Old 02-08-2008, 06:55 PM   #1 (permalink)
boca1's Avatar
race header question?
i talk to nate today about a race header and comptech sc combined and he said definately NOT recommended!!
i am still waiting to hear back from hondata whether or not it will be ok..
nate said these cars will lean out with the race header and sc ..
can anyone give more info ......could it be possible he was just trying to sell me his shorty header considering his header is the only one for this car thats not race style? please let me know what you think
thank you!
boca1 is offline
Old 02-08-2008, 07:00 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
its possible.
is Missy a squirter?
http://killyourself1.myminicity.com/env build my city.
Zeuceone is offline
Old 02-08-2008, 07:06 PM   #3 (permalink)
they say that so you'll buy there shorty header. theres plenty of dynos to proove its possible and perfectly safe. "afr" wise. we are NOT rsx's. rsx's have problems with race headers because there ecus are not as smart as ours. we on the other hand have no problem with race headers.
vtecmike1 is offline
Old 02-08-2008, 07:19 PM   #4 (permalink)
boca1's Avatar
doug at hondata just responded to me and sais it should be fine...but has not been tested....so he said just check the afr and make sure not to hit 13 or higher..
boca1 is offline
Old 02-08-2008, 08:31 PM   #5 (permalink)
The headder alone should not affect the afr enough where you should have to worry.
Jimmysaintjames is offline
Old 02-09-2008, 09:24 PM   #6 (permalink)
kenny rogers's Avatar
Greg
I would say just the opposite - a race header has larger primaries & better flow. Race headers have larger primaries & better flow, perfect for a high volume/tempurature FI engine.
The air-fuel ratios will not be affected with the addition of a race header.
kenny rogers is offline
Old 02-09-2008, 09:31 PM   #7 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
There is a guy selling his Comptech prepared 2006 Si that was a test bed for Comptech products. He has the Comptech S/C along with the Comptech header. If a shorty works, I don't see why a Race Header wouldn't be able to work as well. This is a good question though. It certainly would be worth talking to either Comptech or Chris at RedShift to get their input.
http://www.8thcivic.com/forums/8th-g...ch-usa-si.html
NitrousG35 is offline
Old 02-09-2008, 09:54 PM   #8 (permalink)
reaper702's Avatar
shouldn't affect AFR with our cars, as someone previously stated, we do NOT have the same problem as rsxs...
plus wasn't there someone with a comptech s/c + rh (may have been the dcrh) with something around 250-260whp?
reaper702 is offline
Old 02-09-2008, 10:09 PM   #9 (permalink)
Jeremy
comptech SC with BCRH here, no probs what so ever, my car actually runs rich, you can smell it when i push the car hard
jeremy0203 is offline
Old 02-10-2008, 02:21 AM   #10 (permalink)
reaper702's Avatar
Old 02-10-2008, 03:58 AM   #11 (permalink)
I do look like a monkey
Jeremy
There's a member, to177si he has a BCRH and Comptech SC... his dyno and afr's turned out fine from what he said. You should pm him and ask him about it.
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG
mad monkey is offline
Old 02-10-2008, 11:36 AM   #12 (permalink)
liquidr1's Avatar
Dustin
Well it states on their web page for the S/C that to achieve additional power that the addition of Intake, HEADER, and exhaust is recommended.
So yea
liquidr1 is offline
Old 02-10-2008, 04:58 PM   #13 (permalink)
8thcivic Sponsor
Less restriction means lower PSI with a power increase. So going from a stock setup to a race header you will loose PSI but gain power...And that really is the key Most power out of the lowest Pressure. So even though your flowing more air the PSI acutally decreases due to the opening up of the "bottleneck", yet power increases.
Lotsa guys on here run a race header with their Comptech kit, I am sure its FINE!!
BUY MY CIVIC
Highrev1 is offline
Old 02-10-2008, 05:06 PM   #14 (permalink)
dualdiagnosis's Avatar
Highrev, is there any negative changes to a/f with just running a race header though?
dualdiagnosis is offline
Old 02-10-2008, 05:09 PM   #15 (permalink)
8thcivic Sponsor
Like just running one stock? Or with the charger?
BUY MY CIVIC
Highrev1 is offline
Old 02-10-2008, 05:10 PM   #16 (permalink)
Just stock.
Old 02-10-2008, 05:19 PM   #17 (permalink)
8thcivic Sponsor
From what I have read on the forum here...Its fine I haven't personally datalogged any A/F's yet...But a quick search found this
"rh will not make you run dangerously
lean on the stock ecu, despite the rumors you may hear on the forum"
"rh did lean the car out about 1 point across the powerband, which in fact does not make the car dangerously lean. this is also only at wot."
But I dunno for sure, I would suggest datalogging your A/F's if you REALLY want to be safe, but most use it and haven't had any issues.
BUY MY CIVIC
Highrev1 is offline
Old 02-10-2008, 05:30 PM   #18 (permalink)
Thanks for the reply. I just get a little OCD about my cars and want to be safe because I haven't had the a/f checked at all.
Old 02-10-2008, 05:38 PM   #19 (permalink)
boca1's Avatar
well thanks for all the input..i guess it will be safe...i am running a wide band also ..so when i put the sc on i will be able to moniter it...
boca1 is offline
Race Header question 06fg2fijibluesi Bolt-Ons And All-Motor 6 12-05-2007 09:37 PM
sr*s race header for 07 si rear 02 question monza679 Bolt-Ons And All-Motor 30 11-04-2007 10:59 PM
dc race header question... EntropyXIII Bolt-Ons And All-Motor 17 06-06-2007 05:52 AM
Stupid race header question. Blk4drSI Bolt-Ons And All-Motor 11 04-09-2007 03:00 PM
DC Race header Question on sound??????? mikef1182 Bolt-Ons And All-Motor 4 07-18-2006 06:48 PM
