Old 06-08-2007, 03:06 PM   #1 (permalink)
hondaonchrome's Avatar
Lonny
Wet kit Or Dry kit???
I was interested in a nitrous kit and was wanting to know what the best kit is for our si's?And plus the easiest to install?
And my mods are Injen Cai,Dcrh,Skunk2 70mm.Plus hondata reflash next week.
Thanks,
Lonny.
hondaonchrome is offline   Reply With Quote
Old 06-08-2007, 04:57 PM   #2 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
Thanks,
Lonny.
Do not, I repeat, do not get a dry kit. Get a wet kit. Nitrous Express has good stuff as does Zex. Make sure you run one heat range colder plugs and get a full throttle switch and window switch to adjust the rpm's the nitrous kicks in and out. A remote bottle switch is nice if you plan on using it on the street. A dyno tune would not be a bad idea either.
I have a G35 with a Nitrous Express 75 shot. Taking the proper safeguards will protect your motor. Most guys here have said to run 55 to 75 shot at the most on the Si motor. I would agree. Don't go too radical without beefing up the heads with studs and different rods and pistons if you plan on running more than a 100 shot.
Old 06-08-2007, 08:13 PM   #3 (permalink)
DetachmentBravo's Avatar
William
Wet kits allow you to safely match the amount of nitrous oxide to the fuel being introduced into the intake manifold. Dry systems run the risk of throwing off your A/F ratio during the shot, potentially causing serious damage.
DetachmentBravo is offline   Reply With Quote
Old 06-09-2007, 12:55 AM   #4 (permalink)
MADDOGSI's Avatar
Scotty
Most user friendly and reliable kit is the Zex wet kit.The Nitrous xpress and NOS EFI kits are very nice too but require more experience with nitrous to install and operate.
MADDOGSI is offline   Reply With Quote
Old 06-09-2007, 06:01 AM   #5 (permalink)
In my opinion, a dry kit is the better choice if you can control fuel properly. For example, once KPro is an option, a dry kit will be the better method.
Chris
RedShiftChris is offline   Reply With Quote
Old 06-09-2007, 11:02 AM   #6 (permalink)
William
Chris
If K-Pro is an option. I'm becoming pretty skeptical of whether we are going to see a tuning option for the K20Z3 from Hondata before the end of 2008.
Old 06-10-2007, 01:52 PM   #7 (permalink)
Lonny
Good advice keep them coming,
Who has a kit for our cars that is easy to install because of our drive by wire?
Old 06-16-2007, 02:00 PM   #8 (permalink)
thisisdudewhoru's Avatar
brian
What kind of times are you guys running with a 75 shot? With stock tires and a what is your window switch setting.
thisisdudewhoru is offline   Reply With Quote
Old 06-16-2007, 02:11 PM   #9 (permalink)
Kurt's Avatar
Zex wet kit.
Kurt is offline   Reply With Quote
Old 06-21-2007, 09:41 AM   #10 (permalink)
slostjoe's Avatar
Skyler
Zex wet kit FTW
slostjoe is offline   Reply With Quote
my 5000 mile review on the AJP kit honda06si Forced Induction And Nitrous 100 07-18-2007 06:08 PM
ZEX Wet Nitrous and Safety Help! HoNdA06 Forced Induction And Nitrous 20 05-28-2007 01:56 PM
zex dry install help SI-R Forced Induction And Nitrous 12 08-18-2006 07:00 AM
Which kit would you buy? Rallyfocus Forced Induction And Nitrous 9 08-09-2006 10:49 AM
