Hondata Reflash & Greddy E-Manage Ultimate Together
I don't get it. I've seen the posts that say if you get the Greddy turbo kit for a '06+ Civic Si and you already have the Hondata I/H Reflash, then you have to have your ECU flashed back to stock. I understand to some degree, but I don't believe the real answer is that simple.
I understand that Greddy built their base tuning for their kit on the stock ECU. And, yes, if you use the base tuning from Greddy, then you should have a stock ECU and not the Hondata Reflash. However, just suppose that Honda had produced the '06 Si with a less restrictive intake and had programmed the stock ECU exactly as Hondata did with the Reflash. Does that mean that Greddy would not be able to produce a turbo kit for the Si?? No. They'd simply have a different base tune that took into account the ECU from Honda. Now, why can't I do the same thing? Suppose I was the best tuner in the world (or more likely, I hired a great tuner). Why can't that tuner toss the Greddy base tune and create a tune from scratch that works with the Hondata Reflash? Does that make sense? I just don't believe that you can't run the Greddy turbo and the Hondata Reflash together, as long as you toss the Greddy tune and build you own in the E-Manage from scratch? |
280whp, 219tq, GReddy FTW
Chuck, now that I think about it, that makes total sense. In fact, it seems to me that this would be the BEST setup EVER. If you had the reflash and a GOOD tune on the E-Manage, I bet you'd have one killer ride. I wouldn't run the two simultaneously without a tune, but since the reflash doesn't advance timing, why not do both??? Especially since the reflash lowers VTEC to 4500 RPM at WOT, and you're already at full boost by then. You'd run a serious risk of running lean without a tune, but WITH one, that might be pretty damn sick. I'm all for it. Be our guinnea pig Chuck!!
If you must whine about my Avatar, do it in this thread: http://www.8thcivic.com/forums/showthread.php?t=35167 |
Thanks, Phil! I've found a local guy who can either install the Greddy kit and tune it from scratch, or build a custom turbo and tune it with the e-Manage Ultimate, but I'm still trying to get all my ducks in a row. It may still be a bit before I can move forward, but this is what I'm think of doing - especially if I go for the custom kit (which would give me more whp for the same money). I just want to make sure that my thinking about the Reflash and E-Manage makes sense...
#5 (permalink) | |
#6 (permalink) | |
#7 (permalink) | |
But, I don't see that a standalone EMS is required to get a good tune, either. Greddy obviously developed a tune that is good enough to sell as a product. My point, on my original post, is simply, why can't a good tuner simply develop a new, yet different, tune for the e-Manage Ultimate piggyback EMS that works with the Hondata I/H ECU Reflash and the Greddy turbo kit by throwing away the Greddy base tune for the stock ECU and starting from scratch? This seems very logical to me. Granted, it assumes that you have a tuner that is very good with the e-Manage Ultimate product, but it certainly seems possible. I do realize that a good standalone EMS would have the potential to provide a better tune than the e-Manage Ultimate, but it seems to me that the e-Manage should work and do a good job. Edit: Spell check... Last edited by chilipepper; 08-08-2007 at 11:31 AM. |
#10 (permalink) | |
Also, I haven't heard of the stock ECU "blowing out" any piggyback EMS devices. Where did you see this? |
#11 (permalink) |
8thcivic Sponsor
In theory you could use the V-manage and E-manage, and have quite a bit of control over the si's ECM. Have a tuner do a complete custom setup...
BUY MY CIVIC |
#12 (permalink) | |
Edit: Never mind. I just saw your post on the RedShift thread... |
#14 (permalink) | |
#17 (permalink) | ||
What I don't know (or have any knowledge of), is when you add e-Manage or v-Manage, do these devices insert themselves in-between the ecm's output and the control device? Or, do these simply provide modified input signals to the ecm in order to manipulate the ecm's output? Or both? |
#18 (permalink) |
I'll try to explain in simpler terms. Say for example the flow rate of fuel going through the injectors and controlled by the ECM is rated at a flow rate of 1 through 5, where 5 would be the the most amount of fuel dumped.
Now lets say that the ECM regulates the fuel at a flow rate of 3. You decide to add more fuel via a piggy-back fuel controller to increase the flow rate one more number higher (i.e., to 4) to make it run more rich. What will happen is that the ECM would send a flow rate of 3, the piggy-back would add one number to make it 4, but when the ECM senses that the engine is running rich, then it will self-correct and bring the resulting number back to 3 (i.e., the ECM would send a flow rate of 2 and the piggy-back fuel controller would increase it to 3 which is exactly what the ECM wanted in the first place even without the fuel controller). There is a lot more to it than that, but hope the above example makes sense. |
#19 (permalink) | |
In a real world example, the piggyback wouldn't add 1 to make the engine run rich, it would add 1 to keep it from running lean, right? Then, the ecm would sense that the engine is running within limits (because it really needed more fuel to be correct), and the ecm would continue to generate an output of 3 with the piggyback adding 1 to get to a constant 4. This would continue until the fuel requirements change again. Does that make sense, or am I still missing something? |
#20 (permalink) |
What I am trying to say is that the ECM is fed data from various sensors in order for it to calculate the running state of the engine. It has a MAF, MAP, barometric pressure sensor, temperature sensor, O2 sensor, etc. All of these work in conjuction in some form or fashion enabling the ECM to calculate data in realtime and to autocorrect when running in closed loop faster than you would ever be able to notice. For example, if you had a datalogger and external fuel pressure regulator, you would never see a difference in the AFRs when quickly changing the fuel pressure from say 30 to 60 PSI. On the datalog file, you would not even see a blip of a change in the AFR.
The ECM can auto compensate for a number of things based upon the data that it is fed from the various sensors. The only thing that has yet to be said is the range extent for timing and other things that the ECM can deal with verses what it cannot deal with. Know what I mean? ![]() |
