar
e85 eats up ur rubber fuel injector seals and it dont go well with aluminum, its a bit corosive. even cheaper then that e85 conversion is good ol meth injection! even a 50 50 mix isnt all that corrosive!
sheek360 is offline   Reply With Quote
Old 02-25-2008, 06:53 PM   #7 (permalink)
don't we have all aluminum engines with rubber fuel lines and seals? lol and you said e85 was bad for both? i don't like the sound of that.
vtecmike1 is offline   Reply With Quote
Old 02-25-2008, 07:59 PM   #8 (permalink)
soxfan143's Avatar
E85 is rediculous. First of all, doesn't your fuel mileage drop drastically? And doesn't it actually create more greenhouse gasses to produce it than gasoline even creates while it" being burnt? I was told this by one of the teachers at my training facility for my work. I work in the automotive industry.
soxfan143 is offline   Reply With Quote
Old 02-25-2008, 08:32 PM   #9 (permalink)
07CivicMD's Avatar
Roger
Knock is bad but once tuned you should have a good idea where your A/F ratios are at most times. I will have both a street and race tune once the car is finished. The street tune will be optimized for boosting and modified for vacuum for DD (MPG). The Haltech has the ability to hold 2 seperate maps and I will be housing all my maps on my laptop.
The water/Meth is great to help reduce knock and since Meth is a fuel it add more power over alcohol which cools the intake charge to increase boost.
Once the K-Pro is release I believe it will have knock control and the abilty to control the timing accordingly. You can always spend the extra money and get an aftermarket knock sensor if your really worried about knock.
Monster Dyno Run on HGH
07CivicMD is offline   Reply With Quote
Old 02-25-2008, 08:45 PM   #10 (permalink)
2RotorMotor's Avatar
e85 is pretty sick.. you need alot of fuel but beats the price of race gas. eitherway all our lines are teflon, so we dont have a problem..
2RotorMotor is offline   Reply With Quote
Old 02-25-2008, 09:04 PM   #11 (permalink)
You sure about that?
Old 02-25-2008, 11:18 PM   #12 (permalink)
E85 is pure sickness for the bang/buck profile kinda guy but its takes a ton more fuelo which is the sucky part. for 3.20/gal locally its can make a bunch of power but the majority of the cars i used already max 1000cc injectors and would be forced to go with 1600cc instead for a track only built motors its nice but for a daily driver not a good idea fellas. and the aluminum can be coated to prevent corrosion from E85 and nylon lines i hear work great and are pretty inexpensive
Tigre is offline   Reply With Quote
Old 02-25-2008, 11:25 PM   #13 (permalink)
Our stock lines are nylon right? ..I know some are, but all of them?
Old 02-27-2008, 08:12 AM   #14 (permalink)
not really.. I know they're plastic which is all that matters.. what are they?
Old 02-27-2008, 10:51 AM   #15 (permalink)
I've been doing alot of research on E85 recently and we'll be running it in our STX (yes STX...not STS) Civic this year. Starting in 88, most manufacturers started to do a better job making the car's hardware more ethanol compatible. And starting in 1996, they are even more compatible. The new civic's probably do need a little bit of modification to run E85, but it's probably not a big deal.
Stoich on E85 is around 9:1 but best torque is around 0.8 lambda rather than 0.9 lambda with gasoline (it likes to be relatively richer on E85 than gasoline at WOT). In the end, you need to be able to run around 60% more fuel at WOT and 50% more fuel at cruise..... or something like that.
We are definitely planning to do more with E85 in the future because it's good octane makes it ripe for performance builds. And if all you have to do is change some seals and lines and maybe upgrade/improve/coat a gastank, then there isn't much to deter us.
Chris
RedShiftChris is offline   Reply With Quote
Old 02-27-2008, 12:13 PM   #16 (permalink)
Will
nice, well at least there is good potential and I'm not the only one to see it. May not be a DD, but hey, I figured it's worth investigating.
Question to Highrev and other heavyweight about suspension upgrades! HondaScott Suspension and Brakes 141 04-03-2008 07:19 AM
Question for Highrev and other suspension gurus dualdiagnosis Suspension and Brakes 12 02-18-2008 02:48 AM
What fuel system would pair well with TSI turbo package? jtman Forced Induction And Nitrous 0 10-29-2007 02:04 PM
Ford TwinForce (Twin Turbo Flex Fuel V6) MBK Garage 10 08-28-2007 10:42 PM
Stereo Guru's Please Answer My Question civicboy Garage 9 03-15-2006 03:55 PM
