Closed Thread
Old 12-06-2007, 06:38 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Blueroadster's Engine Build and RedShift Turbo Thread
This thread will be used to provide details and updates regarding the engine build and turbo kit installation being done on my car by RedShift. The engine build will be custom using the stock K20Z3 block and head. The turbo kit will be the RedShift based turbo kit with a few modifications.
Engine Build Details:
  1. Endyn ERL Sleeved Block (88mm bore)
  2. BC Stroker Kit (92mm stroke resulting in a 2238.2cc or 2.2L displacement (stock displacement is 1998.3cc or 2.0L with a 86mm bore and 86mm stroke)) with 9.0:1 Compression Pistons (with coatings, etc.)
  3. Endyn Fully Ported and Polished Head with Cams, Oversized Valves, Dual Valve Spings, Titanium Retainers, O-ring, etc.
  4. Endyn Ported Intake Manifold
  5. HyTech Modified RSX Oil Pump
  6. HyTech Oil Pan Baffle
  7. ACL Race Bearings
  8. Cometic Gaskets and Seals
  9. ARP Head Studs
Oil Stuff:
  1. Setrab Oil Cooler
  2. Mocal Sandwich Adapter w/ Built in Thermostat
  3. Perma Cool Oil Filter Relocation Kit
  4. GlowShift Oil Sandwich Adapter
  5. Oil Temperature Sensor
  6. Oil Pressure Sensor
  7. Custom Oil Catch Can Setup
Electronics Stuff:
  1. Innovate XD-16 Gauge
  2. Innovate LC-1 Wideband Sensor
  3. Innovate DL-32 Datalogger
  4. Innovate OpenTune 1
  5. World Electronics TBC-1 Electronic Boost Controller
  6. MoTeC
  7. Valentine One
  8. Custom Multi-point Vehicle Security System
Fuel Stuff:
  1. Custom Fuel Tank Assembly
  2. Aeromotive 13110 Pro-Series Fuel Pressure Regulator (-1psi for every 2inHg vacuum, +1psi for every 1psi of boost)
  3. Aeromotive 12354 Platinum Series 100 Micron Fuel Filter
  4. BDL K-series Fuel Rail
  5. 8AN Fuel Return Line (Will Probably Change to 8AN Feed and 10AN Return)
  6. Walbro 255 Fuel Pump (Will Probably Change to Bosch 044 External)
Other Stuff:
  1. Cusco Lower H-brace
  2. CorSport Front Lower Tie Bar
  3. CorSport Rear Lower Tie Bar
  4. HFP Suspension
  5. 17" HFP Rims and a Set of 17x8 Enkei RPF-1 Rims
  6. Kics Project R26 Neo Chro Lug Nuts
  7. Progress Rear Sway Bar
  8. CorSport V2 Endlinks (Front and Rear)
  9. Exedy Multiplate Clutch Kit (HM032SBL)
  10. Odyssey PC680 Battery
  11. Carbing Strut Tower Bar
  12. Russell SS Brake Line
  13. Russell SS Clutch Line
  14. Custom Polished Valve Cover
  15. CorSport Shifter Cable Bushings
  16. Skunk2 Rear Upper Control Arms
  17. Ingalls Front Camber Bolts
  18. Hondata IMG
  19. P2R throttle Body Gasket
  20. Ingalls ETD
  21. Ingalls Stiffy
  22. Spectre Magna-Kool Upper Radiator Hose
  23. Mugen Pedal Set
  24. Fast-Turbo Vacuum Block
  25. Omni Power Titanium Defouler
Custom Redshift Turbo Build Details:
  1. GT35R Turbo (T3 4 bolt turbine housing, external wastegate configuration)
  2. 1000cc RC Engineering Injectors
  3. FJO Peak and Hold Driver Box
  4. HyTech Manifold
  5. HyTech Downpipe
  6. Synapse SB001 Synchrinic BOV
  7. Synapse SB001.5A Anti-Stall Valve Kit
  8. Synapse WG002 Synchronic 50mm Wastegate (Dumptube recycled back into the exhaust)
  9. Intercooler Piping
  10. Air to Air Intercooler
  11. RedShift Full 3" Modular Exhaust (Random Technologies cat with flanges to swap out for a test pipe when at the track)
  12. Aquamist HFS-5 Water/Methanol Injection System
Comments and questions are welcome however, I will not discuss price other than saying that it is a lot.
