Old 07-17-2007, 05:49 AM   #1 (permalink)
EXcoupe06123's Avatar
Nitrous Wet Kit DIY R18
Hi this is a request for a DIY for a Nitrous wet kit for r 18 it seems that the zex kit it one of the easiest to install and use and popular .
please some one post a DIY of a zex kit. Also what about using a 75 shot on a r18
EXcoupe06123 is offline   Reply With Quote
Old 07-17-2007, 06:48 AM   #2 (permalink)
RANGERSi07's Avatar
basic rule of thumb is 1/3 your motors hp
RANGERSi07 is offline   Reply With Quote
Old 07-17-2007, 08:35 PM   #3 (permalink)
So it is the same as 40% hp that would be arroud 50 hp admited of nitrous
Old 07-17-2007, 08:44 PM   #4 (permalink)
Old 07-17-2007, 08:56 PM   #5 (permalink)
RANGERSi07's Avatar
I'm just saying thats a safe guideline but you should be able to use a 50 shot just fine
Old 07-17-2007, 08:58 PM   #6 (permalink)
Yeah a might run a 55 shot some people says that zex give less of what they say so I maight be fine
Hey guys some one please post a DIY
Old 07-18-2007, 08:49 AM   #7 (permalink)
slostjoe's Avatar
Skyler
Ive looked for a D.I.Y but i could not find one when i went to do mine all i can say is it's alot easier than it looks and i can offer any help you need.
slostjoe is offline   Reply With Quote
Old 07-18-2007, 10:46 AM   #8 (permalink)
Yeah it seems pretty easy maybe I will isntalit my self with some mechanic friend.
Just I am courious on how is the wiring to the TPS
Old 07-18-2007, 02:01 PM   #9 (permalink)
slostjoe's Avatar
Skyler
Engine Speed (Tach) Connection
ECM Connector A, Pin 28 (Outputs Engine Speed Pulse (NEP)) --> BLU Wire --> Connector D, Pin 3 (BLU (NEP)) on the EPS Control Unit (located inside the cabin behind the kick panel on the passenger's side)
Vehicle Speed Connection
ECM Connector A, Pin 29 (Sends vehicle speed sensor signal) --> BLU Wire --> Connector C201, Pin 4 (on the 2006 Si) or Connector C202, Pin 10 (on the 2 door 2007 Si) --> BLU Wire --> Connector G, Pin 5 on the Under-dash Junction Box (located inside the cabin under the dash on the driver's side)--> Out of the Under-dash Junction Box via a BLU Wire coming out from Connector E, Pin 2 and a BLU Wire coming out from Connector D, Pin 2
Throttle Position Sensor
Throttle Position Sensor/Throttle Actuator (on the throttle body), Pin 1 --> RED/BLK Wire --> ECM Connector C, Pin 20 (Sensor Input (TPSA): Detects Throttle Position Sensor A Signal)...ECM does not output.
Throttle Position Sensor/Throttle Actuator (on the throttle body), Pin 3 --> RED/BLU Wire --> ECM Connector C, Pin 21 (Sensor Input (TPSB): Detects Throttle Position Sensor B Signal)...ECM does not output.
TPSA measures ~3.9V with the throttle fully open and ~0.9V with the throttle fully closed
TPSB measures ~4.1V with the throttle fully open and ~1.7V with the throttle fully closed
Old 07-18-2007, 02:40 PM   #10 (permalink)
Great Thanks. But does this also aplies to R18's
Old 07-18-2007, 02:45 PM   #11 (permalink)
slostjoe's Avatar
Skyler
From what i have gathered yes ill find out.
Old 07-18-2007, 03:08 PM   #12 (permalink)
projectprelude's Avatar
Aaron
only thing that you really have to do is get another HP fuel line and "T" in to it to the ur fuel then connect to a wire on the back of the TB
i know its not detailed or anything but its not hard
projectprelude is offline   Reply With Quote
Old 07-18-2007, 03:27 PM   #13 (permalink)
HELP
Old 07-18-2007, 04:25 PM   #14 (permalink)
slostjoe's Avatar
Skyler
Black wire ground, white is activation is the TPS sensor switch, the red is you arming it needs power 12v and a switch to interupt it.
And the nozzle is easy just put it no more than 8inch away from the TB
R18 nitrous bodydraggin Forced Induction And Nitrous 18 04-11-2007 04:22 AM
nos on an si thmper4u Mechanical Problems & Technical Chat 12 08-10-2006 05:38 PM
