GT35R Turbo Update
In the process of installing the oil cooler kit, I had to remove several parts to include the downpipe. Once that part was removed, I looked inside of the turbine housing and the fins appeared to be chewed up a little. I removed the whole turbo assembly to get a better look and brought it to a friends house to discuss. Here is a PIC:
![]() When I installed the turbo assembly the last time (several months ago), I was very careful to make sure that all parts were clean and free of debris again. The fins were also in mint condition at the time. After installation, I never heard any strange sounds at all. Not knowing what could have caused the damage, we decided to check the compression to make sure that it was not something that went through the engine and into the turbine housing. As a result, the compression was good on all four cylinders and the engine is still running strong. The only other thing that we could think of that could cause such damage would be if the fins got super heated which caused the metal to weaken and sheer bit by bit. I don't know how much heat the fins can take before the metal weaks (i'd imagine a lot), but too much heat seems to make sense (i.e., an overly rich condition causing gas fumes to also ignite in the turbine housing thus creating a lot more heat and stress on the fins). Does that make sense? |
I guess a foreign object can't be ruled out entirely. I sent the manifold with turbo assembly attached to a machine shop several months ago to get the flange on the manifold machined smooth. The machine shop could have dropped something into the housing when they assembled everything back together and I could have totally missed that. If they did drop something in there though, I would have thought that I would hear grinding or something.
In any event, this really sucks. The turbo assembly will need to be sent out for repair which will probably take some time to get back. |
#15 (permalink) |
Well, the chewed up fins on the turbo are not the only problem. There is also an exhaust leak on the downpipe itself. One of the welds split in what looks like a 1 inch long hairline fracture. You can see carbon deposits all around the split itself.
#17 (permalink) |
i use antilag on street cars all the time and nothing will generate more damage than explosions in the manifold and turbine housing and the turbos dont look like that after a year. that sir resembles foreign object damage and its gonna be the first thing Precision says when they see it.
| Reflash Update for AJP Based Turbo Cars | blueroadster | Forced Induction And Nitrous | 143 | 12-20-2007 09:38 PM |
| Honda Accord GT35r Turbo Vs Gsx-R1000 and Gsx-R600 | trev0006 | Garage | 3 | 10-13-2007 05:41 AM |
| Info on engines n/a and turbo | King Bob | Bolt-Ons And All-Motor | 11 | 07-20-2007 01:11 AM |
| Turbo Update: GT-35R | blueroadster | Forced Induction And Nitrous | 170 | 05-17-2007 08:22 PM |
| turbo update/ forced induction | sickyute | Forced Induction And Nitrous | 26 | 11-23-2006 10:15 PM |