blueroadster is offline
Old 12-06-2007, 06:40 PM   #2 (permalink)
rickhilbert's Avatar
Can we trade cars?
rickhilbert is offline
Old 12-06-2007, 07:11 PM   #3 (permalink)
07CivicMD's Avatar
Roger
When can I give details on my engine build? Don't want to steal your thunder!!
07CivicMD is offline
Old 12-06-2007, 07:14 PM   #4 (permalink)
udumkid's Avatar
Rene....
housing A/R?
udumkid is offline
Old 12-06-2007, 07:16 PM   #5 (permalink)
I Vtec, do you?'s Avatar
Blue, what do you do for a living?
Definitely interested in seeing how this turns out, sounds like it's gonna be an animal
I Vtec, do you? is offline
Old 12-06-2007, 07:21 PM   #6 (permalink)
8thcivic Sponsor
He's a toll collector acutally...
BUY MY CIVIC
Highrev1 is offline
Old 12-06-2007, 07:26 PM   #7 (permalink)
Whenever you want...I'm very interested to hear more about your build.
Old 12-06-2007, 07:26 PM   #8 (permalink)
Originally Posted by rickhilbert View Post
Can we trade cars?
Depends on the offer.
Old 12-06-2007, 07:28 PM   #9 (permalink)
8thcivic Sponsor
DO tell do tell
BUY MY CIVIC
Highrev1 is offline
Old 12-06-2007, 07:32 PM   #10 (permalink)
Originally Posted by udumkid View Post
housing A/R?
It is a T3 with I believe a .63 A/R 4 bolt turbine housing.
Old 12-06-2007, 07:35 PM   #11 (permalink)
udumkid's Avatar
Rene....
Originally Posted by blueroadster View Post
I believe the .63 4 bolt turbine housing.
sweet..I also see the turbo has an internal wastegate, any reason why you chose this turbo compare to one with an external wastegate?
udumkid is offline
Old 12-06-2007, 07:46 PM   #12 (permalink)
The turbo is available with either an internal or external wastegate configuration. I am going to stick with the external wastegate setup using a Tial 44mm with the dumptube recycling back into the exhaust. The exhaust will be a full 3" with a cat.
Old 12-06-2007, 07:48 PM   #13 (permalink)
CapnCrunch926's Avatar
Sweeeet. I'm excited to see how it turns out!
CapnCrunch926 is offline
Old 12-06-2007, 07:49 PM   #14 (permalink)
8thcivic Sponsor
Same exhaust thats on the car now?
BUY MY CIVIC
Highrev1 is offline
Old 12-06-2007, 07:54 PM   #15 (permalink)
udumkid's Avatar
Rene....
I was just wondering since there was no info on the wastegate
udumkid is offline
Old 12-06-2007, 08:01 PM   #16 (permalink)
Probably...I think that the catback is cool, but the midpipe may need to be modified depending on how loud the car is when everything is completed.
Old 12-06-2007, 08:02 PM   #17 (permalink)
Cool...I'll update the first post. Thanks!
Old 12-06-2007, 08:06 PM   #18 (permalink)
ReDHatchyGuy's Avatar
David
id go with alittle bigger than the .63 exhaust side.. the smaller exhaust side might hurt your top end.. I cant wait to see it when your are done.. i'm looking for a good setup to go with...
ReDHatchyGuy is offline
Old 12-06-2007, 08:09 PM   #19 (permalink)
Two for the money, one for the state is my motto.
Old 12-06-2007, 08:11 PM   #20 (permalink)
07CivicMD's Avatar
Roger
He really is.
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/forced-induction-nitrous/68219-blueroadsters-engine-build-redshift-turbo-thread.html
Synapse Synchronic Blow-O
