Old 05-23-2007, 12:33 PM   #1 (permalink)
Dave
will i need intercooler?
hi, if i have a greddy turbo kit. will i need to buy my own intercooler and blowoff valve? or can it run the turbo alone without it and i can just buy it later when i upgrade my turbo?
ddldave is offline   Reply With Quote
Old 05-23-2007, 12:36 PM   #2 (permalink)
NIGHTHAWKSI's Avatar
Ian
i thought the greddy kit comes with a intercooler. a blow off valve is not at all necessary for the basic greddy setup.
Old 05-23-2007, 12:38 PM   #3 (permalink)
codys8thcivicsi's Avatar
Cody Lopez
i think it comes with both intercooler and bov
codys8thcivicsi is offline   Reply With Quote
Old 05-23-2007, 12:41 PM   #4 (permalink)
Dave
wow i didn't know that
Old 05-23-2007, 12:42 PM   #5 (permalink)
Ian
www.greddy.com will tell you all the information you need to know about what comes with the kit.
Old 05-23-2007, 12:42 PM   #6 (permalink)
Dave
how strong is the greddy turbo? how many psi?
Old 05-23-2007, 12:53 PM   #7 (permalink)
GreySi07's Avatar
Do you have the kit or your thinking about getting the kit?
GreySi07 is offline   Reply With Quote
Old 05-23-2007, 12:58 PM   #8 (permalink)
Dave
i am thinking about it. does it come with instructions on how to install?
Old 05-23-2007, 01:12 PM   #9 (permalink)
GreySi07's Avatar
the kit comes with the intercooler not sure about BOV.If the instructions arent in the box you can get them from the greddy website.I am gonna get the kit too but Im gona wait to buy it because they are updating the plug-n-play harness and are not currently shipping any kits.
Old 05-23-2007, 01:18 PM   #10 (permalink)
Estrike's Avatar
intercooler = yes
bov = no
Estrike is offline   Reply With Quote
Old 05-23-2007, 01:43 PM   #11 (permalink)
LoverOfCivics's Avatar
Javier
Doesnt come with bov, comes with intercooler, the kit produces about 5-7 psi, and about how strong it is?? its upgradeable ill leave it at that, if your looking for about 280 get the ajp down pipe with this kit along with a good tune and the numbers should be right there dont forget your AFR and boost gauges
Edit:and another thing just recirculate the bov because the bov by itself will make the car run rich
LoverOfCivics is offline   Reply With Quote
Old 05-23-2007, 02:14 PM   #12 (permalink)
Dave
5-7 psi? how do i make it 7psi instead of 5?
Old 05-23-2007, 02:17 PM   #13 (permalink)
Andrew
tuning...MBC
OP: Don't run either, you don't need them. But if you do decide to get one over the other get the BOV as it will cool your turbo when it shoots into the atmosphere......
hahahahahahah!!
Drew07LX04STI is offline   Reply With Quote
Old 05-23-2007, 02:18 PM   #14 (permalink)
Andrew
ok really...obviouslly you need the intercooler but dont even bother with the BOV. its not necessary....at all!!!!
Old 05-23-2007, 02:27 PM   #15 (permalink)
Javier
Get a boost controller and make it run 15 psi
And FTW there both neccessary,, intercooler is a must , and recirculated or not bov helps to prolong the life of your turbo
Old 05-23-2007, 02:28 PM   #16 (permalink)
eugenekim.net's Avatar
captain obvious
i dont think u should be purchasing a turbo kit if u dont even know what components it needs nonetheless how it works.
Old 05-23-2007, 02:32 PM   #17 (permalink)
Javier
Well who can blame him i can find the greddy kit coming with 2 different size injectors
Old 05-23-2007, 02:40 PM   #18 (permalink)
Andrew
yeah and it keeps the turbo spooling in between shifts whcih makes you faster!hahahhaha!
really, a Bov is only necessary when running high boost applications. That excess air left in a turbo boosting 5-7psi with no Bov is not going to harm your snail.
I'd be more concerned about running rich and the loss of power from a bov than gaining a cool noise!!
Im glad the opening post is about an intercooler. i agree with a few posts above me about not getting a turbo kit if the Oposter didnt know that an intercooler was necessary!!
Old 05-23-2007, 02:40 PM   #19 (permalink)
bboylocob's Avatar
BRENT
just a note with the injectors that come with the kit they are 370cc injectors.370cc injectors usually max out at 250whp on a dynojet.so that is probl. the max power you will get out of those injectors.the peps that are getting 280hp they are getting those numbers on a hub dyno not a wheel hp dyno.
now the 440cc injectors will get you about 280whp maybe a lil more
bboylocob is offline   Reply With Quote
Old 05-23-2007, 02:48 PM   #20 (permalink)
k20beast's Avatar
zack
yess the bov may not be needed now...but if u run much more boost id say get one... bc if u dont u will be needed to upgrade the turbo due to compressor surge.
k20beast is offline   Reply With Quote
Intercooler/ license plate? carter21 Inside and Out 14 05-13-2007 09:46 PM
Intercooler carter21 Civic SI 10 03-20-2007 01:08 PM
Heat exchanger info for the guys running the Comp supercharger kits sheek360 Forced Induction And Nitrous 1 12-01-2006 10:26 PM
Side Mount Intercooler? J-StarR Forced Induction And Nitrous 6 05-19-2006 09:01 PM
