Old 06-02-2007, 06:55 PM   #1 (permalink)
brthorner's Avatar
Brian
25 psi Turbo w/ 13:1 Compression Ratio!
Got your attention, huh!
The new Car and Driver magazine has an article on a technology called Ethanol Boosting Systems, or EBS. It uses E85 Ethanol that gets squirted directly into the chamber via direct-fuel-injection, thus fooling the engine into behaving as if it's burning 150-octane fuel. As a result, it can tolerate the typically destructive combination of high boost plus high compression ratio. The article mentioned that an engine to support such a mixture would be running a 12:1, or possibly even 13:1 compression ratio, with either a turbocharger or a supercharger at 22 psi to 25 psi of boost pressure across a broad rpm range, and an intercooler.
The point is ultimately to save fuel, because massive power will be able to be made from relatively small displacement engines. But how amazing would something like this be for the K20Z3?? Obviously you would have to completely build the engine with forged internals, etc., but I'm guessing 350 hp to 450 hp could easily be made, if not more. And possibly better mileage as well!
Too bad there are only 1,000 E85 pumps currently in the whole country.
Brian
brthorner is offline   Reply With Quote
Old 06-02-2007, 07:00 PM   #2 (permalink)
projectprelude's Avatar
Aaron
theres e85 3 minutes away from me...but it doesnt do me anygood
projectprelude is online now   Reply With Quote
Old 06-02-2007, 09:10 PM   #3 (permalink)
F.I.A.T's Avatar
E85 requires twice as much fuel to maintain the same power levels as gasoline. supplimented with gasoline would help some but pure ethanol isnt practical for a daily driven vehicle that is built for performance as opposed to fuel economy.
F.I.A.T is offline   Reply With Quote
Old 06-02-2007, 09:15 PM   #4 (permalink)
padded's Avatar
J. Grahn
Lucas English, an evolution tuner in the Portland, Oregon area recently got one of his customers daily driven cars into 9 second quarter mile times running e85 and meth.
e85 has lots of advantages, it's downfall is that is requires more quantities to achieve the results.
padded is offline   Reply With Quote
Old 06-02-2007, 10:30 PM   #5 (permalink)
DetachmentBravo's Avatar
William
Indeed, it just doesn't have the same chemical energy.
DetachmentBravo is offline   Reply With Quote
Old 06-03-2007, 12:00 PM   #6 (permalink)
brthorner's Avatar
Brian
The EBS engine predominantly uses gasoline, but has an auxiliary E85 tank, and only uses a fraction of the Ethanol. They said you would only need to fill up the Ethanol tank every third gas fill up...
Old 06-03-2007, 12:01 PM   #7 (permalink)
padded's Avatar
J. Grahn
BUT, because of the price of e85, can I run it in the si?
Old 06-03-2007, 01:38 PM   #8 (permalink)
car salesman beware
Freq18hz's Avatar
Brian
I would imagine those horsepower numbers could be achieved. Blacktrax has a silver RSX-S that has forged internals, that is putting down 600+.
Unfortunately, without an ecu swap, our cars arn't currently candidates for such a thing, until someone comes up with a viable engine management option.
-Freq
Freq18hz is offline   Reply With Quote
Old 06-03-2007, 02:07 PM   #9 (permalink)
TwinScroll's Avatar
Soon enough dem civics will be putting down extreme numbers. ECU tuning FTW...
TwinScroll is offline   Reply With Quote
Old 06-03-2007, 08:38 PM   #10 (permalink)
Kidekat's Avatar
super high compression with boost and lower chemical energy fuel is nothing new... it is call Diesel.
it burns complete, and clean... in theory...
Kidekat is offline   Reply With Quote
Old 06-03-2007, 08:48 PM   #11 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
I don't like the idea of ethanol. It has other polutants, you don't get as good of gas mileage, and it takes more energy to make than it produces.
Old 06-03-2007, 09:12 PM   #12 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
I'm glad I live in a state that is a major user. Now all I need to do is FI my new Si and watch the horsepower go ballistic.
NitrousG35 is online now   Reply With Quote
Old 06-04-2007, 09:35 AM   #13 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Just so you know, that stuff's supposed to mess up your ride if it's not flexfuel capable. I know alot of guys on s2ki used it and then had problems.
Boosting an FG FAQ Highrev1 Forced Induction And Nitrous 52 05-25-2008 04:58 AM
HIGH COMPRESSION RECOIL Forced Induction And Nitrous 5 04-27-2007 01:45 PM
Ok, sometimes I think people dont know what they are talking about... dsg2003gt Forced Induction And Nitrous 19 04-04-2007 10:22 PM
225-45-R17, answer needed !! tonybui Civic Coupe And Sedan 26 02-20-2007 07:29 AM
Turbo and CAI CaliGuy Forced Induction And Nitrous 32 06-13-2006 12:46 AM
