#1 (permalink)
Installing an Apexi AVCR + ECU pinouts
2007 civic si - After a few hours I installed a apexi boost controller!!
It was a pain in the butt looking for an ecu pinout but I got the job done!!! Connector A Pin 28 (RPM) Blue wire Pin 29 (Speed) Blue wire Connector C Pin 20 (Throttle) Red/Black wire It was a pain in the butt looking for an ecu pinout but I got the job done!!! ![]() CLICK LINK for the FULL ECU Schematic http://geocities.com/paulo421/fg2ECU.jpg Last edited by k20guy; 05-18-2007 at 07:48 PM. |
#5 (permalink) | |
280whp, 219tq, GReddy FTW
If you must whine about my Avatar, do it in this thread: http://www.8thcivic.com/forums/showthread.php?t=35167 |
oh and +rep to K20Guy for wiring instructions!
#7 (permalink) | |
+ rep...Thanks for posting. Here is some more to add regarding the stock wiring for the Si (Throttle signal is the only one of the three connections that does not eventually route into the cabin):
Engine Speed (Tach) Connection ECM Connector A, Pin 28 (Outputs Engine Speed Pulse (NEP)) --> BLU Wire --> Connector D, Pin 3 (BLU (NEP)) on the EPS Control Unit (located inside the cabin behind the kick panel on the passenger's side) Vehicle Speed Connection ECM Connector A, Pin 29 (Sends vehicle speed sensor signal) --> BLU Wire --> Connector C201, Pin 4 (on the 2006 Si) or Connector C202, Pin 10 (on the 2 door 2007 Si) --> BLU Wire --> Connector G, Pin 5 on the Under-dash Junction Box (located inside the cabin under the dash on the driver's side)--> Out of the Under-dash Junction Box via a BLU Wire coming out from Connector E, Pin 2 and a BLU Wire coming out from Connector D, Pin 2 Throttle Position Sensor Throttle Position Sensor/Throttle Actuator (on the throttle body), Pin 1 --> RED/BLK Wire --> ECM Connector C, Pin 20 (Sensor Input (TPSA): Detects Throttle Position Sensor A Signal)...ECM does not output. Throttle Position Sensor/Throttle Actuator (on the throttle body), Pin 3 --> RED/BLU Wire --> ECM Connector C, Pin 21 (Sensor Input (TPSB): Detects Throttle Position Sensor B Signal)...ECM does not output. TPSA measures ~3.9V with the throttle fully open and ~0.9V with the throttle fully closed TPSB measures ~4.1V with the throttle fully open and ~1.7V with the throttle fully closed Last edited by blueroadster; 05-18-2007 at 04:20 PM. |
#9 (permalink) | |
i have an R18 is it the same on my ECU ??? ((ECM Connector A, Pin 28 (Outputs Engine Speed Pulse (NEP)) --> BLU Wire )) i was planing to install a shift light ... can i use the same pin (A-28) ??? |
#10 (permalink) | |
thanks. |
#13 (permalink) |
For the various connections, I provided a trace from it's ECM connector and out to various other connectors on the car. If you are looking for the tach signal line, you can grab one from inside the passenger cabin. If you look behind the kick panel on the passenger side, you will see the EPS Control Unit as shown in the below PIC.
![]() The grey connector in the center is what is called "Connector D." Pin number 3 on this connector (towards the right in the above PIC...two pins away on the same row where the white wire is located) has a solid blue wire running to it that needs to be tapped to get the tach signal. Last edited by blueroadster; 07-24-2007 at 03:26 PM. |
#14 (permalink) | |
For the shift light, I'd suggest tapping the line mentioned in my previous post so that way you will not have to run any wires from the engine bay and into the passenger cabin. |
#17 (permalink) | |
#19 (permalink) |
sorry to bump this old thread, but james lewis question was never answered...
i need the throttle position sensor signal. but it seems there are 2 wires. which one do i want? 1. ECM connector C, pin 20? 2. ECM connector C, pin 21? thank you in advance and +rep to whoever gives me a credible answer first... |
#20 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/forced-induction-nitrous/40138-installing-apexi-avcr-ecu-pinouts.html
| Diagrama de ecu civic 07' - CARRITO.NET | Post #0 | Refback | 01-26-2008 05:16 PM | |
| (Req)Wiring Diagram For Honda Civic (R18A1 Engine) - E-Manage Support Forums | This thread | Refback | 12-20-2007 11:04 PM | |
