#84 (permalink) |
I'll answer that... yes Eric is going with cams. Also he is looking into intake manifold options as well...and ported stock intake at least. This setup will be good for crazy power, but we're matching the turbo for the street rather than race rubber. Car will probably be able to peel the paint of the center line at will. haha.
Chris |
#85 (permalink) |
Great to hear! Don't think I will head in that direction with the head job until this summer. I want to wait for newer cams to hit the market and Swift is planning to design a custom intake. Think we finalized and have planed a phone call later today to with Darton. Darton is producing K20 Racing blocks with their sleeving.
#87 (permalink) | |
#88 (permalink) | |
#92 (permalink) |
Don't relocate the battery to the trunk...From Hondata
"Do not relocate the battery. There is always enough room in the stock location for an AGM battery, and never a pressing need to relocate the battery. Relocating the battery inevitably causes problems with excessive voltage drop. There are two very common problems: There should be two cables from the positive terminal of the battery - one to the under hood fuse box and another to starter motor. Almost all battery relocations replace this with a single cable, which joins onto the normal battery positive terminal. There are two problems with this: 1) There is now a join in the cable from the battery to the starter motor (and also the other cable to the fuse box). 2) The cable to the fuse box needs to go to the battery positive terminal so that the vehicle receives sufficient voltage when cranking the engine. Otherwise when you crank the engine, the voltage to the ECU will fall to a level which corrupts the normal startup of the ECU - end result is an error code and 4000 rpm rev limiter. The cable run from the alternator to the battery is now very long, and has a connection or joint at the old positive terminal (as above). The voltage regulator for the alternator is integral to the alternator. Thus the output voltage is determined by the voltage at the alternator. If there is significant resistance in the cable to the battery, then the voltage at the battery will be too low to sufficiently charge the battery. In this case a connection resistance of only 0.01 ohms (which is about 1/20th of what your digital multimeter can read) will result in a half volt drop at the battery. " |
#96 (permalink) |
It is being sent out tomorrow.
I will also need a new crankshaft since the thrust bearing is shot. I am going to contact Tai at CorSport and Exedy as the Hyper Single Stage III clutch kit that was designed to work on the car resulted in the thrust bearing failing (I'll post PICs later today). The clutch, flywheel and pressure plate itself however are in good condition. When I spoke with Chris, he also mentioned that there were a lot of pen markings on the outside of the block and a lot of the parts inside. Their RSX did not have all of these markings so it seemed odd. I bought the car new and brought it home a day after it arrived at the dealer's lot. It also only had 47 miles on the odometer. |
#97 (permalink) | |
Sorry to hear that! I just replied on the other thread.. At least the clutch is still good! I should have an update to my block later this evening. Swift called earlier and told me they had good news on the block!! |
LinkBack to this Thread: http://www.8thcivic.com/forums/forced-induction-nitrous/68219-blueroadsters-engine-build-redshift-turbo-thread.html
| Encorefg2 Peakboost Setup...Dyno/Track Numbers - Page 2 - Club RSX Message Board | This thread | Refback | 03-13-2008 12:36 PM | |
| Synapse Synchronic Blow-Off Valve SB001 is shown and what comes in the retail box when you buy one. Also shown are optional flanges and which ports to use when you first setup your unit. - Video | This thread | Refback | 02-16-2008 11:33 PM | |
| Forced Induction And Nitrous - 8th Generation Honda Civic Forum | This thread | Refback | 12-07-2007 08:50 PM | |
