#7 (permalink) | |
![]() For the oil feed line, you will need to remove the stock oil pressure sensor and screw it into the supplied brass T-fitting. Here is an installed PIC: ![]() This PIC shows the feed hose secured to the block with a rubber insulated clamp. ![]() I don't have a PIC of the oil feed hose connection to the turbo assembly, but you should be able to figure it out. Just make sure that the center housing is rotated correctly so that the feed goes in from the top and the drain goes out the bottom. |
#10 (permalink) |
Thanks...I'm happy to answer questions however, I will not write up a complete DIY for the AJP turbo kit installation. People pay enough for the kit to where IMHO, AJP should spend the time to document and send instructions to those that ordered the kit from them.
#11 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
I am happy to help others, but I am not going to write instructions for a kit that a company should have provided in the first place without receiving any compensation beforehand. |
#15 (permalink) |
I think they would lowball you. Intellectual property & copyrights to your pictures should be compensated. Show them a sample (like a random step in the write-up), tell them what you want (say... $1k) :P
I suggest just seeing what they have to say. I assume they have some interest in providing some instructions... cuts down on costs to answer questions when people call... |
#16 (permalink) | |
#17 (permalink) |
DO NOT, I REPEAT: DO NOT USE THE CRAPPY BRASS T AND RUN THE PRESSURE SENSOR RIGHT OFF THE BACK OF THE BLOCK!
-the vibrations from the motor will, over time(sometimes days, sometimes months) cause the T to break off and all your oil will go everywhere but where it should go. i've seen it at least 8 times and its not a pretty site ever! -instead, buy the correct Earl or whatever brand ALUMINUM AN to NPT fitting, screw that into the port, then run a -4 or -3 1ft line to the fire wall where you will then mount your T fitting(aluminum). screw the sensor into one port and then run your feed line for the turbo off the other. -when that stupid brass T breaks off inside the hole and your out on the road or on the dyno, there isnt a dman thing you can do to drive the car back home. towing is the only option. -spend the extra 30 bucks and get it done right. |
| THE OIL FAQ - synthetics, intervals, weights, brands | jdrumstik | Mechanical Problems & Technical Chat | 97 | 09-17-2008 03:45 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 12:45 PM |
| Do you change your own oil | Wu36Ca | Civic SI | 88 | 03-22-2007 04:10 PM |
| Maintenance minder and synthetic oil question... | Paradox Lost | Mechanical Problems & Technical Chat | 17 | 02-14-2007 08:59 PM |
| oil change frequency | JLRvtec | Mechanical Problems & Technical Chat | 34 | 04-28-2006 04:33 PM |
