Old 05-28-2007, 02:04 PM   #21 (permalink)
sickyute's Avatar
Marvie
they hide too much ...
they'll never tell u some of what u want to know ...
hiders hiders hiders ....
good work though ... ...
Shift when it blinks!
Old 05-28-2007, 02:07 PM   #22 (permalink)
DetachmentBravo's Avatar
William
HAHA, I'm definitely getting that feeling sickyute. And thanks!
DetachmentBravo is offline   Reply With Quote
Old 05-28-2007, 02:12 PM   #23 (permalink)
sickyute's Avatar
Marvie
hey... trust me ...
on my last car (link in sig) ... they used it for their kit ...
got a whole lot from them, in terms of parts etc etc ... but when it came down to letting me see the work while it's being done done, or taking pics in the early stages or letting info. out ... they won't even let me/tell me ... lol ...
whatever i had let out was going against their wishes most of the time ... ...
so yeah ... u may just have to go it blind for a while ... the info will more than likely come out later ...
PS: u should PM most of this info to Hirev1 ... that way he can update his boosting faq. thread ...
now somebody needs to make a NA thread....
Old 05-28-2007, 03:17 PM   #24 (permalink)
William
Well, I'm not hear to pass judgment on any company or their policies.
This thread exists to provide 8thGenCivic users with as much information as possible so that they can good, informed decisions.
Old 05-28-2007, 05:14 PM   #25 (permalink)
William
UPDATE:Added the TD06HR-16G6 maps.
I am also in the process of giving the entire map section a visual overhaul to make it easier to find what your looking for. Right now its all strung out because I can't use table tags on these forums so formatting still needs a little work. Replaced the full sized maps with thumbnails obviously so that help clean things up.
Old 05-29-2007, 01:46 PM   #26 (permalink)
William
I have contacted both Precision Turbo & Engine and Greddy to see if they would be so kind as to provide us with flow data for the SC6169E and T517Z turbochargers.
As soon as I hear back I will let you all know, but I am not terribly optimistic. I have a funny feeling that I am not the first person to ask for this data and that I will not be the first person they say "no" to.
Old 05-29-2007, 02:27 PM   #27 (permalink)
Originally Posted by F.I.A.T
compressor maps are a good baseline to start with but altering the motors charateristics will affect your formula. not to mention if we still went solely by compressor maps instead of real world experience we would never be runnning anything larger than a T3 turbo and no where near the GT42R that we run now.
The maps for the Precision turbos are not going to be found. They do their own R&D outside of Garrett and now make some of their own wheels. so simply relying on the garrett mmaps would not be correct in any of your calculations. esspecially since they dont use standard garrett turbine wheels which alter spool and output of each turbo.
When did you guys install the GT42R? Sounds like you are planning to push more than the 680hp the GT35R can handle.
blue1 is offline   Reply With Quote
Old 06-03-2007, 07:38 PM   #28 (permalink)
William
UPDATE: Fixed an error in the K20Z3 base charts for sea level.
Many thanks to RedshiftChris for pointing this error out for me! On the sea level charts I had the pressure ratio lines labeled with the wrong psi values. I created the altitude charts first, and totally forgot to recompute the psi values for sea level. I have corrected the charts and re-posted them.
More compressor maps on the way as well.
Old 06-03-2007, 09:20 PM   #29 (permalink)
sickyute's Avatar
Marvie
aiming for 10s??
Old 06-03-2007, 11:53 PM   #30 (permalink)
William
UPDATE: To help those who are not familiar with compressor maps I have added a section describing their basic anatomy. Its probably full of typos and misinformation because I'm tired and have been studying for exams all weekend. Please notify me of any errors you spot.
P.S. Any chance this is stick worthy yet?
Old 06-04-2007, 12:13 AM   #31 (permalink)
sickyute's Avatar
Marvie
stuck ...
thought i had done that already
Old 06-04-2007, 12:19 AM   #32 (permalink)
William
WOHOO! Many thanks good sir!
EDIT: Aww, I can't give you rep for that. Must have to spread it around or summot.
Old 06-04-2007, 11:54 AM   #33 (permalink)
Really appreciate the detailed information provided in this post. It certainly helps me understand some of the comments received regarding my dyno run.
Old 06-04-2007, 12:07 PM   #34 (permalink)
The Gangster
bossman's Avatar
Al Capone
wow....I am now thoroughly convinced to stay all motor
bossman is offline   Reply With Quote
Old 06-04-2007, 09:03 PM   #35 (permalink)
William
HAHAHAHA!!! Turbo charger thermodynamics are child's play compared to the science that goes on every revolution of an engine. Static combustion ratios, thermal efficiency, flame prorogation, quench surface, discrete element analysis... there is so much to learn. I need to purchase some good books on the subject.
Old 06-05-2007, 01:42 PM   #36 (permalink)
William
UPDATE: Allrighty couple of big updates.
Had to make another correction to my psi values for sea level. Greg from Redshift was the first to point out that I had forgotten to recalculate the psi values for the various pressure ratios. The second time round I didn't look at my notes from when I first did the calculations so I just guessed and I was a little off on the equation. All corrected now though. The values only differed by ~ 1 psi.
Next big change is that I have uploaded my excel file for this project to a mirror and provided a link. It is currently being stored at FileDen (setting up that account was a PITA), all images are stored at PhotoBucket. FileDen allows a monthly bandwidth of 50GB which is more than enough for now.
I'm refraining from hosting anything on my home server for bandwidth, availability, and security reasons. Mostly security reasons though, I'm a bit of a network security freak and my home OpenBSD server actually runs VPNs for myself and friends.
Coming up:
I'm going to add a detailed how-to for using the excel file to generate your own maps.
I've got the process as simple as possible. It only uses Microsoft Excel and Paint. (Easy huh?) I want this to be something everyone can use regardless of skill or resources.
I'm a huge supporter of the FSF (Free Sofware Foundation) if you can't tell. Anyone who wants instructions for use with the OpenOffice.org suite I can provide those as well.
Old 06-05-2007, 02:45 PM   #37 (permalink)
Hot n Spicy
FA5SI's Avatar
Nice Analysis!
FA5SI is offline   Reply With Quote
Old 06-05-2007, 03:14 PM   #38 (permalink)
William
Originally Posted by FA5SI
Nice Analysis!
Many thanks.
I have finished the How-To, but it is rather lengthy and image heavy. Adding it to the current thread could make it too lengthy. I might make another thread of it though.
Old 06-05-2007, 05:08 PM   #39 (permalink)
William
UPDATE: I have posted the How-To and made some cosmetic changes to the first couple posts to make everything fit better.
I have also poster the maps for the GT3267 turbo which I used as the example for the How-To. I hope you all find this useful for your own analysis.
Old 06-05-2007, 05:33 PM   #40 (permalink)
Doraemon!
marc-o-lishuz's Avatar
Marc
Definitely sticky material here. Good job with the analysis.
marc-o-lishuz is offline   Reply With Quote
Turbo Specialties K20Z3 Extreme or Greddy? turbocivic519 Forced Induction And Nitrous 12 10-16-2007 06:30 PM
Turbo Specialties K20Z3 new turbo? Kay Forced Induction And Nitrous 9 07-24-2007 08:39 PM
"Turbo Specialties K20Z3 Extreme Turbo Kit." Anyone has this kit? HoNdA06 Bolt-Ons And All-Motor 5 07-19-2007 01:45 PM
Turbo Specialties K20Z3 Extreme Turbo Kit - 290+ whp chilipepper Forced Induction And Nitrous 39 07-18-2007 05:57 PM
Question on Turbo(ing) the K20Z3 JDMoore Forced Induction And Nitrous 41 07-12-2007 06:13 PM
